Username Post: tailgate hinges        (Topic#229644)
55ej
Loc: Ohio
Reg: 11-13-09
11-13-09 04:17 PM - Post#1805293
I want to take my tailgate off. Lower hinge bolts are rusted and will not come out. I'm going to drill them out one at a time and retap them. any suggestions. thanks 55ej
Henrys57wagon
Canadian Regional Coordinator
Henrys57wagon
Loc: Ontario
Reg: 04-15-06
11-13-09 05:01 PM - Post#1805310
    In response to 55ej
Welcome 55ej. I welded a bolt onto the head of each bolt that did not want to come out, saves drilling into the bracket. Another way is to just drill the head enough to remove the hinge and then shoot penetrate on the exposed stud and let sit, then use vicegrips on the studs. Turn the bolt both ways as you remove them to loosen grime on the underside of the bolt threads, good day, Henry.
57 B/A wagon, 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 07 2500HD with 26 Prowler 5th wheel, 09 Impala LT, 2- 51 HenryJ's,
http://www.picturetrail.com/sfx/album/listing/use r...
11-15-09 08:43 AM - Post#1806116
    In response to Henrys57wagon
Spray some penetrating oil on them and let them soak for a couple of days (repeat spraying occassionally). Then if they won't come out, you can first try some heat to help get them going. Sea Foam is made to work better on parts that have been heated. If those methods don't work, weld the bolt on as Henry suggests. The heat from the weld helps and the bolt is better than the screw because you can get a socket on it. If all else fails drill only enough to get the hinge off as Henry said as well. You really don't want to be trying to drill through the whole screw and retapping the threads unless absolutely necessary.
1957 Cameo Carrier
MPandC
MPandC
Loc: Leonardtown, MD
Reg: 03-09-06
11-16-09 07:34 AM - Post#1806710
    In response to wagonman100
You may find it easier to weld a nut onto the head of the phillips than welding around a bolt. Welding inside the hole will help to contain the splatter/damage from the rest of the gate. Won't prevent it, but will help.
Robert
MP&C Shop Projects
cdmhenry
cdmhenry
Loc: Minden, NV.
Reg: 09-14-00
11-16-09 08:45 AM - Post#1806744
    In response to MPandC
If the screw is original and has never been removed, don't waste your time with penetrant. Weld a bolt on the screw head and wrench it out.
All this advise for a 1 post wonder?
Every Government Interference In The Economy Consists Of Giving Unearned Benefit, Extorted By Force, To Some People At The Expense Of Others - Ayn Rand
55ej
Loc: Ohio
Reg: 11-13-09
11-16-09 01:54 PM - Post#1806919
    In response to cdmhenry
I think I take offense to your comment about a one post wonder.
55ej
Loc: Ohio
Reg: 11-13-09
11-16-09 03:11 PM - Post#1806966
    In response to 55ej
Thanks for all the advice. I wanted to take tailgate off to repair lower part. Not sure what I want to do now. Has anyone ever just taken the pins out of the hinges?
This is a great site, found it while doing search for "putting on quarter panels".
again Thanks ej
11-16-09 06:19 PM - Post#1807115
That's what this site is all about.
Good idea on using the nut Robert. I used a bolt on some tri-five rear door hinges, but that was mostly because that made where I was getting the socket on the head of the bolt far removed from the door and made it easier.
1957 Cameo Carrier
11-17-09 04:17 AM - Post#1807291
Forgot to mention that the pins can be a real pain to try to get out. You're better off with trying to get the screws out.
1957 Cameo Carrier
Henrys57wagon
Henrys57wagon
Loc: Ontario
Reg: 04-15-06
11-17-09 10:05 AM - Post#1807467
When I had the hinges off my gate I tried to remove the pins but they were frozen in, and since they were in good shape I just left them in, good day, Henry.
Hobby Guy
Loc: Orange County
Reg: 07-01-09
11-18-09 05:23 PM - Post#1808259
I also could not remove the pins after the hinges were off.
I finally took them to a machine shop, where the guy put them into a press and pressed them out. It was so quick and easy that he didn't even charge anything ! And if your pins look anything like mine did, you will be glad you replaced them.
Zygmo
Zygmo
Loc: Arkansas
Reg: 11-09-09
04-02-10 05:47 AM - Post#1891360
    In response to Hobby Guy
Ej, I used one of those hammer screw removers. Harbour Freight carries them, for around $10.00 I think. Comes with several sizes of screw bits, including one just the right size. Soak the screws in WD40, then try the hammer. Works well on door hinge screws, too.
Dean
57 Chevy 4dr Bel Air Wagon My Pix
Hobby Guy
Loc: Orange County
Reg: 07-01-09
04-02-10 06:25 AM - Post#1891381
    In response to Zygmo
1 method that works very well for removing many screws or bolts that just don't want to budge is to heat-up the heads with a torch, to a dull red, then spray some WD-40 or liquid wrench on it. Sometimes it needs more than 1 application. You will get a bit of smoke on it when the lubricant hits the hot surface. The metal expands, then shrinks while lubricant goes into the threaded surfaces. I used that method successfully a lot of times after having given up on the hand held impact.
johnminton
Reg: 04-11-18
04-11-18 12:53 PM - Post#2730701
Anyone make the kind that "Kin dig it" made for their resto-mod? (Hidden)
Execution time: 0.116 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:42 PM
