Join the Community today
Username Post: 1936 chevy standard sedan engine color        (Topic#223231)
hoppinb
Loc: Waterport, NY
Reg: 07-30-09
08-07-09 01:34 PM - Post#1749706
Recently purchased the 36 and am new to chevy family as I am a Ford Model A guy until now. My question is in regard to engine color. Would like to know the cast color and what the stamped parts ie. timing gear cover, valve access cover are. Would appreciate input.....new guy... hoppinb...thanks
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
08-07-09 02:21 PM - Post#1749740
    In response to hoppinb
The engine color is a dark blue/gray. The same color was used from 1929-1952, 1953 stick shift engines and various truck engines up to 1962.
The correct color is available from ....www.chevsofthe40s.com.....
The followings parts were "engine color"
Balancer, water pump, valve cover, oil pan, flywheel housing and its covers, manifolds and their attaching hardware, and the oil distributor valve, left lower side of block.
The fan, oil filler, gen. and starter, distributot, transmission was black.
The engine parts that are gray were bolted together then the engine was painted. This means that the attaching bolt heads, edges of gaskets, etc and the acorn nuts holding down the valve cover were blue/gray.
hoppinb
Loc: Waterport, NY
Reg: 07-30-09
08-07-09 06:28 PM - Post#1749900
    In response to Gene_Schneider
Gene, thnx so much for your response. I'm excited to get the show on the road. I'm sure that in the near future that this site will prove invaluable. Once again thnx......Hoppinb
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
08-08-09 02:09 AM - Post#1750005
I am making this thread sticky as it is a contsnt query! And across Forums!!
gypsyrose
gypsyrose
Loc: lake macquarie NSW Austra...
Reg: 02-09-10
03-14-10 12:45 AM - Post#1879726
Hi Id love to see some pictures of your car.
hoppinb
Loc: Waterport, NY
Reg: 07-30-09
03-14-10 06:43 PM - Post#1880154
    In response to gypsyrose
Hello Gypsyrose I am in the process of taking some pictures as it is in the process of reassembly..Keep in touch..will post later. hoppinb
ac13387
Reg: 04-03-12
04-03-12 07:04 AM - Post#2210663
You probably already know but there is a lot of wood in the early Chevys, rear window frame, doors and a couple other places. Check for the condition before you get deep into resto.
chevy standard
Loc: Staten Island, New York
Reg: 06-21-14
06-21-14 09:08 AM - Post#2463223
check out bill hirsch he has all colors for older cars.billhirsch.com
Execution time: 0.104 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:22 AM
