Join the Community today
Username Post: rear disc brakes        (Topic#196001)
jermsjunk
jermsjunk
Loc: Indiana
Reg: 08-21-04
08-08-08 07:53 PM - Post#1495275
Has anyone put rear disc on their trucks. I see classic performance sells a kit for $500 and I dont think its that important. But if someone knows a way to fabricate this using easily replaced parts from auto zone I might try it. Anyway any info will help. Thanks everyone
kevindtimm
kevindtimm
Loc: Cedar Park, TX
Reg: 11-09-04
08-11-08 08:51 AM - Post#1496825
    In response to jermsjunk
It seems to me (IMHO) that rear disks are PROBABLY overkill for 90% of these trucks. If I had the option to get a CHEAP rear axle that would fit and had disk brakes, yes I would do it. Otherwise no.
Again, just my $.02
2008 Equinox LS - My only Chevy right now
Vaughn
Member #455 "15th Year" Gold Supporting Member
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
08-11-08 11:49 AM - Post#1496963
    In response to kevindtimm
Braking force - in general - is distributed between the front and rear axle at 70 percent at the front, 30 percent at the rear.
All the vehicle manufacturers know this, so they almost always use disks in front, drums in rear - because that is all that is truly needed. In addition, it's harder (more expensive) to put an emergency brake setup on a rear disk brake than to do it on a drum setup.
It is rare that you will need the extra braking force that rear disks can provide. Rear disk brakes are usually only used in racing applications or in lifted vehicles with larger tires (that need all the extra braking force they can get).
Carguy1965
Loc: Georgia
Reg: 02-25-08
08-11-08 05:40 PM - Post#1497208
    In response to Vaughn
You dont really need it for the braking.. Thats for sure.. Only real reason is you want the look etc.. I can understand that on a show truck for sure. Probably the cheapest way to do it would be a rear axle swap..I think I have seen some threads on here about that before.. Get one with the brakes on it already and all you have to do is fab up the lines and e brake cables...
2007 Z06
DD 2007 Avalanche
1965 BB Impala SS ( Now Gone to a New Home )
1931 Reo Royale Project Coupe
LT1BURB
Loc: Roseburg Oregon
Reg: 01-06-05
08-11-08 06:45 PM - Post#1497268
    In response to Carguy1965
I have a TSM kit on my truck and it stops on a dime.
Execution time: 0.171 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:52 PM
