Username Post: Tri-five Wagon Roof repair        (Topic#233385)
MPandC
MPandC
Loc: Leonardtown, MD
Reg: 03-09-06
01-12-10 04:00 PM - Post#1841162
Here is a compiled reference of the roof repair I did.
If you see a hole in the roof that is noticeably up from the drip rail, chances are it has rusted from the inside-out, as you'll soon find out.
A quick check on the inside suggests we have seen the tip of the iceberg.
Looks pretty ugly, and will require taking out more than I originally thought. Time to mark out the cut line.
If you've never seen what holds the roof on, there are about a gazillion spot welds that hold it down to the gutter. Maybe not that many, but when you are drilling them out, well it seems so.
Once all the spot welds are drilled out, it is easily removed. This is going from bad to worse. The rain gutter doesn't look too healthy inside.
In true domino fashion, time to lose the gutter, and the profile shot will show how they are assembled together.
Maybe this would make the start of a good Vista Cruiser? After some much needed sheet metal replacement takes place on the inside, we'll try our hand at making a rain gutter.
Let's pause here and clarify the major components we're working with:
The rusty pieces came out as good as could be expected, and were limited help in forming new pieces. Some of the measurements had to be transposed from the opposite side of the roof, which was virtually flawless. After further inspection of the affected area, I'm thinking it was a condensation problem, and the moisture followed down the roof crossmember just like a gutter. The car must have been parked with a downhill slope to that side.
Gaining access:
Here's a good indicator for using the 3" cut off wheels as a grinder for removing spot welds. The top layer starts to turn blue when the metal gets thin and hot. Once you are through to the second layer, you will see the bright metal surrounded by the blue ring. Time to stop and pry them apart.
Think these will sell on ebay?
A trial run at rain gutters
Fabricating the new pieces
There was one more section that needed repair, specifically the section holding the headliner bows. Looking at the next pic, the left red circled area is what it should look like, and the right red circled area shows where some of the rust spread, weakening the headliner bow support. Time to cut this out, bend up a replacement, and weld together.
Dress the exposed welds a bit, and the rest will be cleaned up in the sand blast cabinet in preparation for epoxy primer. Then this stuff can start going back together.
Well most of the roof patches are just about done, ready for paint, but we'll need the rain gutter as well, so let's get that done so it can be epoxy primed at the same time. The section needed was about 31" long, and you tend to get crisper bends on shorter sections (especially with worn out machinery), so I made two pieces 16" long. Here's the bend process:
These were all done in the apron brake, with the last one accomplished using the clamping section of the brake to flatten out the bend. Next, a mark is made to cut the "tail" to size, and this cut will be done using a 3" x 1/32 cutoff wheel. To prevent from cutting through into the back side, slide a piece of scrap under the "tail".
Once the tail is cut this short, we'll need to resort to the press brake with some flattening dies to compress the fold flat, mimmicking the factory original. This could also be done using a good flat body hammer.
Then it's back to the apron brake, and with the newly made fold facing out, make a slight bend to form the curved surface you see on the outside of the gutter.
Then the rest of the bends, and a trail fit.
Although the gutter was fairly straight and needs to have a slight radius to match the roof, the heat from the plug welds should be sufficient to shrink the back edge and draw the gutter in tight to the car where it belongs.
Well the epoxy primer has dried so let's get started on the drip rail install. Some epoxy primer was also painted on the top edge of the quarter the other day, in an attempt to prolong the lifespan this second time around. Plug holes were drilled, and the first piece was welded in place.
All the plug welds were ground flush as the drip rail will position on top of this for welding. The next piece was overlapped and welded in place.
And now for the drip rail
Well I bent up a patch for the gaping hole in the roof. When you don't have the right tooling, sometimes you have to improvise. It would have been nice to use a slip roll to form the contour, but since I don't have one, we'll have to settle for incremental bends to form the radius. Then the bottom flange is bent, and we'll clamp it in place to scribe a mark from the back side and trim to fit.
All trimmed, clamped in place.
Now to see if I can pick up some tips for the spot welder tomorrow, they will likely need to be custom made to fit in the narrow void between the drip rail and the roof. If that is unsuccessful, I guess we're plug welding from the bottom side.
The normal cone shaped tips will definitely not fit the bill:
Looks like we'll have to make our own, so lets start out with some flat tips, and start on the bottom. This one has to be trimmed down pretty short to fit in there because of the outward crease just below the drip edge:
Then to shape up the top one, it will need the extra length to reach past the drip edge:
Then a test fit, this just may work!
Let's see the spot welder in action:
This looks darn near a factory finish!
We got the rest of the spot welds done, and the welder performed beautifully, tips are ready for another roof!
Then we got the mig welder going and started getting the hole closed up.
Finally got the rest of the roof structure welded back in the wagon, and the welds dressed. There are a few low spots in the roof repair, so will need to address those at a later time with some hammer welding to minimize any filler.
Using the hindsight 20/20 thing, the opening should have been cut up a bit higher, so the long horizontal weld would be more readliy accessible to hammer/dolly. I do have a U shaped dolly that I can use in this instance, but the metal finishing after closing up the "patch" should always be a consideration.
Robert
MP&C Shop Projects
Pistol
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
02-12-10 05:27 AM - Post#1861157
    In response to MPandC
Excellent Robert
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
Execution time: 0.112 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:56 AM
