Anonymous
10-11-02 04:02 PM - Post#129444
What am I supposed to torque down the pan bolts to on a TH400 and also what order? Also for the cooling lines on a 400. Which is the feed and which is the return? I think the return is the upper one... please correct me if I'm wrong. Thanks in advance![This message has been edited by aomega13 (edited 10-11-2002).]
78_monte
Loc: NY
Reg: 09-13-02
Re: How much torque and order of TH400 pan bolts? 10-11-02 04:09 PM - Post#129445
In response to
On any Auto trans I just tighten the pan bolts in a stagered pattern and just snugg um. Don't want to Dimpple the pan around the bolt hole or it'll leak like a sive.Go oer it a few times cause the first ones you tighten will be losser as you tighten more.
| 1978 Monte Carlo 350/8.6:1/993 casting 1.94s/Schneider cam 218/224 460/480/TH350 shift kit 2600 stall/3.42posi
Old motor 14.55@95mph |
Anonymous
Re: How much torque and order of TH400 pan bolts? 10-11-02 04:18 PM - Post#129446
In response to 78_monte
My 700r4 required 91 Inch Pounds. Don't know if this will help but it can't be far off of this I wouldnt think.
Anonymous
Re: How much torque and order of TH400 pan bolts? 10-11-02 07:38 PM - Post#129447
In response to
Hey there, According to my handy-dandy TH-400 repair manual, torque the pan bolts to 144 INCH-LBS. I have always installed the bolts starting with one on each side and then fill in by alternating sides.
Chuck_R
Reg: 10-05-02
Re: How much torque and order of TH400 pan bolts? 10-12-02 12:18 AM - Post#129448
In response to
The top is the return you are correct! 144 inch pounds/12 ft pounds
Anonymous
Re: How much torque and order of TH400 pan bolts? 10-12-02 03:26 AM - Post#129449
In response to Chuck_R
Thanks for your quick replies![This message has been edited by aomega13 (edited 10-12-2002).]
