Username Post: Door fuzzies        (Topic#229407)
SZD167
Loc: KIRUNA SWEDEN
Reg: 09-12-09
11-10-09 10:18 AM - Post#1803038
Hi everybody, im replacing the door fuzzies but i only have one on the inside panel and no one on the outside stainless.There is no holes after staples on the outside one.My question is, is this correct or am i missing something here? the kit that i bought has 4 strips that is correct length, but i have only one at each door.
Anders
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
11-10-09 01:36 PM - Post#1803131
    In response to SZD167
On a 2dr ht, only the inside gets the fuzzies.
57 Bel Air 2dr Ht
327 700r4
babyblue1955
babyblue1955
Loc: oregon city or
Reg: 03-12-04
11-10-09 09:18 PM - Post#1803509
    In response to 57tim
hi there. do you know if the door fizzys are the same on a 55 chev nomad fizzys on the inside and not the outside? babyblue 55
Nomad Jack
Nomad Jack
Loc: Cape Cod, Ma.
Reg: 03-14-03
11-11-09 04:46 AM - Post#1803629
    In response to babyblue1955
If you are talking about the horizontal window seals, the 55 Nomad does not have any. The chrome around the edge of the window glass would interfere with any seals as the window goes up and down.
Nomad Jack
55 Nomad
http://www.jaxcars.net/55-chevy-nomad.html
57 3100 Pick-up
http://www.jaxcars.net/57-chevy-pick-up.html
31 LT Truck
http://www.jaxcars.net/31-chevy-truck.html
53 CJ3B Jeep
https://www.jaxcars.net/1953-cj3b-willys-jeep .html
ZZ Nomad
ZZ Nomad
Loc: Chicagoland
Reg: 03-19-07
11-11-09 09:10 AM - Post#1803782
The guys are correct that the fuzzies are only on the inside, but when you look down in the doors with the windows rolled down it looks a little unfinished. We glued a thin fuzzy to each outer side when we had the car apart last winter and it looks a lot cleaner now. Jack is correct that the chrome window frame will come in contact with the outer fuzzy when the windows are rolled up and down, but there’s not much friction and mine are holding up just fine so far. Just something to consider if you want to finish out the outer pieces a little.
ZZ502/502 Nomad
1956 Chevy Nomad
1956 Chevy 3100 Pickup
1932 Chevy Cabriolet
madasell
madasell
Loc: Great North-Wet, Orygun
Reg: 04-21-03
11-11-09 01:28 PM - Post#1803931
    In response to ZZ Nomad
My '57 has the staple holes on the inside door molding I think the original poster indicated. Not sure what year his car is, though. I glued a fuzzie strip to that inside edge and also replaced the little roller which attaches to the inner door sheetmetal there. The glass rolls up and down fine and the chrome surround doesn't catch on the fuzzie. I think the key is the roller. Do the '55's (or '56's) have that roller?
Do these fins make my rear end look big?
SZD167
Loc: KIRUNA SWEDEN
Reg: 09-12-09
11-17-09 08:06 AM - Post#1807403
After some investigations,only the inside should have a fuzzie, in the kit there was 4 strips but i think that the two other ones were for the sliding window seals
Anders
johnminton
Reg: 04-11-18
04-11-18 12:45 PM - Post#2730700
Nomad door fuzzies. My door rattles. It looks like there should be a fuzzie in the rear up/down channel but no indication there was ever one mounted there. It would be of a larger size due to the chrome window trim. (Original barn find) Any ideas?
Edited by johnminton on 04-11-18 12:48 PM. Reason for edit: No reason given.
Lee T
Reg: 07-05-12
04-13-18 02:21 AM - Post#2730838
    In response to johnminton
The rear verticle channel doesn't have a formed fuzzy channel like the front, it just has felt glued in.
"On the back side of the door is a wide channel to accommodate the chrome door window frame. We offer a felt to reline these channels. FS-92 is 1-5/8” wide and FS-92W is 2-5/8” wide. This felt is installed with contact cement on the back side of the felt liner and in the channel. Find a board that is the proper width and height to fit snugly in the channel. Wrap the pre-glued felt over the board and press into the channel. Let this set overnight to dry. Trim off the excess and remove the board. The channel is now ready for glass installation."
https://www.fillingstation.com/articles/windowchan...
johnminton
Reg: 04-11-18
04-13-18 11:37 AM - Post#2730868
    In response to Lee T
The perfect answer! Thanks!!
Execution time: 0.086 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:07 AM
