Username Post: problems deleting datalogs - hp efi        (Topic#282367)
alev8
Reg: 02-06-08
06-09-12 10:15 PM - Post#2235330
hi guys
i am getting a weird error on my hp efi ecu
i cannot save or delete or download any ecu data log
i am getting the following error
there was a problem deleting the log file.
it only show one file (named err000)
my firmware version is 397
my serial number is below 500
any help is appreciated
thanks!
Danny Cabral
Danny Cabral
Loc: Connecticut
Reg: 11-03-04
06-10-12 03:19 AM - Post#2235344
    In response to alev8
Right click the desktop icon for Properties, go to Compatibility and check 'Run this program as an administrator'.
Also, you can allow yourself full permissions, by editing the Security
options (in Properties) to ensure you're not denied any access or control.
If you're running Windows 7, and you get an error when you are trying to save or delete
a folder, your computer is not setup to give you “write” (save) privileges.
To fix this, perform the following steps:
· Select the “Start” button.
· Select “Computer” and select drive “C”.
· Select “Program Files” or “Program Files (x86)”.
· Select “Holley”.
· Right click your mouse on “EFI”.
· Select “Properties”.
· Select the “Security” tab.
· Look at the “Group or user names”. You need to select the Group or user that is running the EFI software. This is likely the “Users” name.
· Click on the proper “Group or user names” and look at the “Permissions for Users” at the bottom of the properties screen. If you are having a save problem the “Write” area is likely not checked in the “Allow” column. To correct this click the “Edit” button then click on the Allow “Full Control”. Hit “Apply” and “OK”.
· You should then be able to save/delete/change a file.
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, A/C, Lentech Strip Terminator AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, 4" lift, 35" tires
alev8
Reg: 02-06-08
06-10-12 07:25 AM - Post#2235383
    In response to Danny Cabral
i Danny
the same error occoured
here is a pic for the error
Danny Cabral
Danny Cabral
Loc: Connecticut
Reg: 11-03-04
06-10-12 10:48 AM - Post#2235442
I don't know then. I've never had that problem. Which operating system?
http://www.holley.com/data/TechService/Tech nical/1... (Data Logger)
Danny Cabral
Danny Cabral
Loc: Connecticut
Reg: 11-03-04
06-25-12 11:43 PM - Post#2241391
Alev8, did you ever find the solution to your problem?
alev8
Reg: 02-06-08
01-25-19 12:05 AM - Post#2758169
Hi Danny
been a while
no, i didnt . nowadays the ecu is on v4 and the same error occurs.
actually i was looking for some type of solution and came accross this post... lol
i am going to put this question on a holley techboard / forum and expect someone from holley to help me fix this glitch.
i tried lots of different notebooks and the same happens on them. i dont think this is a notebook problem, it may be a corruption on the internal sd card...
thanks
Execution time: 0.095 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:52 PM
