Username Post: driveshaft length 58-64        (Topic#189700)
Sal
Reg: 05-18-07
05-16-08 11:07 AM - Post#1434383
I am converting a powerglide driveshaft to 4 speed muncie,I know the front section is shorter,can somebody post the dimensions and a picture showing where to measure it? anybody using the heavy duty billet center support bearing?
thanks
Sal
Edited by bowtieollie on 11-23-09 06:49 AM. Reason for edit: No reason given.
DECEASED
05-16-08 01:54 PM - Post#1434496
    In response to Sal
This question comes up often enough that I saved the info offline. It's a lot faster than trying to run a search for it on the forum. I'm still hoping the moderator will put it onto a sticky.
Note that this is for 59-64 only. If you have a 58 the shaft will be shorter.
Lengths of FRONT driveshafts
4-speed & 3-speed w/OD = 24 5/8"
3-speed & 59-61 Turboglide = 29 3/4"
Powerglide = 26 13/16"
Measurement is tip to tip length with front shaft completely disassembled.... front U-joint and slip yoke removed, center U-joint flange and center bearing removed.
To be on the safe side, remove your old shaft and measure it before cutting to see where (or if) you get the 26-13/16" dimension.
Updated 03/23/15
58 only info
Passenger car (exc O/D and P.G) 25 15/32"
(with O/D) 20 5/16"
(with P.G) 22 17/32"
58-64 Rear shaft 36 1/2"
Edited by bowtieollie on 03-23-15 02:15 PM. Reason for edit: No reason given.
Sal
Reg: 05-18-07
05-16-08 06:25 PM - Post#1434690
thanks for the inf; now help me understand how to measure it:is it from end to end or from center of u joint to u joint? could post a picture to make sure I dont mess up
thanks
DECEASED
05-16-08 09:45 PM - Post#1434787
I didn't write that. I just saved it. My reading is that you remove the rear yoke so you can measure to the end of the spline. You do not have to take off the front yoke, but don't include it in the measurement. That's why you need to check the 26-13/16" dimension on your own shaft - to find out where it was measured from.
DECEASED
12-07-08 11:22 AM - Post#1579532
    In response to Gusaroo
The OD/4-speed shaft was made in comparatively small numbers and will be priced accordingly if you are lucky enough to find one at all. It will almost certainly be cheaper to have your own (or a salvage yard) shaft cut to the length you need.
bowtieollie
Member #3 ChevyTalk Subject Matter Expert
bowtieollie
Reg: 12-06-99
12-07-08 06:24 PM - Post#1579817
    In response to Sal
HI Sal,
As Ray recommended, its a better deal to cut your old shaft. (read that as cheaper)
Ray - the post is now STICKY!
Bowtieollie
Chevytalk.com Moderator
DECEASED
12-08-08 01:35 AM - Post#1579993
    In response to bowtieollie
Ollie, thank you ever so much.
58 Del-pala
58 Del-pala
Loc: Durham, NC
Reg: 05-03-03
12-08-08 07:19 AM - Post#1580055
I had my shaft shortened for under $100 with new u-joints installed.
My Picturetrail
DECEASED
12-08-08 11:50 AM - Post#1580229
If you don't want to cut your original shaft, you could buy another one to modify. They are not expensive or hard to find.
http://cgi.ebay.com/ebaymotors/Impala-X-F rame-Driv...
On the other hand, once you try the 4-speed, I don't think you will ever want to change back.
doubleE
Loc: Eagan MN
Reg: 06-02-03
12-08-08 05:42 PM - Post#1580494
The 4-spd gods will smite me for this but after driving my 62 with the T-10 for the last 3 years, I've considered changing over to a automatic overdrive tranny . Bare in mind my daily driver is a 97 Saturn SC2 with a 5 speed so I get my fill of shifting every day!!!
It would be nice to pick up a few MPG with the overdrive too .
