Username Post: Speedometer Repair Information        (Topic#271437)
11-01-11 07:30 PM - Post#2153599
Thanks to Charle AKA Wagonman for sharing this great information.
Attachment: Speedometer_Repair.pdf (3.38 MB) 2652 View(s)
bowtieollie
bowtieollie
Reg: 12-06-99
11-02-11 05:16 AM - Post#2153696
Let's make this STICKY!
Bowtieollie
Chevytalk.com Moderator
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
11-02-11 06:00 AM - Post#2153715
    In response to bowtieollie
Thanks a lot Tony.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
11-02-11 07:37 AM - Post#2153732
    In response to WagonMan
Great how-to Wagonman. A couple items to add to this. Many Corvette aftermarket suppliers sell the number sets for '57 Corvettes that I would think are interchangeable with the tri-5 sets. Also, the internal gears are not available. I'm sure someone makes them, but they are not available to the public. I tried several speedometer repair and parts places to get one for our 57 Corvette, but all they will do is rebuild your unit. If you are lucky, you might be able to file down any bad spots on the gears to get them to run smoothly. It worked for me.
Ken
36, 38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
http://www.picturetrail.com/ken
Smokey
Senior Site Adminstrator
Smokey
Loc: "Small town USA"
Reg: 12-06-99
11-02-11 08:38 AM - Post#2153754
Good idea Ollie. Here ya go.... a sticky it is......
'67 427 Chevy C-10
'79 454 surburban
'89 454 1 ton dually
'03 V-Star 1100
In Memory of CT's Mike McVeigh and Ron Schrapp (aka rons56)
fran0216
fran0216
Reg: 10-27-09
11-02-11 08:48 AM - Post#2153759
Thanks!! this we will help me a lot!! My speedometer is out of a 56, they looked the same from looking at the 57 pdf. My speedometer cable broke and I some plastics peices remains are still inside, I've read a thread to use a drill bit to remove the plastic pieces, drilled and removed some pieces, but when I stick a needle in it, I hit plastic still, I assume if im hitting plastic with a needle there are still remains of plastic pieces in the gear? Is it solid at the other end where the magnetic spins with the cable? What is the best way to remove the plastic pieces that broke inside? Thanks!
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
11-02-11 09:26 AM - Post#2153776
    In response to bowtiefan
Ken
From my experience many of the internal parts will interchange up into somewhere in the 70's so that would open up the possibility of parts availability. You only have to match old parts against replacement parts to make sure. Some parts also depend on the sweep arc of the needle to be compatible.
I haven't personally done it but have seen a speedometer head in a 57 that the owner exchanged the guts from a later model with the trip function and with a bit of work on the face and lens had a nice looking speedometer with a working trip odometer.
Charles
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
11-02-11 09:36 AM - Post#2153778
    In response to fran0216
If you are talking about the square hole on the back of the speedometer head, the hole is about 3/4" to 7/8" deep. You will have to drill it out with a small enough bit to about that depth and with a large pin or needle, try to dig out the remaining bits. Going to be very tedious work.
Charles
beejay
Deceased Member
beejay
Loc: Pflugerville, Texas
Reg: 06-01-04
11-02-11 09:49 AM - Post#2153784
Are you talking about having plastic parts in the speedo cable housing? If the cable is broken, take it completely out, and use compressed air to blow out the housing. Then you can put in a cable repair kit and use liquid graphite (speedo cable lube)when you have the new cable in the housing. Then work the cable back and forth (top to bottom) to insure it's lubed all the way down.
Bruce
http://www.picturetrail.com/beejay3/"
fran0216
fran0216
Reg: 10-27-09
11-02-11 10:25 AM - Post#2153802
The plastic end of the cable that connects into the square hole has completely broken and I've gotten some out. I'll continue to drill and dig with a pin and yes its tedious work. Thanks!!
albjerryg
Loc: Lafayette
Reg: 07-06-11
09-19-14 03:21 PM - Post#2485232
    In response to beejay
I get the car back tomorrow so I will be able to check if the odometer is moving or not. Thanks for the help....Jerry
Execution time: 0.108 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:18 PM
