brian73
Loc: mn
Reg: 12-22-05
11-18-09 10:09 AM - Post#1808042
I don't know if this is the right place but could someone help with identifying a 700r4? , on the driver side it has the #'s 8663548 embossed on it. Is there any other #'s I should look for?.
brian73
Loc: mn
Reg: 12-22-05
11-18-09 10:44 AM - Post#1808058
In response to brian73
Sorry , I should clarify I'm looking for the year and possibly what it came out of .
Brian C
Loc: Nampa, Idaho
Reg: 12-19-05
11-18-09 12:09 PM - Post#1808099
I don't have that number listed but in 1987 the numbers started with 8663589 so yours is most likely older than that. Probably a 1986 model. As for what it came out of you can get close by looking at the case, tail shaft housing and speedo gear. If it has a tranny mount on the tail shaft housing it is probably from a Camaro or Firebird. If it has a K on the top of the case at the bellhousing it is from a 4x4. If the parts of the case where the flywheel cover mounts are cut off flush with the sides of the bellhousing and do not stick out past there then it is from an S10. ALso what type of speedo connection it has can tell you a bit but I am not up on those.
By looking at the pan you can tell if it is a 86 or older or 87 or newer. The 87 has an auxilliary valve body and requires a pan that is .040" deeper. This pan also has a four indentations near the back of the pan that are the four corners of a square. One of those corners is smaller than the others. If the pan does not have those marks then it is a 86 or older. Also if it has a 27 spline input shaft then it is a 84 or older. A 30 spline input makes it 85 or later. Hope this helps.
79 Pinto wagon (sold the Neon, I am now mopar free)
94 Safari Van awd
79 Mustang, turbo 4
89 Mustang ragtop,
36 chevy cab (intended to be a 4x4 rat rod someday)
Really, really want another ElCamino. |
11-18-09 12:25 PM - Post#1808104
In response to Brian C
How long is the tailshaft? 6-9-12"?
'08 GMC Acadia 3.6L SLE
FINMAN
Loc: Burlington , Mass
Reg: 03-01-05
11-18-09 03:58 PM - Post#1808202
When standing behind the transmission and looking at the rear right hand corner of the pan flange there should be an ID code number.
brian73
Loc: mn
Reg: 12-22-05
11-19-09 06:47 AM - Post#1808509
In response to FINMAN
It does have a big k embossed on the side of bell housing and it has a 6" tail shaft I will look for the dots this evening .
This tranny was rebuilt before I got it and I plan on putting it in my 73 caprice .
This has been a big help ,Thanks all .
Reg: 06-30-00
11-19-09 09:11 AM - Post#1808587
brian73
Loc: mn
Reg: 12-22-05
11-19-09 09:18 AM - Post#1808589
It does have the 4 corners of a square with one being smaller , so that means its newer than an 86 and would have a 27 spline shaft ?.
11-19-09 10:23 AM - Post#1808632
Nope, a 84 and later has a 30 input spline. A 6" tailshaft is a good indicator it came from a car.
Brian C
Loc: Nampa, Idaho
Reg: 12-19-05
11-19-09 11:27 AM - Post#1808658
The K indicates that it came from a 4x4 but the 4x4 has a 3" tail shaft without a tail shaft housing. If it has had the tail shaft changed and now has a tail shaft housing then it should be about 8" long. Then it should fit in your caprice. The 30 spline input started in 85. The deeper pan started in 87.
After you find the model number as Mike pointed out then one of us can tell you exactly what type of vehicle it originally came out of.
94 Safari Van awd
79 Mustang, turbo 4
89 Mustang ragtop,
brian73
Loc: mn
Reg: 12-22-05
11-20-09 04:01 AM - Post#1809049
The 350 in my caprice has a 9" tail shaft , I measured both tranny's and there is less than an 1" difference so I Should not have to cut down drive shaft . I didn't notice the numbers when I looked at it before , but I will look more closely and let you know .
brian73
Loc: mn
Reg: 12-22-05
11-20-09 02:58 PM - Post#1809366
I found some #'s , they are7txm205 and what appears to be either 53 or maybe BB I can't tell .
Will these lead to an exact ID ?.
Brian C
Loc: Nampa, Idaho
Reg: 12-19-05
11-20-09 06:46 PM - Post#1809486
It was from a 1987 pickup 4x4 with a 5.7L engine. So that means that it won't fit in your caprice unless it has had the tail shaft changed to a 2wd type and a tail shaft housing added. For a two wheel drive the tail shft housing should be 7 1/4 inches with the shaft extending another 3/4 inch for a total of 8 inches. For a 4x4 the shaft will stick out of the case about 3 inches. These can be changed by a competant mechanic or a good shade tree mechanic with patience.
94 Safari Van awd
79 Mustang, turbo 4
89 Mustang ragtop,
Brian C
Loc: Nampa, Idaho
Reg: 12-19-05
11-20-09 06:50 PM - Post#1809487
I just reread one of your previous posts and saw that you already measured it. So someone has already changed out the tail shaft. Cool.
To put the 700r4 in where the th350 came out will require that you verify that the detent cable is set up correctly. In a th350 it is a kickdown cable and in the 700r4 it is a throttle vavle cable. They have different purposes so they have different setup requiements. I recomend that you study the info on this website> http://purplesagetradingp ost.com/sumner/techinfo/7...
94 Safari Van awd
79 Mustang, turbo 4
89 Mustang ragtop,
brian73
Loc: mn
Reg: 12-22-05
11-23-09 03:43 AM - Post#1810758
You Guy's have been a great help with the info,
Thanks again
wheelman
Loc: Long Island--New York
Reg: 04-14-07
06-24-13 05:23 AM - Post#2358013
I have same trans in my 68 Impala and for life of me cant find a correct inspection cover to fit. Bought 5 factory and 3 different aftermarket and none line up correctly. Starting to get annoyed.
OTLM025 are side numbers last letter illegible. Also has a large MD8. Embossed above those numbers.
1968 Impala Sports Coupe
2004 Jeep Grand Cherokee
Save a Classic - Crush an Import
[url=https://www.facebook.com/greg.leonovich [/url] |
Edited by wheelman on 06-24-13 05:26 AM. Reason for edit: No reason given.
models916
Loc: Addison, IL
Reg: 05-28-10
06-24-13 06:40 AM - Post#2358038
In response to wheelman
K case 700r4 will need the aluminum 4x4 cover with the holes for the support rods.