Eric
Kdurgin
Kdurgin
Loc: Maine
Reg: 10-28-07
12-08-08 06:39 PM - Post#1580577
    In response to doubleE
Good Lord...... Don't let Tom read this.
62 Impala SS 383 Small Block, Tremec TKO 600, 3.70 gears. Black.
1965 C-10 SWB BBW Fleetside Black.
2003 100th Anniversary Harley 2 tone Silver and Black Road King.
Gusaroo
Gusaroo
Loc: Glastonbury CT
Reg: 09-28-06
12-08-08 07:13 PM - Post#1580612
    In response to Kdurgin
Take a look at the New Process A833 RPO code:MY6 tranny. Thats what I am using. 4 speed OD, same size as the T10 and same gear ratios as a 700R4 (but a manual)
1931 Chevy Independence 2 door coach/sedan.
DECEASED
12-11-08 01:50 PM - Post#1582690
  • Gusaroo Said:
The guy measured it and it is a 4 speed shaft
Who says miracles don't happen any more? You must live right. Congrats!
DECEASED
12-11-08 02:02 PM - Post#1582698
Well if you are going to run it hard you should probably get a telescoping rear shaft. You will have a lot fewer problems with the bearing support that way.
Bryan59ec
Bryan59ec
Loc: San Antonio, Texas
Reg: 06-24-07
12-23-08 06:07 AM - Post#1591009
    In response to SmooveP
When I had the shaft cut for the TKO in my car.
Measured the length of the 3-spd from the bellhousing to the end of the tailshaft.
Made the same measurement on the TKO.
The TKO was (IIRC) 8" longer than the 3-spd.
So---that is wnat I took from the front shaft.
Bryan's Toyz
59 ElCamino, 454ho/TKO 5-spd (Daddy)
66 ElCamino, 307/5-spd and gets 25mpg (Mousey)
65 Ranchero, 289/4-spd--my uncle bought new (Old Blue)
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
01-25-09 05:00 AM - Post#1615159
try speedway atuto parts they sell different lenth
Jerry Acheson
Jerry Acheson
Loc: Green Oaks, IL
Reg: 12-30-00
03-13-09 02:12 PM - Post#1650649
    In response to arnieg141
I started with a 59 Sport Coupe with 283/Powerglide. I installed a 98 350 RamJet with 700R4. We had to cut 5 1/2" off the front shaft on the driveshaft. Hope that helps.
Jerry
micke
Loc: Sweden
Reg: 01-02-08
09-21-09 08:10 AM - Post#1775614
    In response to Jerry Acheson
Anyone.....how is it lenght between th350 or th7oo is it any differens??
speedygman
speedygman
Loc: Gorgeous Georgia
Reg: 06-27-08
09-21-09 03:13 PM - Post#1775788
    In response to micke
Go look at TOPIC Transmission Dimensions
Speedygman (Grady)
http://www.picturetrail.com/sfx/album/view/204855 0...
Biscayne Stocker
Loc: Pasadena, Md
Reg: 11-14-09
11-16-09 02:51 PM - Post#1806916
    In response to speedygman
Showcars automotive sells all the correct front drive shafts for four speed and automatic.
Scott Chalk
1959 Impala Convertible
283 290h.p. Fuel Injected 4 speed
58 yeoman
Reg: 12-10-08
04-29-10 05:01 PM - Post#1907081
    In response to Biscayne Stocker
just on the show carts site, and am not understanding the pictures. front drive shaft. http://www.show-cars.com/cgi-bin/commerce.cgi?prea...
rear drive shaft.
what connects the front shaft to the trans then?
am i really that dumb?
'58 YEOMAN 4 door. 283/glide for now. silver blue and snocrest white.
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
04-29-10 07:47 PM - Post#1907188
    In response to 58 yeoman
rear drive shaft.
The yoke would attach to the U-joint. The slim end would have the Center Support Bearing.
Edited by Techhead on 04-29-10 07:52 PM. Reason for edit: No reason given.
