Username Post: URGENT PROM 85 ERROR - I'm stuck in Mexico!!        (Topic#287680)
bob5513
Reg: 09-29-12
09-29-12 09:11 PM - Post#2274940
Hi! we're a British couple with a Canadian-born 1992 Chevrolet g30 1 tonne van (5.7 auto) currently in Palenque, Mexico and supposedly headed for Argentina!!
We have an urgent problem as we cannot drive far due to a fault - the vehicle starts fine but once warm it will gradually loose power, struggle and come to a stop. if we restart the vehicle immediately it will work fine for a few hundred yards before beginning to stuggle again. The problem gets progressively worse the longer we drive but for the first 20-30 minutes each day it is fine!
Here is some background: driven from Canada, no problem (except a new shield, exhaust etc.!). 2 days ago we parked after driving as normal but car would not start after a 10 minute stop. Local mechanic identified faulty FUEL PUMP and dropped the tank and replaced it. Started fine and we drove up a big steady hill for 50 minutes then around a town. Van worked fine.
After 2 days parked, 15-20 minutes down the road the loss of power started uphill and we grinded to a halt some 5 minutes later. Got towed to the next town and limped in. Got new fuel (better octane fuel - 91 (the best in Mexico!) but we had previously been running 87 (and also in US and Canada with no problem). After refuelling started and drove fine for 10 mins.
Next day, after 10-20 minutes of good, normal operation the same loss of power again and we had to limp in to the next town. If turned off it would then go well for a few minutes before gradually dying again.
I have since: replaced air filter, checked fuel filter, visually inspected for leaks, put some injector cleaner in, driven around, cleaned spark plugs (they were all sooty black an they probably are again now), partly dismantled the TBI to inspect the fuel injectors (seem OK when just started until problem starts), and checked that there is fuel coming in.
I have not checked fuel pressure (need to find a mechanic on Monday). I assume the mechanic who replaced the FUEL PUMP put the right one in but I do not know. I saw it briefly (it was 9pm) and it looked the same. It is strange that the problem has developed 40-50 miles after a new pump but it seems to be working). We seem to be using more fuel than usual.
Fault codes read 44 (lean mixture)
and
fault code 85 (PROM error)
If anyone can suggest likely cause please help. i have a haynes manual, an adjustable wrench and basic Spanish :P
Parts are hard to find, as are mechanics with full facilities and no Chevrolet dealer nearby or breakers yard that I know of. Need to identify the problem asap as we have nowhere to stay!
thank you so much and sorry for the length of this !
DEI8FAN
DEI8FAN
Loc: Western, N. Carolina
Reg: 02-01-05
09-30-12 04:47 AM - Post#2274970
    In response to bob5513
I did find this, sounds like your engine computer is toast.
Auto Systems and Repair
GM OBD Code 85
OBD I Code 85 - PROM error
If the ECM detects an internal fault with the PROM code 85 will set. The PROM is a special "chip" that is installed in the ECM, based on the particular vehicle configuration.
Fault Code Description
85 - PROM
Symptoms
Engine may not start
Poor engine performance
Common Problems
Internal fault with PROM
PROM incorrectly installed in ECM
The lean code could be caused by the prom code which should be fixed first.
1959 El Camino
1970 El Camino
1981 Corvette
2004 Z71
2005 Monte Carlo
bob5513
Reg: 09-29-12
09-30-12 08:14 AM - Post#2275025
    In response to DEI8FAN
thank you. I reset the computer (by taking the battery terminal off) and although I still had a problem (lack of power, some knocking/pinging maybe, odd misfire and generally no go) it hasn't re-registered any fault codes...very tough to find a new PROM down here.
We will get a fuel pressure
test done tomorrow.
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
01-02-13 07:03 PM - Post#2303485
Bob, just saw this (it three months old) and wondered how things worked out? Hope they did and that you reached your destination without too much additional hassle. Don
Chevytech
Chevytech
Reg: 04-25-04
01-04-13 03:05 PM - Post#2303971
    In response to Highlander1
He started another thread.
  • bob5513 Said:
Then I accidentally knocked the connector joining to the Igntion control module and it sporadically worked.
Problem was just those metal ends inside the 4 pin plug has been loosened with the removal of the plug!! They looked fine, no corrosion and I didn't spot them at first check. I just pinched them tight and she runs great!!!!!!!
Execution time: 0.093 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:37 AM
