Username Post: stock cam specs        (Topic#260760)
starrunner
Loc: Castile,NY.
Reg: 09-06-10
04-06-11 08:34 PM - Post#2072994
Hi guys, I have a 2006 HHR 2.2 and I'm trying to find the stock cam specs and not having any luck.Would any body know what they are? Patriot has a ported & polished head with cams@ 192/178 dur. 242/235 lift @ .50 but not knowing stock specs how far is too far? I have seen cams at 201/197 dur.440/428 lift,210/212 dur. 423/419 lift.I believe these are for higher RPM ranges than street use. This is my daily driver and I didn't want to go to far with it.I do have a 2.4 intake manifold that I plan on using also with a Trifecta performance tune on the ECU.Any help would be appreciated. Thanks Ed..
bowtie67
bowtie67
Loc: Loudon, NH
Reg: 12-06-03
04-07-11 04:17 AM - Post#2073047
    In response to starrunner
Check out the Chevy cobalt forums as many of these guys modify there cars. Also a good spot for finding out what works and what doesnt, Patriot heads are a hit & miss for performance and before jumping the gun on the purchase see if anyone else is running that head with good results. As for that cam in my opinion looks more stock than a performance cam, Even comps XE252HR-11 which is there entry level would for the 2.2L be far better.
Execution time: 0.136 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:43 PM
