Username Post: 91 4.3 timing specs??        (Topic#266560)
lizbeth
lizbeth
Loc: Az,desert rat
Reg: 06-22-03
07-23-11 07:46 AM - Post#2117090
Help please...I have a 91 s-10 4.3 automatic 2 wheel drive. Want to check the timing..My chiltons says "see the decal under the hood".No decal at all.This p/u has been around the block many times & also repainted.Cleaned & marked the damper,but with timing lite on=no show.Also once heard the dist plug in on back of dist must be unplugged?? Please let me know the right way to do this..
OLTYMERZ
Chevytech
Chevytech
Reg: 04-25-04
07-23-11 10:57 AM - Post#2117148
    In response to lizbeth
For the Small block TBI trucks, the timing specification is Zero degrees BTDC.
Here is some information I saved for a 1993 S/T truck.
Check and see if your truck is the same.
On 1993 V6 S/T trucks, to set the ignition timing, unplug the set timing connector. The timing connector breaks out of the wiring harness below the heater case in the passenger compartment on the passenger side of the firewall. It is a single wire connector with a tan wire with a black strip.
Image source
http://0.tqn.com/d/autorepair/1/0/Z/X/ 41927325.gif
07-23-11 05:21 PM - Post#2117246
    In response to Chevytech
Zero is the factory timing. Truck owner sometimes add up to 4 degrees for more power and efficiency. Any more timing requires a chip upgrade.
Here is more TBI information: http://www.cfm-tech.com/GM_tbi_tuning_tips.htm
'08 GMC Acadia 3.6L SLE
popcorn89
Reg: 12-22-10
07-24-11 08:33 AM - Post#2117413
the sticker is located on top of the radiator cover.
Execution time: 0.008 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:45 AM
