 Page 1 of 3 123
Username Post: Yes...another rear end question        (Topic#267475)
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
08-10-11 04:55 PM - Post#2124202
I'm still somewhat lost on what rear end to run under my '53. It is getting a 383 stroker making just shy of 500hp at the crank and I will also most likely run a 700r4 behind it.
I would also like to run a 8" wide rear wheel if possible. So are there any readily avaliable (ie: pick n' pull) axles that would hold up to this engine and be narrow enough to run this wider wheel? I will also be upgrading to 2.5" leaves.
Thanks again!
- '53 Belair 2 door post. Ford 8.8 rear, Currently getting CE M2, 383 stroker/TH400, and any spare change I have!
53belair
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
08-10-11 06:36 PM - Post#2124233
    In response to Sixshooter
The best drop in fit for that power train is not going to be easy to find. A 12 bolt posi from a first gen camaro or firebird (or nova) would be the best fit and most durable. It has a 60 in. dimension which is the same as your 53.
A second gen camaro/firebird third member will fit and is plentiful but good it isn't going to be as strong. Then again, it may not fail before the 700r4. It's 61 1/2 in. but it would carry the 8 in wheel easily. You would probably need a 4 or 4 1/2 in back spacing depending on the tire you are running.
1953 Belair Sport Coupe,350/350/Fatman/Dako ta Digital/American Shifter/Southern Air/Ciadella Interiors
1967 Chevelle 396 Muncie
2010 Camaro II-SS
2011 Camaro Pace Car
2012 Tahoe
Bill K.b
Loc: upstate NY
Reg: 10-24-05
08-10-11 09:10 PM - Post#2124307
    In response to 53belair
I think the 10 bolt would be okay, because the car is too light, you should be spinning the tires before you can hurt the rearend.
There are some Ford 9" rears with a 60" housing too, if you want to go that route.
But the second-gen Camaro is probably going to be the easiest to find in the you-pick, if the S10 is too weak for that kind of power.
Those who can, do. Those who can't, criticize it on the internet.
Driving 2002 Express 2500
2002 Express 2500 extended
1988 G20 conversion
1993 GMC 3500 dually
Plus cars for swap and sale
& yes, I once tried a frame swap on a 51 Chevy.
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
08-10-11 10:30 PM - Post#2124347
    In response to Bill K.b
Thank you both for the advice. I plan on using the Chasiss Engineering leaf spring kit and it shows they have a kit for the 67-69 camaro rear which is a 10 bolt, correct? And I assume with this kit and the correct rear end it should be a straight forward swap.
Anything else I need to check out at the junkyard when looking for a rearend? Were these posi units and what ratios did they come in? Thanks again and I appolagize for the ignorant questions.
usmile4
"11th Year Gold Supporting Member
usmile4
Loc: Aurora, Illinois
Reg: 08-12-05
08-11-11 07:30 AM - Post#2124424
Here's a chevy axle chart that I had in my bookmarks. It lists a bunch of information on the Chevy rear ends.
Bill Gommel
Bill K.b
Loc: upstate NY
Reg: 10-24-05
08-11-11 08:16 AM - Post#2124445
    In response to usmile4
I honestly think it's highly unlikely to find a first-gen Camaro in a junkyard. A Nova that era, sure, there's a couple 74s in a yard here, but the first gen cars I have only seen in older yards where they've been rotting for 20+ years and that's getting harder and harder to come by.
1988 G20 conversion
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
08-11-11 09:02 AM - Post#2124469
Does anyone know what Ford 9" rears would fit this application if I decided to go that route for more strength? And if I run a 8" wide wheel what would be the ideal width? 60" like the stocker? Or wider or more narrow?
Thanks!
Coaldalecar
Coaldalecar
Loc: High River, Alberta, Cana...
Reg: 10-10-08
08-11-11 04:35 PM - Post#2124623
An 8 inch F**d rear out of an early mustang is the right width. Don't know about the 9 inch.
Alan Klassen, Alberta, Canada
1952 Chev 2Dr Sedan Deluxe (on the road, finally)
02 Chev Silverado Ext Cab
2012 Fusion AWD
2007 Kawasaki 1500 Vulcan
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
08-11-11 07:25 PM - Post#2124686
    In response to Coaldalecar
A 9" would be the strongest, but pricey. I went with an 8" from a mid to late 70's Ford (this one just happened to come from a '79 Monarch) Not quite as beefy as a 9", but stronger than a 10/12 bolt GM rearend. One downside is the difference in bolt pattern. You can get different axles or have them redrilled (sometimes) but then your into it for more cash.
