Username Post: 80 Caprice        (Topic#180045)
txturbo
Loc: Rosenberg,TX USA
Reg: 07-27-01
01-19-08 05:31 PM - Post#1346662
What V-8s and transmissions were available in the 80 Caprice? Were these all 305s and 2004R?
Dan
1969 Camaro SS 396/T400
1966 Impala 283/PG/AC
1966 Impala SS 427/4 Speed
1948 Panel 1 Ton
1963 Cadillac
1940 Ford P/U
1954 Chevy 3100
1955.2 Chevy 3100
1956 Cadillac CDV PINK
1930 Model A hot rod
artak
artak
Reg: 05-22-05
01-19-08 11:47 PM - Post#1346828
    In response to txturbo
229 V6 (sawed 305)
305 V8
267 V8
350 V8 Olds Diesel
California:
231 V6 Buick
305 V8
350 V8 Olds Diesel
Transmissions were only 3-speeds, probably 250s and 350s.
2.73:1 on V6s
2.41:1 on V8s
2.56:1 on Wagons
Casting Numbers
txturbo
Reg: 07-27-01
01-20-08 06:54 AM - Post#1346895
    In response to artak
Thanks.....I thought I had found a good deal. Was hoping the car I found with a fresh rebuilt motor and transmission was a 350 with an OD trans so I could swap it into my wifes 66 Impala. But after seeing the HP rating of the 305, I would be swapping in less HP. Guess I'll pass on it.
Dan
1948 Panel 1 Ton
1963 Cadillac
1940 Ford P/U
1954 Chevy 3100
1955.2 Chevy 3100
VintageCarryall
Loc: Arizona
Reg: 10-08-06
02-02-08 12:47 PM - Post#1356889
First year of the 700R4 was 1983 for passenger cars (1982 Corvettes only). Not sure about the 200R4 admittedly.
Supposedly; the 1986+ 700R4's are stronger.
txturbo
Reg: 07-27-01
02-03-08 09:10 AM - Post#1357384
    In response to VintageCarryall
yeah the 700r4 had lots of problems the first several years.But these days they rebuild all 700r4s to eliminate the past problems.Most of the rebuild kits come with the instructions and parts to fix most of the early problems and hard parts are available to update the weaker early versions. I found another one that I'm checking out today. It's an 83 wagon.
Dan
1948 Panel 1 Ton
1963 Cadillac
1940 Ford P/U
1954 Chevy 3100
1955.2 Chevy 3100
Execution time: 0.132 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:36 PM
