Username Post: Transmission dimensions        (Topic#220966)
TheDUKEofDULL
TheDUKEofDULL
Loc: The DON'T DRINK & DRI...
Reg: 11-18-06
07-07-09 02:34 PM - Post#1730768
I have a 3spd w/od trans in my '59 Belair. I want to go to a 4spd. It looks like the driveshaft length with the 3spd w/od will work with the 4spd, correct?
Which 4spd transmissions will bolt in easily? (years & models)
Thanx, johnny
I DIDN'T vote for HIM...
Edited by bowtieollie on 07-08-09 01:37 PM. Reason for edit: title change for sticky
bowtieollie
bowtieollie
Reg: 12-06-99
07-07-09 05:08 PM - Post#1730844
    In response to TheDUKEofDULL
Hi Flat,
Looks at the top of the forum list.
There is a sticky addressing driveshaft lengths by transmission types.
Bowtieollie
Chevytalk.com Moderator
Jens
58-60 Subject Matter Expert - "11th Year" Silver Supporting Member
Jens
Loc: Iowa.
Reg: 04-21-02
07-07-09 06:23 PM - Post#1730887
    In response to bowtieollie
Here's a transmission list Chuck sent, if you want to add it to that sticky post Ollie.
Jerry Acheson
Jerry Acheson
Loc: Green Oaks, IL
Reg: 12-30-00
07-08-09 04:01 AM - Post#1731008
    In response to Jens
Wow! Hey Bowtieollie; the info from Chuck/Jens should be put at the top of the forum as a permanent link. This should be a great complement to the driveshaft length thread. Thanks guys for posting.
Jerry
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
07-08-09 04:39 AM - Post#1731023
3 speed with O/D and 4 speed driveshafts are the same, yes. The front section is the one that is different than the other models. The T-10 or Muncie either one should fit. The output yoke may be different, be careful.
Donny
Edited by aawtech on 07-08-09 04:46 AM. Reason for edit: No reason given.
TheDUKEofDULL
TheDUKEofDULL
Reg: 11-18-06
07-08-09 09:58 AM - Post#1731166
    In response to aawtech
Donny,
That's the info I need. Thanx a bunch.
Johnny
bowtieollie
bowtieollie
Reg: 12-06-99
07-08-09 01:36 PM - Post#1731278
You guys asked - and I have to agree - its great material!!
Bowtieollie
Sawlee
Reg: 08-05-09
11-12-09 09:01 AM - Post#1804492
    In response to Jens
Well...On to the next question at hand:
I´m looking to upgrade from a Powerglide to a TH700R4 in a ´58 Impala. The dimension chart is nice, but I see no reference to the PG there.
So, I take it I´d be best off going with the type of 700R4 -unit that´d have the face-to-mount distance of 22 1/4 -inch, but what is the overall length as well as face-to-mount distance of the PG?
This in hopes of figuring out exactly where the trans crossmember needs to be located, as well as the driveshaft shortened?
Thanks again.
Hobbies and interests: A ´58 Impala Sport Coupe,and it seems that´s about it lately...
thatguy2001
thatguy2001
Loc: Oregon
Reg: 07-12-07
09-01-10 10:24 AM - Post#1969911
    In response to Jens
Anyone know the dimensions of an m40 turbomatic? it's in a 77 van with a strong 400ci. engine that I can pick up cheap.
Never mind, I just found the answer
The M40 3-speed, automatic transmission, RPO was also a generic category in 1969. It was translated at the factory into the TH350 (actually RPO M38) for non-big-block engines, and into the TH400 for big-block engines.
So I guess the question I need to find an answer to is, does this one have a short shaft?
Seth
'59 Chevy Biscayne 4D: Baby
car photos
thatguy2001
thatguy2001
Loc: Oregon
Reg: 07-12-07
09-12-10 07:12 PM - Post#1975196
    In response to thatguy2001
Here is another tranny spec sheet that shows some other transmissions.
Power Glides are 20 9/16" to mount and 27 9/16 total. Very close to a TH350 short shaft.
Seth
car photos
Rugratman
Loc: Maryland
Reg: 09-15-10
02-12-11 02:47 PM - Post#2045748
OH No...the measurement sheet disappeared
Just Learning as I Go Here...
lostkoz
lostkoz
Loc: Caldwell, Idaho
Reg: 11-07-05
05-19-11 03:33 AM - Post#2092107
Yes the 3 speed overdrive driveshaft is the same lentgh as the 4 speed.