Bill K.b
Loc: upstate NY
Reg: 10-24-05
08-12-11 01:28 AM - Post#2124746
    In response to kool53
The Monarch/Granada/Versaille s are the same body... seems like the Lincoln one usually has a 9" with disc brakes. They're not super common either but they're not quite the unobtanium an early Camaro is going to be.
1988 G20 conversion
50hotrod
50hotrod
Reg: 07-25-11
08-12-11 07:55 AM - Post#2124799
Thanks!
OPEN DRIVELINE CONVERSION
To convert your torque tube suspension to a open drive line. You will need the proper width rear-end. I am running a 1976 camaro 10 bolt.
These are some swaps that will work.
* 55-57 Chevy Cars. (57 is best choice)
* 68-72 Nova
* 70-81 camaro
For 49-54 cars,you will need a rear-end that is 60" wide. You can use the stock leaf springs but you will get a much better ride with a wide leaf spring kit. (2.5" wide) If you run a rear-end that is 58.5 inches wide you will be able to run a 8" wide rim (3 3/4" backspacing)in the rear.
1950 CHEVY 2 DOOR 327 TRI POWER FENDERWELL HEADERS HEIDT FRONT SUSPENSION 700R4 TRANS 411 REAR
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
08-12-11 08:57 AM - Post#2124841
    In response to 50hotrod
Thanks again for everyones help. It looks like a 58.5" rear is what I am after then. And that measurement is simply taken from wheel mounting surface - to wheel mounting surface, correct?
EDIT: I found Ford 9" this chart while searching, please don't hang me for posting this on a chevy site!
Anyways, which of these other axles would be close enough to work in my '53 with a 8 wide wheel? How about the Bronco rear at 58"? Im just thinking a versailles rear might be scarce.
1965-1966 Mustang 57.25 inches
1967-1970 Mustang 59.25 inches
1971-1973 Mustang 61.25 inches
1977-1981 Versailles 58.50 inches
1967-1973 Mustang, Torino, Ranchero, Fairlane 59.25 inches to
61.25 inches
1957-1959 Ranchero and station wagon 57.25 inches
1966-1977 Bronco 58 inches
1977-1981 Granada/Versailles 58 inches
1967-1971 Comet, Cougar, Mustang, Fairlane 59.25 inches
1964 Falcon 58 inches
1967 Cougar 60 inches
1967 Fairlane 63.50 inches coil springs
1972 Ford Van 3/4 ton 68 inches
1973-1986 Ford Van 3/4 ton 65.25 inches
57.25 inches
narrowest 9" housing
1966-1977 Bronco 58 inches 5-on-5 1/2 inch diameter bolt circle
1967-1973 Torinos, Rancheros, Fairlanes 59.25 inches or
61.25 inches
1967-1971 Comets, Cougars, Fairlanes 59.25 inches
1975 Mustang II 8" 57.00 inches
1974 Maverick 8" 56.50 inches
Edited by Sixshooter on 08-12-11 09:21 AM. Reason for edit: No reason given.
cortcomp
Loc: NE Ohio near PA border
Reg: 11-17-08
08-12-11 10:31 AM - Post#2124868
"For 49-54 cars,you will need a rear-end that is 60" wide. You can use the stock leaf springs but you will get a much better ride with a wide leaf spring kit. (2.5" wide) If you run a rear-end that is 58.5 inches wide you will be able to run a 8" wide rim (3 3/4" backspacing)in the rear. "
If you were willing to get custom (or corrected) backspaced wheels, would it really matter if you were running a 58.5 inch rear end?
I have a disc brake 3.45 posi 87 trans am GTA that i believe is 62" wide under the 50 chevy i'm working on right now, and it fit great with normal wheels. I plan on getting 8" wheels and setting them up with correct backspacing, and haven't seen any clearance issues while working under there yet.
I left the axle stock and made the frame coil spring 3 link with watts linkage, so i could get a Ford 9" or Chevy 12 bolt that's made to drop right into that generation firebird camaro, and it'd be bolt in.
However, i don't think all that affects the wheel spacing issue at all.
gsport
gsport
Loc: Salem, Oregon
Reg: 10-04-09
08-12-11 11:00 AM - Post#2124879
here's a bunch more information on the different rearends and front clips, etc..
