 Page 24 of 25 « First<22232425
Username Post: What did you do to your truck today?        (Topic#235250)
rcr3
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
02-01-16 08:51 AM - Post#2605898
    In response to hilandr451
Looking forward to seeing the finished product!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
hilandr451
Moderator & "11th Year" Gold Supporting Member
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
02-02-16 11:18 AM - Post#2606187
    In response to rcr3
I mocked up a few boards just to see what it will look like.
I looked on one of the boxes the wood came in and noticed the shipping date. I've had this stuff laying around for 9 years!
Attachment: 20160131_113322.jpg (2.57 MB) 323 View(s)
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L,
1966 C20 Custom Camper "Rattle can primer red" 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
Chevy_Stepside
Chevy_Stepside
Loc: San Francisco, Ca, USA
Reg: 07-08-02
02-02-16 07:10 PM - Post#2606303
Well then you saved some cash. I am thinking it was a lot cheaper 9 years ago.
"A man and his truck, It's a beautiful thing"
The tour is on again. May 1st 2011. $5 I ride 100 miles. http://main.diabetes.org/site/TR?pg=personal&a mp;f...
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
02-06-16 07:20 AM - Post#2607004
    In response to Chevy_Stepside
Yeah, no kidding! I just visited Mar-K's site $100.00 more today. Same with the moldings. In 2005 I priced them at just under $400.00. Today they're asking $495.00. Good quality stuff though!
-The Hilander.
Project Pics
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
02-06-16 11:11 AM - Post#2607045
but the interest that you lost on your money over that time more than likely equals out
ron
http://www.sawmillcreek.org/showthread.php?208929-...
http://www.sawmillcreek.org/showthread.php?220902-...
http://forum.woodenboat.com/showthread.php?156542-...
Edited by sidworks on 02-06-16 11:11 AM. Reason for edit: No reason given.
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
02-06-16 11:18 PM - Post#2607177
And now the fun starts! I think I got my mileage out of those original boards!
two words: "square nuts" @#&*/!!!!
Attachment: 20160206_142251.jpg (2.86 MB) 340 View(s)
Attachment: 20160206_151703.jpg (2.46 MB) 347 View(s)
-The Hilander.
Project Pics
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
02-06-16 11:33 PM - Post#2607178
One side and one wheel tub off, work resumes on tearing down the rest of the bed.
More cutting and grinding....
....and grinding and cutting.
Attachment: 20160206_182911.jpg (434.63 KB) 350 View(s)
Attachment: 20160206_182941.jpg (535.99 KB) 307 View(s)
Attachment: 20160206_182959.jpg (507.42 KB) 354 View(s)
-The Hilander.
Project Pics
Edited by hilandr451 on 02-08-16 06:59 AM. Reason for edit: No reason given.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
02-26-16 08:00 AM - Post#2611589
I took my windshield out so I could change the rotten gasket. It actually turned back to petroleum form. What fun that was to clean out. Also there wasn't any rust (except surface rust) like some Know it all tried to tease me with as I knew there wasn't any. Had to get rid of that tar at the top. I have a feeling this truck was kept indoors. Since the gasket melted it protected all the metal underneath. I also coated the lip with Duplicolor Bed Coating. Should be good for along time.
Look Ma... Or should I say Greg. NO rust. hahahahahaha
Coated.
Vaughn
Member #455 "15th Year" Gold Supporting Member
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
02-26-16 03:02 PM - Post#2611679
You should use an epoxy seam sealer on those spots. It is designed to seal up places where the panels overlap or on welded seams. Get a type that has UV resistant chemicals.
Bed liner is fine in it's intended application, but it isn't as good where seams are. It can tend to trap moisture at the seam, which causes it to rust out, instead of protecting it from rust which is why most people do this in the first place.
To use bedliner in an application (like underneath the cab), it first must have a primer (like an epoxy primer) applied, and it must be carefully prepped so that rust doesn't form (use a metal rust killer of some sort). It isn't designed to be used it in the way you are trying to use it.
Epoxy primer also accepts paint more readily. If you want to use bedliner, it needs to be tinted to match your color, because you can't really pain over it successfully. The bedliner will probably cause the color to flake off, because it tends to skin over hard enough that paint won't stick to it. Bedliner is supposed to be resistant to chemicals, so painting over it and expecting a chemical bond to form will result in paint failure.
