Username Post: major problem need help some pro help        (Topic#284142)
devic
Reg: 07-15-12
07-15-12 03:06 PM - Post#2248476
car: 2000 trans-am ls1
ok so first ill list what i have done to the car, then what is going wrong. so that you can have a full idea of what might be going on.
*replaced:
intake gaskets
torque converter
starter
throttle body
throttle body sensors
egr & air delete
fuel filter
racetronix fuel pump 255lph
oil & transmission fluid
transmission filter
pcv oil catch can
new battery
this is all the new stuff.....
*old mods....
slp lid
02 sims
cat gut
msd wires i made
3" magnaflow cat back
all free mods
*i have the hot wire kit for the fuel pump but i haven't put it on yet
*tried blowing compressed air threw the lines to clear out any old gas that might have been in there (disconnected line at motor and filter)
injectors where all clogged i cleaned them and now all injectors are operating
tested with noid light all injectors are getting signal
current problems im now having:
***UPDATE***
the car is only getting 40 psi @ the fuel rail,
**update: after cleaning injectors they fuel rail pressure is now @ 35 psi with a very slight leak down in pressure
coil 4,5,7,8 are firing. 1,2,3,6 are not firing checked via spark tester (swapped coils around same cylinders firing)
car tries to start after i turn the key for about 3-5 seconds then dies
********car is now not cranking over and it is backfiring out of the intake also blew out my valve cover gaskets*********
idk if this could be part of the problem but this is how my pcv is set up after air & egr delete
**results for "trigger wire" from pcm to coils and spark test without "plug wires"
also the "check gauges" light is on idk if this matters ?
also car was setting for bout 3 years
Edited by devic on 07-15-12 03:13 PM. Reason for edit: No reason given.
89RS98Z28
89RS98Z28
Reg: 10-14-04
07-16-12 01:33 PM - Post#2248803
    In response to devic
Go register at ls1.com and post up over there . Lots of good info there also........
A lesson learned the hard way is not easily forgoten.
Execution time: 0.099 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:39 PM
