Username Post: steering lock        (Topic#254539)
rockvette
rockvette
Loc: South Texas
Reg: 02-09-10
12-18-10 07:06 PM - Post#2019959
I just got a " service steering lock" on my odmoter screen. It shuts the gas off and won`t let the car move. Is there any fixes to this problem.It`s on a 2002 vette
Edited by rockvette on 12-18-10 07:10 PM. Reason for edit: No reason given.
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
12-19-10 12:19 AM - Post#2020056
    In response to rockvette
FROM WHAT I REMEMBER READING ,THAT SHOULD OF BEEN TAKEN CARE OF UNDER A RECALL,INQUIRE INFO FROM YOUR NEAREST DEALER.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
TAT_2
TAT_2
Reg: 10-29-00
12-19-10 02:06 AM - Post#2020069
    In response to TAT_2
http://www.corvetteactioncenter.com/forums/c5-tech...
U COULD READ THRU THEM,I HAD A FEW MINUTES SO I SEARCHED IT UP
I MAY EVENYUALLY STEP ON UP TO A C5,SO I KINDA READ UP ON EVERYTHING I CAN ON EM,LUCKLY MY MEMORY RETENTION IS STILL FAIRLY GOOD 4NOW
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
hotwheels57
hotwheels57
Reg: 11-20-02
12-19-10 09:23 AM - Post#2020142
Go to the C5 Tech sub forum at corvetteforum.com and use the "search" or "search this forum" (in the red banner). Use keywords "clb" or "column lock bypass".
http://forums.corvetteforum.com/zeromain
That forum never deletes any technical threads from the archives. There's probably 10,000 past threads on this topic. There's more than one manner to handle this. The most common DIY modification is called a "clb". Basically it's an electronic device that tricks the computer into believing the column lock is still functioning, but it has been disabled.
The dealership may or may not still repair your car under warranty. They use a different approach to the issue. The GM VIS (vin check of past GM services) may reveal it's already been done, and it's failed. There have been two to three variations of the GM offered solution, so make sure you get the most recent if you chose to use the dealership.
If you chose not to use the dealership, you can buy the after market column lock bypass and install it yourself. You cannot install a "clb" until you release the steering wheel lock though. The link below is long, but it'll describe what you can DIY to possibly break the steering lock free temporarily until you install the "clb". The device is available through several after market sources, but the most popular source is CORVETTES OF HOUSTON, at approx. $50.00.
http://forums.corvetteforum.com/c5-tech/1015483-st...
Karma is the universal equalizer. The Ignore User feature comes in a close second.
Edited by hotwheels57 on 12-19-10 09:24 AM. Reason for edit: No reason given.
duals
Reg: 03-30-11
03-31-11 01:48 PM - Post#2070013
    In response to hotwheels57
i have this bypass on my 99 for years and I have had no problems
o2bnkc
Loc: Carson City, Nv.
Reg: 03-29-13
03-30-13 12:35 AM - Post#2330924
    In response to duals
The recalls that the dealers did was just a temporary fix. Like the previous poster said, get a hold of Corvettes of Houston and get that device to fix the problem for good.
A Proud Navy Vet
Execution time: 0.177 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:59 AM
