Username Post: transmission problem        (Topic#247089)
boureau
Reg: 08-08-10
08-08-10 07:05 PM - Post#1957767
could someone help me. My camaro is equiped with a TH350C, was stopped for 7 years, and the tranny stood without fluid for this period, i have now filled with new fluid and tryed to run it, but it will only engage on revese, none of the forward gears are working. What could be the problem?
Randy_W
None
Reg: 01-06-02
08-09-10 06:22 AM - Post#1957927
    In response to boureau
I would suspect either something in the valve body clogged or dried out seals and o-rings. You should have left fluid in it. I would put some tranny treatment for seals, etc... in there, run the engine and shift it through the gears, working or not a few times, then let it idle until warm, then shift through the gears some more. Repeat over a few days and see what happens, but it may require disassembly, clean up and re-seal.
Randy
DON'T mess with Old Men, we didn't get old by being, STUPID!!!
"The veneer of civilization is very thin!" (Arlo)
Execution time: 0.156 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:07 PM