Seam sealers are specifically designed to protect seams, and if you get the right type of seam sealer, that will include exposure to UV rays/weather. Two part (all epoxies are at least two part, otherwise it isn't an epoxy) epoxy seam sealer will set up so that it is extremely strong, difficult to remove and will prevent rust from forming. This is especially important in the drip rail on our trucks, they have seam sealer in them from the factory. Seam sealer has advanced a LOT since they used it in the 60-66 trucks, and it is more capable now to handle that kind of constant exposure to weather and resisting rust.
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
03-04-16 06:50 PM - Post#2613101
    In response to Vaughn
Been buisy!
Got the cross braces cleaned and coated with POR15. I started working on the wheel tubs.
Kinda ran out of daylight tonight but Mrs. Hilander and I managed to get everything started. All the cross braces are attached and the bed is bolted to the frame.
Attachment: 20160220_182145.jpg (2.33 MB) 312 View(s)
Attachment: 20160304_192635.jpg (3.2 MB) 301 View(s)
-The Hilander.
Project Pics
rcr3
rcr3
Reg: 11-24-02
03-07-16 08:37 AM - Post#2613677
That's looking good!!
'67 Camaro survivor
'74 Nova Custom cp.
'17 Chevy Trax LT
'00 S10 Ex cab
Woogeroo
Woogeroo
Loc: what does this part do?
Reg: 05-26-02
03-07-16 08:41 AM - Post#2613679
  • hilandr451 Said:
Been buisy!
Looking good hilndr!
-W
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
03-10-16 03:44 PM - Post#2614457
    In response to Woogeroo
Gearing up for a productive weekend! My brother in law, my son in law and I are going to team up for a big push! Hopefully get the Bed sides and the tubs cleaned, pounded out and POR-15'ed. We're also going to fit the aux fuel tanks to the bed and start on cleaning those up and mounting them with sending units.
-The Hilander.
Project Pics
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
03-12-16 10:53 PM - Post#2614959
Passenger side bed - cleaning rust and dirt, pounding out dents and straightening sheet metal.
Front panel needs lots of help. All I could do was straighten it out, clean the rust off the bottom edge POR15 the mating surfaces and get it ready to assemble. I ordered a new one from Classic Trucks but it's got a 3 week lead time.
I started on the saddle tanks. I'll get them fitted tomorrow.
Driver's side cleaned and ready to POR15 the mating surfaces.
Got the tubs pounded out and cleaned up.
Now everything gets de-greased, pressure washed, treated with"metal ready" and POR15'ed.
Attachment: 20160312_144431.jpg (1.64 MB) 358 View(s)
Attachment: 20160312_144443.jpg (2.32 MB) 349 View(s)
Attachment: 20160312_144521.jpg (2.65 MB) 304 View(s)
Attachment: 20160312_144603.jpg (2.2 MB) 311 View(s)
-The Hilander.
Project Pics
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
03-14-16 07:12 PM - Post#2615441
Test patch on the tailgate. A preview of what the rest of my 66 will look like.
Attachment: 20160314_181634.jpg (2.54 MB) 318 View(s)
Attachment: 20160314_181615.jpg (2.39 MB) 306 View(s)
-The Hilander.
Project Pics
Woogeroo
Woogeroo
Reg: 05-26-02
06-13-16 03:08 PM - Post#2633728
gas tank filler hose & filler neck replacement - 1965 C10
-W
wyome
wyome
Loc: Castle Rock CO
Reg: 09-22-08
08-06-16 10:07 PM - Post#2644161
I didn't actually do anything to it, but I did talk to a guy who has a small shop who will assist me on some things, and take lead on a few things to finally help me get Funky back on the road sooner, rather than my later....
David E.
1964 Chevy C-10, Stepside, Longbed Sportin' a 283ci V-8
Woogeroo
Woogeroo
Reg: 05-26-02
08-14-16 07:48 AM - Post#2645604
    In response to wyome
spray painted the wheels and rear bumper, knocked the dirt and grime off a bit and pressure washed the bed wood :
08132016 – exterior, engine, interior
-W
Woogeroo
Woogeroo
Reg: 05-26-02
04-24-17 01:20 AM - Post#2687992
Howdy 60-66 folks,
so, after diagnosing charging issues... ordering and installing a new voltage regulator...
I had to replace my heater core again, so I took lots of photos.
Here is the latest tech article if you are interested in checking it out.