The first gen camaro is slightly narrower than the second gen (70 - 82). First gen is 60 on the rear and approx. 60 1/2 on the front, which is almost exactly the same as your 50. This measurement is mounting surface to mounting surface (outside hub). The second gen is 61 1/2 on the front and 60 1/2 on the rear, mounting surface to mounting surface. Scroll down near the bottom of the info below and you'll find some clip measurements.
Original Vehicles
Rear Suspension Width (Flange to Flange)
Year
Classic Vehicles
Width
26-39
Plymouth-Dodge car/pick up
56-58"
40-52
Plymouth-Dodge car
60-62"
26-39
Chrysler/DeSoto Car
60"
Most Early
Mopar's
56-62"
25-39
Chevy Car
56-58"
26-46
Chevy Truck
56-58"
40-48
Chevy Car
58-60"
49-54
Chevy Car
58-60"
47-54 & 55 1st Series
Chevy Truck
60-62"
Most Early
Buick,Olds, Pontiac
58-61"
28-31
Ford Car/Pickup
57 1/2"
32 & 33-34
Ford Car/Pickup
56 1/2"
35-48
Ford Car
57-60"
35-41
Ford Pickup
56-60"
49-58
Ford Car
57-58"
49-56
Mercury
57-58"
49-51
Mercury
61"
64
Falcon
58"
67
Cougar
60"
55-59
Chevy Pickup
62"
Donor Vehicles Front and Rear
Year
Classic Vehicles
Width Front
Width Rear
74-79
Ford Mustang II/Pinto & Mercury Capri/Bobcat
55 ½"
55 ½"
71-77
Ford Maverick with 8" axle
56 ½"
75-80
Ford Granada with 8" axle
57 ½"
64-66
Mustang
57"
67-71
Mustang
59"
72-73
Mustang
60"
67-69 , & 60"
Camaro
60"
64-67
Chevelle
60"
55-64
Chevy car
60"
65-67
Nova
58"
68-72
Nova
60"
60"
78 & up
Monte Carlo, Regal, etc. with 10 bolt axle
58"
58"
68-72
Chevelle with 10 bolt axle
61 ½"
89
Trans AM (Disc brake)
62"
76-80
Camaro/Firebird
61 ½"
60 ½"
68-83
Corvette
58 ½"
59 ½"
84-95
Corvette
59 ½"
60 ½"
Early 70's
"A" body (Dart/Duster) with V8&3/4 axle
58"
"E" Body (Cuda) with V8&3/4 axle
58"
Dodge Dart
59"
55 ½"
Plymouth Volare & Dodge Aspen
61"
60 ½"
71
Blazer (6 lug)
63 ¾"
75-78
Granada 9"
(43" perch to perch)
52 ¼"
75-78
Maverick 9"
56 ¼"
81-87
Olds Cutlass
58 ½"
FRONT SUSPENSION INFORMATION
Track Width of Popular Donor Car Clips
Manufacture
Model
Years
Track Front/Rear
Curb Weight
Chevrolet
Nova
68-74
59.8-59.6
3,770
Buick
Apollo
68-74
59.1-58.8
3760
Pontiac
GTO
68-74
59.9-59.6
3880
Chevrolet
Corvette
68-83
58.7-59.5
3655
84-95
59.6-60.4
3890
Chevrolet
Camaro (Z28)
76-80
61.3-60.5
3820
Pontiac
Firebird (TA)
76-80
61.3-60.5
3900
Ford
Mustang II
74-79
55.6-55.8
3305
Pinto
74-79
55.6-55.8
3305
Mercury
Capri
74-79
55.6-55.8
3305
Bobcat
74-79
55.6-55.8
3305
Chevrolet
Monte Carlo
78-86
58.5-58.8
3235
Buick
Century
78-86
59.0-58.8
3700
Pontiac
Grand Prix
78-86
58.9-59.0
3735
Plymouth
Volare
75-79
61.0-60.5
3395
Dodge
Aspen
75-79
61.0-60.5
3395
Dodge
Dart
76
59.2-55.6
3600
Salem, Oregon
1950 chevy, sport coupe. gone, but not forgotten
2011 chevy, SS camaro, synergy green
2011 silverado 4x4 crewcab, 3500 HD
2006 corvette convertible
2014 39ft. 5th wheel
2013 harley fatboy, sold
2006 JD riding mower
18inchapes
18inchapes
Loc: Jackson, NJ
Reg: 10-18-08
08-12-11 01:25 PM - Post#2124925
Sixshooter, I have a Ford 9" rear under my '52 hardtop.I had this laying around.(I used what I got ) I also have the Chassis Engineering rear spring kit. The spring kit is super EZ to install, hardest things are removing the old spring perches(drilling the rivets) and drilling holes for the upper shock mounting.
