 Page 2 of 2 <12
Username Post: Complete rebuild of front cross member and suspension        (Topic#218134)
54Convert
54Convert
Loc: OK
Reg: 10-29-06
06-13-14 10:02 AM - Post#2461095
    In response to 67Spirit
TIP
LESSONS LEARNED
upper INNER shaft.
If you are having problems betting the new shaft to "bite" and go into the bushings, try this before you take a hammer to it.
Follow DZ's advise on using the lower outer bolt as a tool to install......but also use another'ANOTHER' LOWER OUTER NUT ON THE OTHER SIDE OF THE UPPER INNER SHAFT TO TIGHTEN UP THE SHAFT.
Then use two 1 1/8 wrenches on either end of the shaft to both push and pull at the same time.
Works like a champ. Got this tip from one of our
members down under..........but it resolved my particular situation
54 Belair 1067DTX, Roman red 327 Turbo350
54 Belair Hardtop, just bod off frame,work in progress
54 210 Station wagon Father in laws pass me down
Member #51
07-19-14 06:47 AM - Post#2470235
    In response to 54Convert
Are you referring to the steel bushings for the upper-inner cross shaft??? If so, they are spot welded in place and new ones are available from Paragon Reproductions.
Member #51
07-19-14 06:49 AM - Post#2470236
The bell crank that you mentioned, is that the center steering arm/bracket??? If so, you also need the Vette left and right steering arms because they have a different angle than the ones on pass cars.
Member #51
07-19-14 06:50 AM - Post#2470237
The member from "down under" got the tip from me.
54Convert
54Convert
Loc: OK
Reg: 10-29-06
07-31-14 07:51 PM - Post#2473398
well then your both genius's
dmax75
Reg: 09-23-14
09-24-14 04:45 AM - Post#2486221
Tom,
I am a noob here and I have now been welcomed, figured out I had to be logged in to reply, and now know what a sticky can do for someone!
This is exactly where I am with a 54' Bel Air and now that I have seen your rebuild I am even more excited. That looks awesome!
westsiderider
westsiderider
Loc: Santa Barbara Ca.
Reg: 04-29-15
09-30-16 02:38 PM - Post#2654201
Just wanted say thank you for your thread on this front end rebuild . About 1 1/2 years ago I followed your instructions on my 49 and it went smooth. My first front end rebuild ever ! I really appreciate you and others who share their knowledge with the world . A challenging project can get done with nice guys like you , sharing your expertise, for free . Thanks again .... Best wishes - David
Attachment: IMG_0632.JPG (1.85 MB) 291 View(s)
Member #51
10-05-16 03:50 PM - Post#2655064
    In response to westsiderider
Thanks David,
Now, while you are at this point in the restoration of your 49, one thing I will point out. You can do a really nice DIRECT BOLT-ON upgrade to your brakes by locating a 51-54 donor car and replacing your Huck brakes with the 51-54 Bendix style brakes. You will need the backing plates, drums and all brake hardware from a 51-54 car. It will all be a direct swap and a nice brake upgrade.
stilsmokin
Loc: los angeles ca
Reg: 06-01-15
08-03-17 01:40 PM - Post#2702676
hello dzauto, I can not see the pictures for the front suspension, they are very helpful, Chevy talk is asking to update my account on Chevy talk why? I,am in the process of rebuilding my second front suspension, and I have a couple of things to see on your posting on supension. (818)492-0780 Frank.
08-03-17 07:20 PM - Post#2702723
    In response to stilsmokin
It is not asking you to update your info. Looks like Tom had the photos uploaded to photobucket.
Photobucket it now asking for money to host pictures. Those were the pictures he took. The service manual should have most of the pictures you need.
There is a topic, I think in ChitChat that talks about Photobucket.
29-41, 42-48, 49-54 Moderator
stilsmokin
Loc: los angeles ca
Reg: 06-01-15
08-05-17 12:56 PM - Post#2702942
I have a question about the upper a arm controls, How do you install them? they are hard to install. Do you have pictures on how to install them? (818)492-0780 Frank
bradberry00
Reg: 08-20-17
08-20-17 07:33 PM - Post#2704986
It is really to bad photobucket killed this thread...any chance you still have the photos and that they could be reuploaded to a different server?
stilsmokin
Loc: los angeles ca
Reg: 06-01-15
10-25-17 03:00 PM - Post#2712143
Hello DZAUTO, I have a question on the camber adjustments, there are 2 1 on the drivers side and 1 on the passenger side, since I took mine apart, I don't remember which side the allen screws go the drivers side goes to the back, twards the steering wheel, and the passengers side the allen goes the front twards the head light, is the right? if so I don't remeber the adjustment on the actual allen screws if the go twards the outside or?. I did this once and they came out prfect, but it has been a while. Here is my cell number, if you can call me I would sure apreciate it, call me any time, I,am retiered it is 3:00pm wed. Thank you very much I hope to hear from you soon.
stilsmokin
Loc: los angeles ca
Reg: 06-01-15
10-25-17 03:01 PM - Post#2712144
By the way I,am off line now, so I wont be able to see if you post anything, phone call would be great. Frank
stilsmokin
Loc: los angeles ca
Reg: 06-01-15
10-25-17 03:02 PM - Post#2712146
(818)492-0780 Frank
stilsmokin
Loc: los angeles ca
Reg: 06-01-15
11-15-17 08:19 AM - Post#2714463
I'am finished putting togaether the front suspension. I have a silly question, the front Brake pads, doe's the short pad go to the front or at the back, it has been a while I had to stop my project, and I restarted again, forgetting where I left off. I'am moving to Las Vegas soon.
DECEASED
11-15-17 11:36 AM - Post#2714491
Short faces forward. And they are shoes or linings, not pads. Pads are on disc brakes.
stilsmokin
Loc: los angeles ca
Reg: 06-01-15
11-16-17 01:39 AM - Post#2714593
Hello Ray, the manual reads, on page 5-13 6. Attach brake shoe to brake flange plates with the hold down pins and springs using tool J-4712; at the same time engage shoes with wheel cylunder connecting links. The primary shoes (short lining) goes forward. You wre so right, I just had to read a ;ittle closer, thank you, I have another problem the Arm that controls the steering is hitting the parking brake base. I never had these problems before, poopoo happens. I,am gona have to look this over, I dont think it's because I put springs that were cut 1" to lower it a little. Any way I'll call you tomorrow. Talk to you soon.
stilsmokin
Loc: los angeles ca
Reg: 06-01-15
12-04-17 06:46 AM - Post#2716820
Hello DZAUTO, Do you or do you have the link that shows how to rebuildthe steering colum? my steering colum hits the bottom of the emergency brake bracket. and does'nt alow the steering to turn all the way to the left. It hit the ememgency brake bracket, and stops. I believe you ahve a link that shows how to rebuild them. Thank you Frank.
12-04-17 10:33 AM - Post#2716844
Please see my reply to you on August 3 2017.
Member #51
02-06-18 08:43 AM - Post#2723519
Let's see if this works.
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
02-06-18 11:15 AM - Post#2723536
That works. All the pictures are great.
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
Jones
Jones
Loc: Germany/Bavaria
Reg: 09-27-16
02-14-18 06:08 PM - Post#2724430
Hey,
Thank you so much
Just started to disassemble my frontend
Jason
 Page 2 of 2 <12
Execution time: 0.228 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:31 AM