Gusaroo
Gusaroo
Loc: Glastonbury CT
Reg: 09-28-06
04-30-10 01:06 PM - Post#1907563
    In response to Techhead
...uh those pics dont look right to me either. The front shaft they are selling is only half of the front drive shaft assembly (which is two pieces). It is missing another short yoke piece.
Gusaroo
Gusaroo
Loc: Glastonbury CT
Reg: 09-28-06
04-30-10 01:08 PM - Post#1907566
wait...I think I have that backwards...the rear driveshaft is two pieces...now Im confused
karrz
Reg: 12-21-10
12-21-10 10:19 PM - Post#2021251
I'm restoring a 58 Wagon and replacing my 3 speed manual with a 63 aluminum powerglide.Can I use my existing driveshaft and yoke?If not, I need to get a 59-64 front shaft? I see theres 1 inch difference with the numbers you have shown. Also why are the 58's different from the rest when it comes to the front shaft lenght? thanks
ElkyBob
ElkyBob
Loc: Tenino Washington
Reg: 05-19-03
06-05-12 09:10 PM - Post#2233896
Yeah, for sure, was watching the Doctors TV show this morning and they were talking about injections to make the shaft bigger!!! Ouch.
59 Elky w/348 & 5 spd
62 Corvair Monza Conv w/102 & 4 spd
87 Elky w/350
00 Ford F150 p/u w/5.4
05 Chrysler 300C w/5.7 Hemi
DECEASED
07-11-14 12:30 AM - Post#2468195
    In response to karrz
Your 3 speed front shaft will be too long, but the 63 X-frame aluminum PG is the same length as a stock 58 cast iron PG, so a stock 58 PG front shaft will be the right length for it. 58 shafts are shorter than 59-64 because the 58 wheelbase is shorter than 59-64.
I realize that this answer is about 3-1/2 years late, but I figure other members may still find the info useful if they are working on a 58.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
07-11-14 04:36 PM - Post#2468348
I always cut and weld my own. I cut on the end without a weight and try to keep the weld even all the way around. never had a problem.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
ShortyLaVen
Loc: Minneapolis, MN, and Phoe...
Reg: 01-23-18
03-05-18 04:47 PM - Post#2726547
    In response to Sal
Might be a dumb question, but would the length of the four speed shaft listed here be correct for an M21? I know they came out in '63, but not sure if hey are the same length as the earlier 4 speeds (T10?). I know the Muncie would be close to same as other 60s/70s T10, Saginaws, etc... I don't know much about late 50s/early 60s trans.
ozzie7
ozzie7
Loc: Central Ohio
Reg: 03-11-16
03-21-18 10:19 PM - Post#2728473
    In response to ShortyLaVen
The Muncie's (M20, M21, M22) 1963 through 1970, that were built to accommodate the
higher torque/HP of that era of big blocks, are the same length as the T-10's they replaced.
Those T-10's were made from 1957 to 1963 and were mostly not able to meet up to the high torque/HP needs
of some of the big block chevys of the '63 to '70 era... mostly.
Even some Special High Performance '59 through '62 engines were also too much for the T-10's.
Starting in 1971 and going through to 1974, the Muncie's were longer by 3/4".
The Super T-10's (second design for passenger cars) came out in 1974 and went through 1982 to
accommodate the lower torque/HP needs of that era of big blocks and they are the same length as the 1971-74 Muncie's.
The Muncie's production was discontinued after 1974.
The Saginaws were made mostly for the lower HP 4 cyl, 6 cyl and V8 small blocks... mostly.
That's the info I've dug up so far during my research leading up to getting a Muncie.
I'm putting a 1968 M20 in a 1959 Impala right now, and the lengths check out with the info at the top of this thread.
I purchased this front drive shaft for the conversion from a 3 speed:
Muncie and T-10 Drive Shaft
Execution time: 0.232 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:56 AM