The rear I have is from a '64-'71 full size.I measured it at 61". I installed a traction lok from a '69 mustang and set up with 3:50 gears.I'm using the stock axles.I also converted to disc brakes in the rear. 1990's Lincoln came with discs from the factory and will bolt on with slight mods. Theres a ton of aftermarket avail also. Jeff
Heres a link for the rear specs widthshttp://www.carnut.com/specs/rear.html
also a link for wheelspacing for the tri-fives. there the same measurments as our cars (i'm told)
http://tri-5.chevyrides.com/rear_tire.php
1956 GMC pickup
1952 Chevy hardtop
1932 Plymouth PB 3 window coupe
1940 Willys sedan
1964 Chevy II SS
1966 Pontiac GTO hardtop
Jeff
Edited by 18inchapes on 08-12-11 01:26 PM. Reason for edit: No reason given.
53belair
53belair
Reg: 03-25-07
08-12-11 04:49 PM - Post#2124973
    In response to 18inchapes
Once again I'd like to point out that those charts are giving a incorrect measurement for the second gen. camaro/firebird rear end. They are 61.5 inches, not 62.5
2010 Camaro II-SS
2012 Tahoe
Bill K.b
Loc: upstate NY
Reg: 10-24-05
08-15-11 01:40 AM - Post#2125763
I believe you will find the Bronco rearend the pinion is offset a little - one axle is shorter than the other.
1988 G20 conversion
JSanford1974
Loc: Warrior, Alabama
Reg: 08-26-10
08-15-11 06:55 AM - Post#2125829
I'm going to use a 94-2002 or so Ford Explorer rear axle in my 1953 Chevy. The axle has 31 splines, disc brakes, and a factory posi. Width is close to 60". And you can get them cheap at junk yard. The pinion is slightly offset, but I haven't found anyone who has had a problem with the axle.
I'm putting a cammed and carbed 2009 5.3 in my 1953 Chevy. I should be around 425 hp at the crank. I don't expect a problem with the axle.
18inchapes
18inchapes
Loc: Jackson, NJ
Reg: 10-18-08
08-15-11 01:05 PM - Post#2125962
    In response to JSanford1974
To my knowledge, Ford designed their rear with the offset pinion so the needle roller bearings in the universal joints for the driveshaft would rotate and not wear "flats" in them if just the universal rotated. Anyone else heard of that? Jeff
1956 GMC pickup
1952 Chevy hardtop
1940 Willys sedan
1964 Chevy II SS
Jeff
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
08-15-11 01:36 PM - Post#2125980
I just picked up a 8.8 out of a '92 Explorer today. It measures 59.5" and came with 3.73 limited slip. I also noticed the pinion is offset, it looks like about 2 1/2" to 3". This shouldn't be a problem should it? I also ordered the CE rear kit today so I'm pretty excited about getting this rear end in there and moving forward on this car.
Thanks for everyones help and input.
Edited by Sixshooter on 08-15-11 01:37 PM. Reason for edit: grammatical graffiti
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
08-15-11 02:58 PM - Post#2126022
I thought it was because they are 4wd.The shaft comes out of the transfer case,so they offset the rear end to get a straight shot.???????
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
08-15-11 03:10 PM - Post#2126026
    In response to Lead sled
I believe that is correct lead sled. I'm just wanting to make sure that there won't be any issue running it with this offset in my car. I have heard it is no issue, but I would just like to verify.
porters
porters
Loc: minnesota
Reg: 09-21-10
08-15-11 07:00 PM - Post#2126158
What about the strength of the Explorer,Blazer rear ends. The 9" will handle a 350, but will the Explorer and Blazer do the trick?
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
08-15-11 07:41 PM - Post#2126176
    In response to porters
I hear of a few guys running 8.8 rears that are running mid 10's and 11's with full slicks. Also, the explorer rears are 31 spline, I believe most others are 28. Pretty stout from what I'm told.
JSanford1974
Reg: 08-26-10
08-16-11 08:42 PM - Post#2126664
You are correct. Explorer axle is 31 spline, but some Rangers also have the 31 spline. Most Mustangs are centered (chunk) with 28 spline. I've heard the Mustang guys put hell on their 28 spline axle 8.8's. So if I come across one of them, I'll definitly buy it.
Loc: Hendersonville, N.C.
08-16-11 09:07 PM - Post#2126677
31 splines is not the sole measurement of a "stout", reliable 3rd member.