04/19/2017 – heater core replacement - 44 pictures
Happy Wrenching,
-Woogeroo
Darren65
Darren65
Loc: Escondido CA
Reg: 11-10-16
04-24-17 04:31 PM - Post#2688111
MadDog made its first appearance at Cruising Grand in Escondido California! Always a great time and felt good getting it out for the on lookers!
Attachment: 20170331_200744.jpg (3.03 MB) 99 View(s)
Attachment: 20170331_200815.jpg (2.92 MB) 87 View(s)
1965☆Chevy-Man C20 3/4Ton Fleet-side long bed Red/White MadDog
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
04-26-17 09:26 AM - Post#2688336
    In response to Darren65
nice looking '65!
I love those saddle tank doors - I have those on mine as well (dealer installed saddle tanks) I am looking for a pair of chrome doors to replace my painted ones. are yours chrome if so where did you find them?
-The Hilander.
Project Pics
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
04-26-17 12:33 PM - Post#2688364
Check these out. http://www.tanksinc.com/index.cfm/page/ptype=produ...
Darren65
Darren65
Loc: Escondido CA
Reg: 11-10-16
04-27-17 07:53 AM - Post#2688491
They are chrome. Bought the truck this way.
Darren65
Darren65
Loc: Escondido CA
Reg: 11-10-16
04-27-17 07:55 AM - Post#2688492
I actually dont even use that tank. Just the behind the seat tank. The original owner that i bought the truck from said he has never used the side tank and probably wouldnt be a good idea unless i replaced it or cleaned the old one out.
Woogeroo
Woogeroo
Reg: 05-26-02
08-12-17 10:34 PM - Post#2703959
In the past month or so :
had new exhaust put on by the professionals.
had a oil leak with the nylon hose for the PSI gauge, the hardest part of fixing that was getting to it, it is next to the distributor on a SBC and sorta under that indented area in the firewall.
( NOTE : thanks for the tip, Vaughn)
Noticed the diff. was leaking, I *think* from the gasket cover... so I replaced it today, still have to top off the fluid. The instructions on the goop box said to let cure for 24 hours... so here are a few in progress action shots:
Today :
3 pics - rear axle differential gasket cover replacement - in progress shots
Happy riding and wrenchin' folks,
-W
Eric_Gary132
Loc: northern California
Reg: 01-27-17
08-13-17 06:56 AM - Post#2703978
I gave it a big hug and let it know about my current lack of knowledge on fixing it and cars in general.
Also I'm still trying to figure out what gender it is. I'm still looking. maybe I will even lift its tailpipe under there or check its rear axle to find out.
I hope my truck is a girl. A sexy girl. Which I think we can all agree that our trucks are.
i guess i'll name it after the girl who used to own the truck.
Edited by Eric132 on 08-13-17 04:51 PM. Reason for edit: No reason given.
Woogeroo
Woogeroo
Reg: 05-26-02
10-09-17 12:06 AM - Post#2710238
    In response to Eric_Gary132
updated my truck site with project photos this weekend :
07/30/2017 – 8 pictures
painted the original type under the bed spare tire holder and mounted it up
08/12/2017 – 3 pictures
replaced the gasket and the goop on the rear differential cover and changed the rear end gear fluid/dope.
-W
rocknrod
Loc: China Spring, TX
Reg: 04-27-15
10-09-17 07:04 AM - Post#2710275
I sure miss Escondido, I used to live there. Knew Randy at HR&CS pretty well and was in the OTHG back in the day.
Master Chief, US Navy, Retired
64 C10 Short bed Step Side
Darren65
Darren65
Loc: Escondido CA
Reg: 11-10-16
10-09-17 05:05 PM - Post#2710331
    In response to rocknrod
Nice. I do have to say HR&CS is not a go to place around here no more. They are known for gouging coustomers and not looking out for fellow hotroders!
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
11-22-17 07:06 AM - Post#2715309
Birthday present back in June (I'm a little slow on the up-take) New 3 core aluminuminumn radiator with a big electric fan!!!!
Runs nice and cool now! When we yanked the original we thought it must be full of sand because it weighs at least 25 lbs.
Attachment: 20170612_192551.jpg (414.67 KB) 89 View(s)
Attachment: 20170612_192640.jpg (345.88 KB) 78 View(s)
Attachment: 20170612_192644.jpg (324.35 KB) 80 View(s)
-The Hilander.
Project Pics
Execution time: 0.142 seconds.   Total Queries: 24   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:15 AM
