Username Post: cosworth parts?        (Topic#204039)
hoffbug
hoffbug
Loc: Maplewood,MN
Reg: 12-29-00
11-26-08 08:54 PM - Post#1572325
Where do you find parts for a cosworth engine?
Cam belts, distributor belts. gaskets.. valves bearings etc?
I know they raced these in Midget cars for a while before they were outlawed..
so what about hot cams?
You can sleep in your car but you cant drive your house
Tony H 72 Malibu 11.38 ET
Mike McVeigh. Not forgotten
bowtieollie
Member #3 ChevyTalk Subject Matter Expert
bowtieollie
Reg: 12-06-99
11-27-08 08:27 AM - Post#1572600
    In response to hoffbug
Hi HOff,
Best source for the parts you mentioned is....
http://www.cosworthvega.com/
Forget the hot cams if you intend on driving it on the street. The engine has a completely useless power band. I would entertain the thought of reindexing the factory cam sprockets - the CVOA offers this service - and it really wakes up the bottom end - or as I say - the way we drive these cars daily on the street. (one thing though - I sure do miss the KICK you got at 4000+ rpm when the cam came on - with the stock sprocket timing.
You will need a Timing Belt Tensioner tool for any maintenance work with the water pump, timing belt, cams, or oil pump/oil seal.
In case you are interested...
http://cgi.ebay.com/ebaymotors/ws/eBayISA PI.dll?Vi...
Bowtieollie
Chevytalk.com Moderator
caryabhi11
Lurker
Reg: 03-27-09
03-27-09 11:29 AM - Post#1662519
    In response to bowtieollie
Thanks for the information.
Chevy Camaro 2007 H11 HID Bulbs
Execution time: 0.159 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:41 PM