1951 Styleline Deluxe 2 dr sedan. 1955 235" 3 speed std.
1969 Corvair 500 Coupe 28,000 miles.
Member #51
08-17-11 05:34 AM - Post#2126774
    In response to bobg1951chevy
Well, after all the above discussions, let me jump in here and provide some comments on the 55-64 style rears (as though I've never said a word about them in the past ).
I know, I know, I know the 55-57 axle housings are becoming kind of scarce, but there are still plenty of them out there and it is one of the best options for converting a 49-54 Chevy to an open driveline.
Now first, let me preface this with 2 comments:
First, the 55-64 rears are perfectly fine, and plenty strong for any healthy SB in a car that is a street/driver/performance car-----------------I'M NOT TALKING HARD CORE RACING WITH STICKY SLICKS!
Second ------------ EVERYBODY seems to forget that this style rearend was used behind the 63-64 425hp/409 engines. And they only broke under excessive abuse conditions.
IF, IF, IF a 55-57 axle housing is used, the BEST CHOICE center section to use is the 60-64 posi. Or, if you can't locate a 60-64 posi center section, then at the very least install one of the new Eaton posi units in a non-posi rear.
It's true, all 55-64 axles are 17spline. Again, these axles were used in the 409 cars and did just fine as street drivers.
I have a 57 axle housing under the 51 Chevy that's been there since I converted it in 1967. The rearend center section that's in it is a 3.08 posi that came out of a 64. It's been there since late 70s behind a healthy 327, then a healthy 350 and now the 51 has a very healthy 383. I run 235/70R15 tires on 15x8 Corvette Ralley wheels and everything works just fine. I no longer do any serious clutch banging, but I often turn some serious rpm's. Last Sat when I was going to work on the plane, I was running with a late model Volvo on the Interstate at 110mph for about 8mi (surprised his a$$).
The 55-64 ring gears are 8.2, so certainly anything that size and larger would be a good choice to stick under a 49-54 Chevy.
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
08-17-11 05:54 AM - Post#2126782
Damn, you're good!
johnnymv1
johnnymv1
Loc: Phoenix, AZ
Reg: 04-15-11
08-17-11 08:10 AM - Post#2126838
Call me crazy but i want to change my rear end but still keep the 235, I just want a different rear end just in case one day i decide to convert over to a diffrent eng and trans setup plus it will be nice to drive this thin on the freeways and not worry about putting to much stress on the engine. so is it possible to change the rear end and still keep the 3 speed and 235?
Edited by johnnymv1 on 08-17-11 08:12 AM. Reason for edit: No reason given.
Member #51
08-17-11 08:31 AM - Post#2126852
    In response to johnnymv1
Johnny,
READ THIS CAREFULLY!
If you swap to an open rearend, then you will have to change EVERYTHING from the behind the engine. There IS NOT any kind of way that you can keep you existing bell housing and 3sp tranny. Your existing tranny ONLY connects to a closed driveline (torque tube).
You will have to change the tranny to one that connects to an open driveshaft. But, to be able to change to an open style tranny, you will also have to change the bell housing to a 55-62 style bell housing (or an early 50s truck housing). The bolt pattern for the tranny on the rear of the 54-earlier housing and the 55-later housing is totally different.
You can bolt ANY 55-later tranny to a 55-62 housing, such as a 55-later 3sp or 4sp. If you want to stay with a 3sp tranny, the 58-65 3sp is an excellent choice because it has a SHORT tail housing, AND, it has a tranny mount on the bottom of the tail housing. I pointed out the shorter 58-65 3sp specifically because it is easier to work with than the longer 55-57 tranny and because the 58-65 3sp has the tranny mount which makes it MUCH EASIER to adapt a tranny mount to the 49-54 cross member.
Now, my last comment.
THE 49-54 CHEVYS WERE NOT DESIGNED FOR THE INSTALLATION OF AN OPEN DRIVELINE!!! Thus, depending on what you go with, there WILL BE some fabrication required. THERE IS NO SUCH THING AS A DROP-IN, BOLT-IN CONVERSION TO AN OPEN DRIVELINE!!!
I did the conversion to open drive line on my 51 about 45yrs ago, and it was somewhat of a hassle then. Nothing's changed. Today, there are more rearend options to choose from than there was 45yrs ago, but modifications and fabrication is STILL required. I just don't want you going into the project thinking it will be a piece of cake!
 Page 1 of 3 123
Execution time: 0.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:01 AM
