Join the Community today
Username Post: Really Thick gear Lube        (Topic#249403)
Oldengineer
Loc: Cross Lanes, WV
Reg: 08-16-10
09-17-10 09:24 PM - Post#1977572
I finally got around to pulling the differential fill plug on my recently acquired 48 Fleetmaster. THe differential was full, but, the gear lube in it is really thick - about the consistency of thick molasses. It has almost no odor and there's no sulfur smell at all. Now I'm wondering what the stuff is, and, what I should do with it.
Regards:
Oldengineer
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
09-18-10 09:28 PM - Post#1977920
    In response to Oldengineer
Drain it out. Then add a quart of 85W140, spin things around to flush and drain and refill with 3 1/2 pints of 85W-140 (can use #90 if you wish.
I would drin the transmission also and use the 85W-140 for sure in it. It helps to chushion the gear rattle (clutch chatter) when hot.
Oldengineer
Reg: 08-16-10
09-19-10 07:38 PM - Post#1978311
    In response to Gene_Schneider
Gene:
I put a fresh load of 85-90 in the tranny, and, it seems to be doing fine. The rear end, I suspect, is full of 600 weight gear oil. I'll try your suggestion on it, and, put in 85 - 140 in.
Regards:
Oldengineer
Edited by Oldengineer on 09-19-10 07:39 PM. Reason for edit: No reason given.
Road Runner
Road Runner
Loc: CA Mountain Desert
Reg: 02-07-07
09-26-10 04:08 PM - Post#1981156
Only use GL-4 rated gear oil in your synchro-mesh transmission.
Avoid GL-5 gear oil. It has twice the amount of sulfur/phosphorous additive, which will slowly peel off the surface of the brass parts.
You can confirm this, when you drain GL-5 oil after some use and the oil looks like thick metallic copper paint in direct sunlight.
GL-4 rated gear oil is a little harder to find these days.
I get this one from the NAPA store: Gear Oil - Automotive, 85W90; 1 GAL
I also use this for my rear end, although GL-5 would be alright, since there are no yellow metal parts.
Transmission and differential oil should be changed anually, especially in colder and damper climate zones.
On the road every day ...
1948 Coupe
1952 Truck
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
09-26-10 11:28 PM - Post#1981330
    In response to Road Runner
Made sticky!
Sawtooth0645
Sawtooth0645
Loc: Colorado Front Range
Reg: 10-02-10
05-01-11 10:56 AM - Post#2084493
Oldengineer-
I am about to do the same thing to my diff, but wondered what it would take to get the old thick stuff out. Did you have to do anything special to drain something the consistency of thick molasses?
49Stovebolt
Loc: NE Florida
Reg: 11-27-12
11-28-12 11:26 AM - Post#2293080
It may be STP
Road Runner
Road Runner
Reg: 02-07-07
05-17-13 04:57 PM - Post#2346493
Pennzoil came out with a special Synchromesh fluid...
Pennzoil Synchromesh Transmission Fluid
It's mineral oil based like the old-time fluids and much thinner compared to 85W-90 GL-4 fluids.
It's rated SAE 80 - Not ideal for the summer months, but great for cold temps, with easier shifting, especially after a cold start.
1948 Coupe
1952 Truck
LRH
Loc: USA
Reg: 10-27-08
05-17-13 05:35 PM - Post#2346504
The GL-5 lube with GL-5/MT-1 uses different additives VS more sulfur so they are compatible with yellow metals. MT or MT-1 alone do not meet spec, and GL-5 won't, it has to meet and be labeled GL-5/MT-1. Some synthetic manual trans lube have the large letters MT on the container not to mislead, but to signify it is for manual trans. Just offered this in case some are not finding GL-4.
Road Runner
Road Runner
Reg: 02-07-07
08-01-14 11:38 AM - Post#2473567
WARNING !
Do NOT use the PENNZOIL SYNCHROMESH MANUAL TRANSMISSION FLUID I mentioned in my last post, especially in the summer months.
It is too thin/light.
I just called the Pennzoil techline and they also don't recommend it and said to either use GL-4 mineral oil or even better GL-4 synthetic oil.
1948 Coupe
1952 Truck
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
08-01-14 08:11 PM - Post#2473654
    In response to Sawtooth0645
  • Sawtooth0645 Said:
Oldengineer-
Just pull the bottom bolt holding the cover in place, place a pan under it and let gravity take its course.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
Road Runner
Road Runner
Reg: 02-07-07
08-02-14 07:12 AM - Post#2473722
I posted the same info on another forum and somebody recommended against using synthetic base fluid ...
"... I'd be cautious of using full synthetic lube in an older trans with brass blocker rings. The extra slippery lube can make it difficult for the brass rings to get the needed "bite" on the synchronizer hubs. You might end up with some gear clash even on a new or freshly rebuilt transmission. The increased slipperiness of the synthetic fluids, while beneficial for most of the transmission, actually over-lubricates the older style synchronizers."
1948 Coupe
1952 Truck
Execution time: 0.071 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:46 AM
