Rocki
![Rocki](http://i298.photobucket.com/albums/mm247/sz3gfj/Copyof2008-05-22.jpg)
Loc: Hartland, Michigan
Reg: 06-17-05
03-08-09 06:19 AM - Post#1646372
There have been a couple of posts recently about rusty box braces, or body to frame supports, the boxed-in body mounts at the rear of the wheelwell. Eckler's Chevy Classics magazine, in its March 2009 issue, had an article that, in part, addressed replacing these supports. The thrust of the article was replacing body mounts. To help those who are working on these supports, I have scanned the article and include it here. Note that the body support parts called out in the article are available from many parts suppliers, so shop for the best prices.
Don't know how the readibility of this will be. If you need a better copy, PM me and I'll e-mail it to you.
64 Impala SS Convertible (undergoing frame-off resto and upgrades)
62 Impala SS Convertible Anniversary Edition 409/409, 4 speed (recovering from engine fire)
65 Mustang GT Convertible, 289, 4 spd (wife's toy)
Dreaming of more... |
dav63
![dav63](https://www.chevytalk.org/fusionbb/fbbavatars/av-29733-1234402046.jpg)
Loc: Bowie, Maryland USA
Reg: 04-30-05
03-08-09 06:39 PM - Post#1646868
In response to Rocki
Rocki, you are right on the money with this post. I have the same issue on all my impala's. I have order the boxes. This wiil be by spring project.
dav63
1963 Impala SS 327/300h
1962 Impala 283/250 |
mcyphert
![mcyphert](https://www.chevytalk.org/fusionbb/fbbavatars/av-58370-1299412282.jpg)
Loc: Clarion, PA
Reg: 01-27-09
03-11-09 07:50 AM - Post#1648929
In response to dav63
I ordered new braces and covers at Xmas time, when Eckler's was offering free shipping. Personally, I think it's ironic that they published this article when they did. I would guess that anyone who has a car from the northeast has this issue. I bought my Impala 25 years ago when I was in high school. Someone prior made a metal box where the driver side mount belongs and bolted it to the frame. It wasn't even welded to the body. It's scary when I think about what that car went through when I was a teenager!
1964 Impala 2 door hardtop
2006 HHR
2017 Malibu
2017 Silverado double cab |
dav63
Reg: 04-30-05
03-15-09 09:31 AM - Post#1652061
In response to mcyphert
Rocki, my box braces are in bad condition, due for replacement this spring.
![](http://inlinethumb03.webshots.com/29570/2803989830084257240S600x600Q85.jpg)
![](http://inlinethumb58.webshots.com/3705/2810048820084257240S600x600Q85.jpg)
dav63
RambosRide
![RambosRide](https://www.gravatar.com/avatar/360e8ca9b6e9470d3cd0d6c211af08d8&s=80)
Reg: 10-01-20
10-01-20 08:50 AM - Post#2804597
Ecklers removed the link to the pdf file pictured in this thread...
Any chance someone has a copy saved on disk?
Dan
RambosRide
Reg: 10-01-20
10-09-20 09:11 AM - Post#2805154
In response to RambosRide
I got a pdf copy of the instructions from rocki!
I bought factory type rubber replacements from Ecklers, so not poly urethane.
What I'm struggling with is the torque specs...
Book says 40-50ft lbs, but even at 20ft lbs the front firewall lower rubber bushing is extremely compressed - how flat or "squished" out should that lower rubber mount be compared to the washer?
Dan
How
Verne_Frantz
DECEASED - Member #574 "61-64 Subject Matter Expert"
![Verne_Frantz](https://www.chevytalk.org/fusionbb/fbbavatars/av-574-1568478038.jpg)
Loc: Hightstown,NJ USA
Reg: 08-22-00
10-09-20 07:28 PM - Post#2805183
This is the front mount with new bushings from Steele torqued to 45lbs.
Verne
RambosRide
Reg: 10-01-20
10-10-20 09:53 AM - Post#2805199
In response to Verne_Frantz
Thanks for the picture Verne - I wouldn't have thought the lower would compress that much.
At 45ft lbs do you think you were up against the crush sleeve that comes with the larger rubber between the body and frame?
Verne_Frantz
Reg: 08-22-00
10-10-20 07:59 PM - Post#2805229
Well, since my x-ray vision isn't working as well as it used to, I really don't know.
I can only tell you that the torque wrench didn't all of a sudden get tight.
Verne
RambosRide
Reg: 10-01-20
10-12-20 08:18 AM - Post#2805312
Verne
LOL - my x-ray has failed me too - the old eyeballs aren't what they used to be!
Sounds like you got to the torque spec without hitting the crush sleeve.
These original mounts are very odd compared to later 60's and 70's vehicles..at least from what I'm seeing.
Dan
Scott1962
Loc: Minnesota
Reg: 11-16-18
01-10-21 12:07 PM - Post#2811781
Is there anyway to get a copy of this article Thanks
RambosRide
Reg: 10-01-20
01-12-21 07:39 PM - Post#2811964
In response to Scott1962
I have a copy I sent you a private post
Adam63impala
![Adam63impala](https://www.chevytalk.org/fusionbb/images/avatars/0.jpg)
Loc: From Memphis to Florida
Reg: 12-01-15
05-20-24 05:14 PM - Post#2870071
any way I can get a copy of this ?!? do the box braces have to be welded on ? I'd have to have a shop do all that.
junky
Loc: Northeast CT
Reg: 06-27-10
05-22-24 09:02 PM - Post#2870121
In response to Adam63impala
I would say that you will have a tough time getting anything from anyone in this thread. Look at their profiles and you will see that it has been a long time since they were on the forums.
pvs409
![pvs409](https://www.chevytalk.org/fusionbb/fbbavatars/av-26453-1368069215.jpg)
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
05-22-24 10:29 PM - Post#2870122
I probably have a copy of this magazine
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
https://paulstensland.com
