Username Post: timing help        (Topic#207266)
the427chevy
Lurker
Reg: 01-13-09
01-13-09 11:46 AM - Post#1605948
got an 88 chevy with a 350 tbi motor, when i set the timing with the light to 0 degrees everything is steady, rev it up and it doesn't bounce around but when i hook up the computerized timing it won't hardly run all it does is pop and back fire out the exhaust.. i'm a 4 barrel kind of guy so this has got me stumped
Chevytech
Chevytech
Reg: 04-25-04
01-17-09 08:43 AM - Post#1609219
    In response to the427chevy
Sometimes the outer ring on the Harmonic balance (front pulley) slips and rotates making it so you can’t set the timing with a timing light.
The more common problem on these trucks is for the distributor module to fail. Many stores like NAPA in my area will test the module for free if you bring it in.
Make sure when you install or reinstall the distributor module that you use heat sink compound/grease under it. The compound helps dissipate heat from the module. Without it, the module will fail.
PS: This post is up in the car section and this happens often because the area is NOT clearly marked.
There is a truck section farther down on the form index. The truck section gets much more traffic and you will get more help when you post in the truck section. A moderator may move this if they find it.
I see it’s your first post. Welcome to the message board.
ausman
Lurker
Reg: 03-04-09
03-04-09 07:51 AM - Post#1643496
    In response to Chevytech
Could be a bad ignition module.
Execution time: 0.353 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:29 PM