Grey
Grey
Loc: Norway
Reg: 08-02-05
03-01-16 04:26 PM - Post#2612497
    In response to lostkoz
Anyone have the transmission list that Jens posted...which is now gone?
1959 Chevrolet ElCamino
Jens
Jens
Loc: Iowa.
Reg: 04-21-02
03-01-16 05:57 PM - Post#2612517
    In response to Grey
Here it is:
ragtp66
ragtp66
Reg: 12-09-07
10-26-17 08:31 PM - Post#2712301
    In response to Jens
Here since they keep disappearing. http://www.crankshaftcoalition.com/wiki/images/9/9...
Return to Dimensions of common GM automatics
http://www.crankshaftcoalition.com/wiki/images/3/3...
All dimensions are in inches.
Powerglide (bellhousing pattern - Chevrolet, Fit-all)
Style A B C D E
short shaft 25 23/64 16 5/16 20 9/16 3 ¾ 19
TCI shorty 17 15/16 16 5/16 20 9/16 N/A 19
long shaft 27 9/16 16 5/16 20 9/16 3 ¾ 19
TH350 (bellhousing pattern - Chevrolet, BOP, Fit-All)
Style A B C D E
6" tailshaft 27 11/16 21 5/8 20 3/8 3 ¾ 19 1/8
9" tailshaft 30 11/16 21 5/8 20 3/8 3 ¾ 19 1/8
12" tailshaft 33 27/32 21 5/8 20 3/8 3 ¾ 19 1/8
TH400 (bellhousing pattern - Chevrolet, BOP)
Style A B C D E
C tailshaft 28 3/8 24 5/16 26 15/16 4 ¼ 20
D tailshaft 33 27/32 24 5/16 27 15/16 4 ¼ 20
13" tailshaft 37 7/8 24 5/16 27 21/32 1 ¾ 20
2004R (bellhousing pattern - BOP, Fit-All)
Style A B C D E
All 27 11/16 integral tailhousing 27 3 ¾ 19 1/8
700R4 4L60 (4L60E 1993-1995) (bellhousing pattern - Chevrolet)
Style A B C D E
All except Corvette 30 ¾ 23 3/8 22 ½ 3 ¾ 20
Corvette(1982-1996) 29 7/8 23 3/8 22 ½ 3 ¾ 20
4L60E/4L65E 1996-Later (bellhousing pattern - Chevrolet/removable)
Style A B C D E
All except Corvette & LS1 30 ¾ 21 ¾ 23 3/16 3 ¾ 18 ¼
Corvette (transaxle) N/A N/A
LS1-style (1998-later) 31 5/32 21 ¾ 23 19/32 3 ¾ 18 ¼
4L80E/4L85E 1991-Later (bellhousing pattern - Chevrolet)
Style A B C D E
Std. 2wd 32 11/16 26 30 3/8 4 ¼ 20
HD 2wd 31 15/16 26 30 3/8 4 ¼ 20
HD long 33 26 30 3/8 4 ¼ 20
4 X 4 29 26 30 3/8 N/A 20
[edit] Weights
Weight (approximate, in pounds):
Powerglide- wet 110
TH200C- 96
TH350- wet 130
TH400- wet 140
TH2004R- 132
4L60E- wet 175
4L80E- wet 255
Toys:
1987 Sea Ray Pachanga 22
killerkjn
Loc: Edgewood, WA, usa
Reg: 12-19-02
09-22-19 06:03 AM - Post#2776119
    In response to ragtp66
I have had a hard time finding the weight of a cast iron powerglide. I just removed mine from my 62 impala for a 2004r upgrade. I drained it of fluid and weighed it. The transmission with the bell housing adapter (spacer) and torque converter is. Drum roll please. 230 lbs.
Edited by killerkjn on 09-22-19 06:06 AM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
09-24-19 03:33 AM - Post#2776315
    In response to killerkjn
I keep telling people if you want to lighten up your 62 with an ironglide and a 235, drop a 409 4 speed in it. I had an ironglide in the 59, I remember moving it around after removal, also removed one from a 62. Never weighed one though.
Member #2194
Execution time: 0.107 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:37 PM
