 Page 2 of 2 <12
Username Post: 6V to 12 VOLT CONVERSION        (Topic#196833)
prowler
prowler
Loc: Port Alberni B.C.
Reg: 01-15-12
02-01-12 08:29 PM - Post#2186151
    In response to Rukee
Im doing the same dance right now myself. I origianly was givin a vr 4 voltage reducer, but couldnt figure it out, so now I am oredering a Runtz diode type reducer. There are directions online for it, and it looks very simple and is the one most guys are using I think. I also have a 12 volt conversion thread going you might find some helpfull stoff on.
52 Chev Styline. Now running a 250/TH 350 with a 2.77 rear end. Daily driver / work in progress
Rukee
Reg: 02-01-12
02-02-12 12:27 PM - Post#2186376
    In response to prowler
Do you have any links to the product and instructions?
prowler
prowler
Reg: 01-15-12
02-02-12 02:35 PM - Post#2186416
This is the one. I havent installed it yet, but will soon....
http://www.speedwaymotors.com/Runtz-12-Volt-to-6-V...
Rukee
Reg: 02-01-12
02-02-12 05:37 PM - Post#2186484
Wow, that's alot cheaper then the NAPA IR1 which is over $50.00. Where exactly does that thing wire in?? Like I said, I can hardly see anything trying to look up from under the dash. To the left of the steering column I see a bunch of wires on some sort of connecting block, can I wire it in there somehow?
Thanks for your help by the way.
prowler
prowler
Reg: 01-15-12
02-02-12 08:51 PM - Post#2186578
No sweat. if you open the hood and remove the voltage regulator, you can remove the plate that the regulator is mounted to, and that will give you easier access to the backside of the dash. have a look at my thread, "converting a 52 to 12 volts" and there is a couple of pictures there that show what I mean. this diode wires directly in line to the fuel guage. Split the power wire to the guage and splice it in, and the ground it somewhere with the black wire, and your done..
Rukee
Reg: 02-01-12
02-03-12 08:36 AM - Post#2186679
I'll have some work to do then, this `49 has a power brake booster and master cyl attached to that plate.
Thanks!
prowler
prowler
Reg: 01-15-12
02-03-12 06:07 PM - Post#2186860
oh yikes! You will be better off hiring a 6 year old to climb under the dash with an instruction sheet and a flashlight!! Hahaha..
gjwach
Loc: Central PA
Reg: 02-02-12
02-06-12 08:19 PM - Post#2188008
Can an 54 Autronic eye headlight dimmer be coverted into a 12 volt system and what would be needed to operate the original power seat option in a 54 chevy being converted over to 12 volt from 6?
Thank you,
Greg: 54 Red & White (well will be someday) Hardtop being done as original (except 12 volt and disc brakes) and loaded with options (i.e. original pwr steering, pwr seats, autronic eye, sunvisor, spot light, acc lighting and a continental kit)
02-07-12 05:40 AM - Post#2188081
    In response to gjwach
Hey Greg!!! See they made you start from 0 on the number of posts. Glad to see you back!!
gjwach
Loc: Central PA
Reg: 02-02-12
02-07-12 07:59 AM - Post#2188125
    In response to Bob_Hayden
Its only fair to start me back at zero since I let my job keep me away so long. But I am happy to be back as well both here and getting back to work on my hardtop and house projects.
49Stovebolt
Loc: NE Florida
Reg: 11-27-12
12-08-13 02:28 PM - Post#2405939
    In response to ralph47
Is the 6V starter normally used when going to 12V? Are any alternatives available?
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
12-10-13 05:44 AM - Post#2406374
    In response to 49Stovebolt
Yes, the 6V starter is commonly used. Just don't crank it too long at a time.
Dean50
Loc: Hendersonville, N.C.
12-11-13 08:42 AM - Post#2406705
  • Rukee Said:
Hey guys, first post, please bare with me.
Have a `49 Deluxe 4dr here that someone put in a 350 csb w/single wire alternator. Trying to convert the system to 12v, have all the bulbs swapped but don't know were to put the reducer for the gas gauge. I can hardly see behind the dash at all!! Is there a convenient location to wire it in?? Also the parts list showed a IR4 from NAPA for the gas gauge, but it's discontinued, they gave me a IR1 instead, is that going to be an issue?
www.NAPAonline.com
Don't understand this post. If poster is running a 350 sb with a 1 wire alt., how is he running anything but a 12 volt system?
Mcloud
Loc: NY
Reg: 12-02-14
02-08-15 08:45 PM - Post#2521706
    In response to bobg1951chevy
Perhaps a better alternative to the 6 volt-12 volt issue can be found at Randy Rundle's fifthavenueinternetgarage .com. Interesting catalog, too. Their 6 volt alternator has a built-in solid state regulator, greater output, ability to charge at idle, and eliminates of the constant charge-discharge battery cycling. Add their ignition coil with internal resistor that eliminates the old troublesome ballast resistor, and you have a more reliable car. Apologies if I sound like a salesman for the guy, but it makes sense to me.
1950 Styleline Special, 216, 3-On-Tree, stock. 1955 Bel Air, stock V8.
WGS53
WGS53
Loc: Culver, Oregon
Reg: 10-21-13
07-16-15 01:04 PM - Post#2562192
    In response to Mcloud
Just did this conversion. All went well except that car would not shut off. PROBLEM: DA plug. In all of the articles I've read on this, after conversion, only one (can't remember which one now), mentioned that the DA plug MUST have a diode wired into yellow (white) wire. You can not just go to the parts store, as I did and get the right plug. I ended up with the DA wiring harness from Speedway w/diode, Now all works fine.
1950 Styleline
1953 Chevy 150 4dr
1978 Camaro
2003 Ford F350 7.3
 Page 2 of 2 <12
Execution time: 0.098 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:45 AM
