Username Post: drivetrain problem        (Topic#283362)
sixty5short
sixty5short
Loc: NC
Reg: 05-20-02
06-29-12 12:53 PM - Post#2242673
Hey gang, I just picked up my first vette - a 1998 6-speed, just got it last night. It's a high mileage car (179K) but it looks/runs/sounds great. Had a blast cruising around last night, but today it's doing something nasty it hasn't done before. This sure didn't happen on my test drive! Figures.
This is hard to describe, so bear with me. It happens on take off from a stop, about 1 out of every 4 or 5 times. No apparent rhyme or reason as to when it will happen.
In first gear, ease out on the clutch with little or no gas applied. the most gentle takeoff you can imagine. Then it happens- this fairly severe vibration/shudder, almost like clutch shudder you get from fluid on the disk but not as "distinct" as that. Not sure which end it is coming from.
Sometimes when the vibration starts I'll push the clutch back in, knock it into neutral and let the clutch back out- and the noise/vibration continues for a few seconds with it in neutral and the clutch out.
My guess is the release bearing or clutch is messed up. Hate to get into that project without knowing for sure what is going on.
Sure would appreciate some insights if anyone has them to share.
- "sixty5short"
'65 C10 Shortbed Fleetside
'60 Impala 2 dr
'57 210 2dr Sedan
hotwheels57
hotwheels57
Reg: 11-20-02
06-29-12 02:01 PM - Post#2242696
    In response to sixty5short
WOW, if the original clutch/slave assembly is still in your car, it's certainly gave the previous owner plenty of miles. Most C5 Corvette clutches need attention long before they reach that many miles.
The torque tube bushings might be deteriorated. Some owners use BMW bushings which are similar. I believe the aftermarket may have some upgraded bushings as well. It will require the entire torque tube assembly to be removed.
Although your symptoms don't coincide with the usual dirty clutch reservoir fluid issues, you might start with something simple and DIY. Check the clutch reservoir. Chances are the fluid is very dirty unless it's been regularly changed.
Check out this link. "Ranger" is well known for his procedure in changing out contaminated clutch fluid which causes common clutch woes.
http://www.rangeracceleration.com/Clutch_Care.html
That might help the symptoms. Changing the transmission/transaxle fluids would also be a good idea if you're not certain of the previous owners preventative maintenance practices.
Karma is the universal equalizer. The Ignore User feature comes in a close second.
Edited by hotwheels57 on 06-29-12 02:10 PM. Reason for edit: No reason given.
TAT_2
Member #26 "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
06-29-12 03:49 PM - Post#2242734
http://www.corvsport.com/Corvette/C5/1998/C5_1 998_...
HERES THE WAVE !!!
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6SPD/RAG TOP
NEXT ?
sixty5short
sixty5short
Loc: NC
Reg: 05-20-02
06-29-12 07:03 PM - Post#2242791
    In response to TAT_2
Thanks hotwheels. Yeah I have no idea if this the original clutch or not. Sucks not knowing the history of your car. I am planning on doing the Ranger method tomorrow. I sold my 2005 GTO to buy this vette, so I've been around that block before.
Hey TAT... I haven't been on the board in a while- your post count is crazy high now! Anyway thanks for the link and the Vette wave.
PS I may have bigger problems than I thought. Went to move the car into the shop and discovered major oil on the floor. Great.
The car is lowered and I haven't been able to get it on the lift just yet. But I bet I've blown a seal (rear main? oil Pan?) in the first 24 hours of owning this car. Oh boy!!! With the amount of oil this thing is dripping, it could definitely explain the chattery clutch.
Didn't think I was buying a project car, but it may very well turn into one.
- "sixty5short"
'60 Impala 2 dr
'57 210 2dr Sedan
TAT_2
TAT_2
Reg: 10-29-00
06-29-12 09:41 PM - Post#2242831
LET US KNOW WHAT YA FIND,CHEK THAT BATT ACID ISSUE ALSO.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
sixty5short
sixty5short
Loc: NC
Reg: 05-20-02
06-30-12 05:31 PM - Post#2243083
OK, one problem identified. It wasn't oil, it was really dirty power steering fluid. The high pressure line from the pump to the rack is blown.
Not sure exactly what is involved to replace- the connection at the pump is quite well hidden by the PS pulley.
Not sure if this is related to the drivetrain problem yet.
- "sixty5short"
'60 Impala 2 dr
'57 210 2dr Sedan
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
07-01-12 04:31 AM - Post#2243210
Let us know....
Hey T @!
Joe
hotwheels57
hotwheels57
Reg: 11-20-02
07-01-12 08:37 AM - Post#2243274
Good luck with it. You'll probably go through a lot of these irritations until you get it all sorted out...
Edited by hotwheels57 on 07-01-12 08:49 AM. Reason for edit: No reason given.
sixty5short
sixty5short
Loc: NC
Reg: 05-20-02
07-03-12 03:33 AM - Post#2243875
    In response to hotwheels57
OK I got the line replaced- got lucky and was able to break both the fittings loose without taking the PS pump off the car. Still having the drivetrain problem but not as frequently/severely as before. Still unsure of any cause/relate there.
- "sixty5short"
'60 Impala 2 dr
'57 210 2dr Sedan
65_Impala
Reg: 12-29-02
07-12-12 08:45 PM - Post#2247626
Sure sounds like the clutch is doing something funky. Maybe the pressure plate has a broken piece. Pull the inspection cover off and take a look at it, preferrably with someone else to operate the clutch at the same time.
The couplers usually are usually reported as more of a rpm related vibration and not that severe. I would not recommend using the BWM couplers if you get into it. They are softer and just don't hold-up as well. Get GM replacements.
I was going to say that you can reach the PS line pretty easy but you already got that one figured out. Mine was leaking pretty badly too and I have some parts here so I stuck the extra one on and it leaked a little as well. It seems to seep right through the rubber hose.
elcaminokevin
Loc: Mississippi
Reg: 05-18-13
05-18-13 11:51 PM - Post#2346892
In older cars with standard tranny, they had a Bronze bushing in the end of engine crankshaft, new LS engines have a bearing there, when bearing goes out it cause's that noise, my '99 had the same issue with the noise then eventually stopped then the vibration started, that was my problem, Bearing had gone out, the bearing hold the very front tip of the Shaft that goes to the tranny. most call it a pilot bearing. Hope this helps.
Kevin Edwards
Execution time: 0.198 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:54 PM
