 Page 25 of 25 « First<22232425
Username Post: What did you do to your truck today?        (Topic#235250)
hilandr451
Moderator & "11th Year" Gold Supporting Member
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
11-22-17 08:08 AM - Post#2715310
    In response to hilandr451
Then I took her fishing.....
Attachment: 20170504_184148.jpg (474.92 KB) 73 View(s)
Attachment: 20170504_184207.small.jpg (418.22 KB) 68 View(s)
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L,
1966 C20 Custom Camper "Rattle can primer red" 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
Chevy_Stepside
Chevy_Stepside
Loc: San Francisco, Ca, USA
Reg: 07-08-02
11-27-17 10:17 PM - Post#2716034
I installed the OD trans last week and today picked up the driveshaft and will install it tomorrow (Tuesday) and take it on a test drive.
"A man and his truck, It's a beautiful thing"
The tour is on again. May 1st 2011. $5 I ride 100 miles. http://main.diabetes.org/site/TR?pg=personal&a mp;f...
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
12-05-17 12:14 PM - Post#2716958
    In response to Chevy_Stepside
Hey remember how my spedometer was always reading real high? Remember how I was holding off buying a set of speedo gears until I had the 4:10 diff I wanted?
Well, after we put that diff in that I bought from you - the speedo is spot on! I'm guessing that the van that the 700r4 came out of had a 4:10 in it too.
The thought had occurred to me that might be the case, but I never "luck-out" like that so I dismissed it. What a pleasant surprise!
-The Hilander.
Project Pics
DECEASED
12-05-17 12:38 PM - Post#2716962
You have just discovered on your own one major advantage to being a pessimist. Pessimists are never disappointed, and occasionally they are pleasantly surprised.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
12-05-17 02:14 PM - Post#2716968
Damn. That should be worth an extra $100. You know where to send the check.. I am going to go install my new pull cable now for my trans.
Edited by Chevy_Stepside on 12-05-17 02:15 PM. Reason for edit: No reason given.
DECEASED
12-06-17 12:37 AM - Post#2717033
What kind of cable did you get for your OD?
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
12-06-17 09:30 AM - Post#2717059
Just an aftermarket cable from Dorman. I installed it to the dash so far. I just didn't feel like crawling under the truck yesterday.
Edited by Chevy_Stepside on 12-06-17 09:33 AM. Reason for edit: No reason given.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
12-06-17 03:00 PM - Post#2717095
Hooked up. Now I just have to replace my headlights. I also found the other fill plug and filled the back of the trans up.
Edited by Chevy_Stepside on 12-06-17 03:01 PM. Reason for edit: No reason given.
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
12-08-17 04:49 PM - Post#2717339
    In response to Eric_Gary132
  • Eric_Gary132 Said:
-I stuck a wrench up it's tail pipe for giving so much issues with shifting through the gears.
I'm also thinking about stickig a zbar up it's tailpipe as well.
ooh key then....
Welcome to working on old trucks!
-The Hilander.
Project Pics
Woogeroo
Woogeroo
Loc: what does this part do?
Reg: 05-26-02
12-10-17 09:02 PM - Post#2717527
The other day I swapped out my voltage regulator and when I went to put the battery cable back onto the battery post, the clamp broke as I was tightening it.
Today was change the battery cable day, which involved me having to drop the starter, so yay that I had it up on the ramps.
Broke the little solenoid wire, fixed that, got the new cable snugged down and routed. Bolted starter up, hooked up battery cable, lights and radio came on, electric fuel pump was humming and then no starter action.
now what?
After checking and troubleshooting several things, I realized that somehow I put the small solenoid wire on the wrong post.
jeez. I think maybe I should stop working on things. haha.
Got that swapped over, put battery cable back on and hit the switch : vrooom!
Yay.
Happy Wrenchin' everyone.
-W
Micmac
Micmac
Reg: 07-06-10
12-17-17 05:29 PM - Post#2718296
    In response to Woogeroo
Brought her to the body shop for a frame off rotisserie full resto. I want it right when I leave her to my son. I will keep you posted.
1947 Indian Chief
1963 Chevy C-10 Fleet Side
1982 Harley Davidson FXR
2003 GMC Sierra 1500 Z71
2012 Indian Chief Vintage Serial #002
2012 Camaro SS Convertable
2016 Silverado High Country 2500 Diesel
Sparta, N.C./Calais, ME.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
12-23-17 05:22 PM - Post#2718886
I finally took the ugly brown seat cover off the back of the seat today. I am so thankful that they didn't remove the original cover. Had to clean the seat for it just to look like it dose now. Is there anyone out there that makes seat covers like this? Too bad the bottom seat is all ripped up. I want to remove that one also but need something to put over the ripped part. It is better then they ugly brown cover..
