Join the Community today
Username Post: 39 engine removal        (Topic#248626)
MajesticsCanada
MajesticsCanada
Loc: Surrey, B.C., Canada
Reg: 08-27-06
09-03-10 12:54 PM - Post#1971108
Do i need to take the whole front end and fenders off of my 39 to remove the engine, or can it be done all together or partially together?
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
09-04-10 12:21 AM - Post#1971326
    In response to MajesticsCanada
I had a look at the online at the '38 online manula and it does not mention. This is what the '41 manual says
http://chevy.oldcarmanualproject.com/shop/1941/41c...
Can anyone help here please?
Pistol
"19th Year" Silver Supporting Member
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
09-04-10 04:18 AM - Post#1971350
Worked a little on 39 Chevys and it's tough getting in there, I know you will have to take the hood and hood hinge bracket off which will need to come off even if your going to be removing the nose, as for taking the whole nose off you might be in better shape doing it that way
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
09-04-10 07:19 AM - Post#1971389
    In response to Pistol
Hood and core support removal would be necessary....if it were mine I would just lift off the entire front clip as a unit. That would require the removal of the least (rusted) bolts.
kunk
kunk
Loc: Raleigh NC, USA
Reg: 01-07-01
09-04-10 06:11 PM - Post#1971581
On my `38 I removed the front dog house (holds the grille/radiator. I removed the hood and basically let the front fender droop outward. It was much easier this way. Pull the trans with the engine as a unit. You can basically slide everything in straight and it goes pretty fast.
Kunk.
1957 Belair 2door Hardtop
Looking for 1937 Chev. PU
Looking for 1937 Chev. Coupe
Looking for 1965 Impala 2drhdtp
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
09-04-10 11:19 PM - Post#1971661
    In response to kunk
I am making this sticky as it might be useful in the future.
bob70
Reg: 06-25-06
04-19-12 07:25 PM - Post#2217113
    In response to David Hayward
Can someone please tell me how to access the rear hood attaching point at the cowl on a 38 sedan? I need to remove the hood and can't find a way to get to the fastener holding the center hood rod in place at the rear. I'm hoping I don't have to come at it from underneath the dash. Much clutter under there.
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
04-20-12 11:07 AM - Post#2217287
    In response to bob70
I would leave the rear hood attaching plate in place and loosen the nuts on the rods that support the radiator under the dash. Then you can pull the front sheet metal forward, to pull the hood center rod out of the holdown.
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
bob70
Reg: 06-25-06
04-20-12 11:59 AM - Post#2217301
    In response to Rustchips
Thank you, 233. Good idea. I'll have a look soon with the idea of doing as you suggest.
Execution time: 0.299 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:34 AM
