Join the Community today
Username Post: Temperature gage bulb        (Topic#202168)
10-30-08 06:03 PM - Post#1553646
Stock 1947.
I tried to remove the bulb from the head, but after I removed the nut, the bulb seems to be stuck. I pulled a little bit with a pair of plyers, but it wouldn't come out. Afraid I might break it off. I sprayed some Kroil in the hole and am letting it set. Hope to break it loose. The tube has been cut when the PO removed the dash.
Any ideas?
29-41, 42-48, 49-54 Moderator
DECEASED
10-30-08 06:20 PM - Post#1553663
If the tube has been cut, you aren't going to break the gauge any worse than it already is now. Assuming you are planning to re-use the head, you don't want to risk damaging the seat that the bulb seals against. Try drilling a hole in the bulb and use a screw extractor on it.
A gauge repair outfit will be able to put a new tube and bulb on your present dash unit if you can't find a replacement.
Edited by David Hayward on 10-31-08 01:06 AM. Reason for edit: No reason given.
10-31-08 05:03 PM - Post#1554300
Went out this afternoon and tried the plyers again and it popped right out. Guess the soaking worked. Going to put an aftermarket mini gage set up on it for now. Need to referbish the stock gages I have.
Thanks for your comment raycow.
gary635g
gary635g
Loc: Oldtown Idaho Yuma Az
Reg: 10-28-09
04-24-10 05:31 AM - Post#1903919
Typical problem a friend recently had the same condition the bulb had to be drilled to get it out causing loss of either or alchol.he found one from private party ~$60 I do see used and NOS on e-bay now and then.
Execution time: 0.125 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:13 PM
