Username Post: headlight motor runs after light is down        (Topic#214394)
evot123
Loc: s.c.
Reg: 02-11-09
04-12-09 12:51 PM - Post#1674671
my passenger side headlight motor continues to run for about 5 seconds after the headlight is all the way down(1998 c5)what does this mean.....bad motor...how much do they cost...thanks for your help
dont give up, help is on the way
1965C-10
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
04-14-09 10:01 PM - Post#1676723
    In response to evot123
Probably not the motor, maybe it's the gears, I hear they are made of plastic.
I think there are brass ones you can get somewhere.
wagonmaster
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
04-15-09 05:06 PM - Post#1677274
    In response to 1965C-10
Could be the "stop" that the lever hits when rotation is complete....Not sure how to get to that or how to adjust it...Sorry.
Hey T @!
Joe
Sting Ray
Sting Ray
Loc: Drag City, California
Reg: 02-19-05
04-15-09 06:56 PM - Post#1677379
Has the car set any codes and if so what are they?
If no codes, check relay #44 in the passenger footwell electrical center, that's the relay that operates headlight doors.
Bleeds Chevy Orange
1957 Chevy 150, 3-spd
1967 El Camino, 427, 4-spd
o2bnkc
Loc: Carson City, Nv.
Reg: 03-29-13
03-30-13 01:19 AM - Post#2330931
    In response to Sting Ray
It's your headlight gear. It's mad of plastic and they are prone to stripping out. Replace it with a brass gear. All the corvette vendors sell them. It's a fairly simple job. In fact there's some good videos on youtube showing how it's done. The corvetteforum has some good writeups too. This also will clear up the problem of having the lights pop up when just the parking lights are turned on. If you have any questions, let me know. I've done this procedure many times.
A Proud Navy Vet
lonsal
lonsal
Reg: 01-05-03
09-08-13 08:34 PM - Post#2380367
    In response to o2bnkc
Agreed with the comments that it is the plastic gear that needs to be replaced. I sell a kit for the 97-99 and 00-04 'Vette. If yours is the 97-99 (which came with a metal headlight actuator housing with a side cover attached with 3 screws) and you don't know the vehicle service history, you will need to confirm that it still has the metal housing. It could have been changed by a PO or the dealer to the 00-04 plastic housing. The brass gear in either kit is the same, but the instructions differ and I include a gasket with the 97-99 kit vs 2-part urethane and a t-brace for the later kit.
Lon
Top-Down Solutions
1990 Camaro RS Convertible 1988 Camaro IROC Resto-Project
Execution time: 0.134 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:00 AM
