Username Post: 1978-83 chevy cruise control system        (Topic#256947)
CHimp66
Reg: 08-05-07
02-02-11 06:06 PM - Post#2041172
Greetings! I've been away from Chevytalk for a bit, but I have a 1978 Malibu Classic Landau I'm working on to make my daily driver. On a recent trip to the local Pull-A-Part, I pulled a cruise control system (transducer, hoses, brake wires, but no lever) from a g-body. Has anyone ever acquired a setup like this and made it work? Thanks!
02-03-11 05:23 AM - Post#2041362
    In response to CHimp66
You can make it work with all of the pieces. You may even be able to get the lever from a GM dealer still. But first you have to make sure that it is a GM unit. My '83 Malibu wagon had a dealer installed aftermarket cruise control on it when I bought it. I found that out when I went to replace the turn signal lever and found the plug on the end of the wiring harness didn't match the plug that was in the car.
1957 Cameo Carrier
CHimp66
Reg: 08-05-07
02-04-11 03:13 AM - Post#2041819
    In response to wagonman100
Ahh. I didn't think of that. Now, I can't even remember what car I pulled it from! I'll keep researching. I don't have to have this setup, but it sure beats buying an aftermaket setup for $200. Thanks!
55 Shaker
Loc: north central IL.
Reg: 03-13-06
02-05-11 01:38 PM - Post#2042395
Years ago 10/15? I put a tilt steering column and factory cruise set up in my 78 ElCamino out of a junk Malibu. It's been a few years and beers ago , but I remember it being pretty easy to do. Compared to messing around with magnets on the drive shaft, and chains on the throttle linkage, and splicing connectors and crap like that, that come with those aftermarket kits.
Randy_W
None
Reg: 01-06-02
02-08-11 05:38 AM - Post#2043525
    In response to 55 Shaker
The good aftermarket kits are very simple and easy to install, they're fully electronic, use a throttle cable and an inline speed sensor. No chains, no magnets. In fact I've been installing aftermarket kits for 30 years and I've never used one of those old chain/weights systems, looked way too trouble prone to me.
Randy
DON'T mess with Old Men, we didn't get old by being, STUPID!!!
"The veneer of civilization is very thin!" (Arlo)
CHimp66
Reg: 08-05-07
02-20-11 02:43 PM - Post#2049443
    In response to Randy_W
Well I plan to try it out, especially since I paid under $15 for everything (minus the cruise control lever) at my local Pull-A-Part!
TRIK-56
TRIK-56
Loc: Springfield, Mo. USA
Reg: 09-03-00
06-21-11 08:48 AM - Post#2106163
Randy,
Would you care to tell us the brand of cruise control you are talking about and where we could buy one?
My 82 El Camino has the factory cruise and works correctly about 10% of the time. I'm getting pretty sick of it!
Bobby
Execution time: 0.064 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:20 AM
