04-22-12 09:51 AM - Post#2217883
i have a loaner 2007. when i drive in 1st or 2nd (stick shif) at low revs as i transition from on the gas to off, or vice versa, i can hear a click in the rear. sounds like a cv joint. anyone experience this?
04-23-12 07:30 PM - Post#2218489
In response to bobb
ok i had a chance to look at it. parking brake on, 1st gear feather the clutch and it sounds like the cv joint clicks. put it in reverse and do the same and the same click. bad cv joint?
Sting Ray
"19th Year" Silver Supporting Member
Loc: Westwood Hills, Kansas
Reg: 02-19-05
04-27-12 11:53 AM - Post#2219713
In response to bobb
A few things to check; rear sway bar monunting bolts.
Broken shock mount.
The support springs for the x-pipe in the exhaust; push it up and down and listen for the noice.
Most likeley the rear axle nuts. There is a castle nut with washer that needs to be torqued.
Bleeds Chevy Orange
1955 Bel Air hardtop, 327, 4-spd, tilt front end
1964 Corvette two top convert, 327, 4-spd
1967 El Camino, 427, 4-spd
2022 Corvette coupe, Arctic white, red stripes, 3LT Morello Napa leather |
04-27-12 07:20 PM - Post#2219831
In response to Sting Ray
thanks for the tips.
04-29-12 09:43 PM - Post#2220496
no castle nuts. just nuts. loose nuts. i took um off with the short ratchet, like 12 inches long. i put um back on with a 3/4 inch ratchet and a helper bar with locktite. i hope the splines didnt take too much of a beating. i will need to monitor these things.
