Username Post: removing hatch        (Topic#252897)
59imp
Reg: 07-14-09
11-18-10 12:05 AM - Post#2005873
i have to remove the rear hatch of my Astre to weld one of the hinges back on. anyone got any tricks? i heard it's a real pain and it's hard to remove the spring mechanisms from the hatch...
any tips???
bowtieollie
bowtieollie
Reg: 12-06-99
11-19-10 06:18 PM - Post#2006665
    In response to 59imp
Hi 59,
Yes there is a trick.
Get some 1/2" rod and you want to drill one end.
The purpose of drilling the end is to create a smooth crater.
This crater will center on the hatch pin which is pointed.
Get a coat hanger straighten it out, then place some strategic bends in the coat hanger.
It will look like an "S" when you are done.
Heat the 1/2" rod and bend it to mirror the coat hanger.
Now, a nice 2lb hammer and your newly fabricated "special tool" will knock the pins out in no time.....
Good luck and watch that hatch - they are heavy!
Bowtieollie
Chevytalk.com Moderator
59imp
Reg: 07-14-09
11-23-10 05:02 PM - Post#2008659
    In response to bowtieollie
that's a good tip thanks, what about the hatch springs, i heard they're under a lot of tension? is that true???
bowtieollie
bowtieollie
Reg: 12-06-99
11-25-10 06:25 AM - Post#2009253
Hatch Springs??
There are gas struts that hold up the hatch.
Yes, there is pressure 'in them" but removal is done with the hatch open.
TIP:
Block the hatch open with a wooden stick
Remove the struts BOTTOM first. Less chance of damate to the paint/window this way.
Then remove the strut from the hatch.
Better have a helper when you remove those pins,
The hatch is rather heavy.
Bowtieollie
59imp
Reg: 07-14-09
11-29-10 02:18 PM - Post#2011188
ya there is a spring mechanism on the early Vegas, then they went to the struts. i wish you had mentioned there was a clip that helt the hinge pins in place, i bent them quite badly trying to pound them out, i thought they were just rusted in...live and learn......
bowtieollie
bowtieollie
Reg: 12-06-99
11-29-10 06:02 PM - Post#2011320
Its not a special clip...it just a C clip.
What year Astre are you working on???
Bowtieollie
59imp
Reg: 07-14-09
12-03-10 01:50 AM - Post#2012860
it's my black 73 from my earlier post. some rust developed under the hinge and a couple of the spot welds came loose. now sometimes the hatch comes unlatched while driving, mostly under cornering.
Execution time: 0.141 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:44 AM
