Username Post: Interesting swaps        (Topic#256024)
lifetime65
Reg: 04-14-10
01-17-11 03:37 AM - Post#2033067
When I was a kid I swapped a 231 v6 in my Vega. In the future I would like to pick up another one and build a sporty econo car. I was thinking Quad 4, aluminum 5.3 or ?. Any ideas? The new Camaro get 28 mpg with 400 hp, I would like to find a setup that will get 40+.
hoffbug
hoffbug
Loc: Maplewood,MN
Reg: 12-29-00
02-07-11 06:40 PM - Post#2043407
    In response to lifetime65
Buick or Olds 215... with an overdrive transmission like a 200R4
You can sleep in your car but you cant drive your house
Tony H 72 Malibu 11.38 ET
Mike McVeigh. Not forgotten
models916
Loc: Addison, IL
Reg: 05-28-10
02-08-11 09:27 AM - Post#2043640
    In response to hoffbug
I bought Hot Rod and Super Chevy this month. One of them has a Vega with a LS engine. Nice neat install.
hoffbug
hoffbug
Loc: Maplewood,MN
Reg: 12-29-00
02-09-11 06:30 PM - Post#2044449
    In response to models916
Google.. The Flying turd vega...
Randy_W
None
Reg: 01-06-02
02-25-11 04:35 PM - Post#2052069
I swapped a 455 Pontiac into my '76 Olds Starfire, the engine was almost a bolt in on the 231 mounts. The wrapped wire Pinto steering shaft was used to around the left side exhaust. Never saw another H-body with a Pontiac engine, although I know a few were done.
Randy
DON'T mess with Old Men, we didn't get old by being, STUPID!!!
"The veneer of civilization is very thin!" (Arlo)
txturbo
Loc: Rosenberg,TX USA
Reg: 07-27-01
04-27-11 02:55 AM - Post#2082588
I just started another Vega. This one is getting a 96 Camaro 3800 Series II motor with a 4L60E transmission. Just want to make a nice, fun cruiser out of this one. 205hp should make it fun to drive and keep the weight down on the nose.It should also get pretty good mileage. This combo got upper 20s in the camaro and the Vega is probably 1200 pounds lighter.I also bought an S10 frame for the front spindles/brakes and rearend to swap into it.
Dan
1969 Camaro SS 396/T400
1966 Impala 283/PG/AC
1966 Impala SS 427/4 Speed
1948 Panel 1 Ton
1963 Cadillac
1940 Ford P/U
1954 Chevy 3100
1955.2 Chevy 3100
1956 Cadillac CDV PINK
1930 Model A hot rod
Execution time: 0.143 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:01 PM
