Username Post: starting        (Topic#247844)
rockvette
rockvette
Loc: South Texas
Reg: 02-09-10
08-20-10 11:29 PM - Post#1964285
Will not start on first try.I have a 2002 but will not start on the first try , but will on second try.Any one ever had this problem. Can`t seem to figure it out.
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
08-21-10 07:52 AM - Post#1964365
    In response to rockvette
Never heard of this, but maybe somone that has will chime in...have you checked the fuel pressure? If it takes a minute to build up there may be an issue there..... No codes??
Hey T @!
Joe
rockvette
rockvette
Loc: South Texas
Reg: 02-09-10
08-23-10 10:21 AM - Post#1965544
    In response to wagonmaster
There is no codes. Runs fine after it starts,good idle. Can`t figure it out. Turn key for a minute than try no luck.
Edited by rockvette on 08-23-10 10:24 AM. Reason for edit: No reason given.
hotwheels57
hotwheels57
Reg: 11-20-02
09-12-10 09:22 AM - Post#1974909
Fuel or ignition...fuel pump, fuel filter, fuel lines, fuel pump relay, injectors? Fouled plugs, plugs worn w/ to much gap, to much resistance in the old plug wires?
Try posing your question in C5 Tech at corvetteforum.com
Karma is the universal equalizer. The Ignore User feature comes in a close second.
o2bnkc
Loc: Carson City, Nv.
Reg: 03-29-13
03-30-13 12:29 AM - Post#2330923
Can you hear the fuel pump come on before you turn the key all the way over?
A Proud Navy Vet
Execution time: 0.219 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:32 PM