I also installed new mirrors. The driver mirror rusted off and the right one just fell off.
Woogeroo
Woogeroo
Reg: 05-26-02
03-27-18 02:54 PM - Post#2729133
'65 C10
was on the way to work last night and noticed the blinkers blinking slowly, so electrical system...
checked it out today, no charging from the alternator... found a broken wire going to the alternator... jumped it with a wire and some alligator clips, suddenly charging. ok... a broke wire, I can fix.
So, new butt connector and all is well again.
old trucks are fun.
-Woog
Woogeroo
Woogeroo
Reg: 05-26-02
04-09-18 01:15 PM - Post#2730473
There was a small wire that went from the voltage regulator to the back of the alternator that broke, again. I decided to solder it together this time. So... heated up both ends, dabbed a little solder... then shaped 'em in a hook, then hooked 'em together... heated 'em up together, dabbed a bit more and ta da. Then I heated up the shrink wrap to cover it up nicely.
While I was there, I decided to do the other wire as well... that part went pretty well.
Then I was putting the battery cable back on and noticed the clamp was broken... again. Back to the parts store! I bought a replacement clamp instead of the entire cable... cut the overly long cable to length and put the replacement clamp on.
It's always something extra coming up, isn't it?
Old trucks are fun!
-W
Woogeroo
Woogeroo
Reg: 05-26-02
05-04-18 05:29 PM - Post#2733052
replaced the starter motor in my '65 c10...
old trucks are fun...
-Woog
Woogeroo
Woogeroo
Reg: 05-26-02
09-03-18 04:38 PM - Post#2745191
08/26/2018 – mounting hole for alternator bracket : new threads
-W
First Rebuild
Reg: 05-29-16
09-10-18 07:05 PM - Post#2745850
Got parking lights working with new wire. Waiting on lenses and gaskets to come in mail. All I got left is the bed. Will this ever end? Like to post pics have not figured it out yet
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
09-11-18 06:48 PM - Post#2745937
    In response to First Rebuild
  • First Rebuild Said:
Will this ever end?
NO!!!
Edited by Chevy_Stepside on 09-11-18 06:49 PM. Reason for edit: No reason given.
09-11-18 09:43 PM - Post#2745947
Posting pictures.
http://www.chevytalk.org/fusionbb/showforum.php?fi...
29-41, 42-48, 49-54 Moderator
First Rebuild
Reg: 05-29-16
09-12-18 07:53 PM - Post#2746003
https://www.picturetrail.com/sfx/album/view/248169 ...
Edited by First Rebuild on 09-14-18 04:35 PM. Reason for edit: No reason given.
09-12-18 09:11 PM - Post#2746013
It is asking for a password to view.
Woogeroo
Woogeroo
Reg: 05-26-02
10-25-18 06:14 PM - Post#2749575
My '65 C10 started doing a wonky thing, sometimes the starter would not do anything... and I replaced it earlier this year.
Then it was doing the same thing... of course when I was out and about and on the other side of the big city I live near.
I started some basic troubleshooting and found the small wire going to the starter was cracked in places. I wiggled it, it started right up.
I wound up replacing a good part of that wire and thought it was all good... but, nope.
After a doctor appointment one day, same thing... it hit a lick, then it wouldn't.
HMMN.
wiggled the wire, and it started up.
I started checking it out... the wires going to the main engine harness plug wire on the passenger side of the firewall looked like they were ready to give up the ghost, right where it went into the plug. Hmmn.
Many years ago I had to replace one of those wires... so I unsnapped it and two more wires broke off.
I broke out the soldering gun and what not but I was having no luck this time getting going in the direction I wanted, so I just ordered a new engine harness.
Then things got interesting, seems there were different harnesses, for a 6 cylinder with gauges or lights and for a v8 with gauges or lights. Now, I have gauges, so that part was easy, but I have no idea what engine it had originally. Hmmn.
I went with the v8 with gauges, figured I could make it work.
The box arrives, I check out the goodies... yay new parts.
I start looking at the instructions layout... it was pretty neat, they had each wire numbered with a sheet of paper listing what each one was for. However, it was for the very original layout so I had to do a little internet searching to figure out what I needed.
After that, I basically only needed to hook up two wires, 1 to the HEI hot ignition and the other to the small wire going to the starter. I taped off the other wires as my gauges are wired in other ways(previous owner) or not working at all... though I think I will investigate hooking 'em up later.
At any rate it all fired up and runs again, so yay.
Old Trucks are fun.
-Woog
Execution time: 0.124 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:27 PM
