Username Post: Head gasket or valve cover leak?        (Topic#179344)
Capr87Elco70
Loc: New York
Reg: 06-24-02
01-11-08 01:57 PM - Post#1340476
What's more common for a leak, the head gasket or valve covers? I've got quite an oil leak coming from somewhere on the top of the engine (can't quite see yet, it's tight in there)and it's running down on the exhaust crossover pipe. I would think that if the head gasket leaked it'd be pretty serious.
-Shawn-
1965 Olds F-85 Deluxe
1983 Olds 98 Regency Brougham
1987 Caprice Landau Sport Coupe
1970 El Camino RIP 1-1-05
artak
artak
Reg: 05-22-05
01-11-08 03:18 PM - Post#1340525
    In response to Capr87Elco70
Bet on valve covers. It is a weakness in the older small blocks. You would notice a head gasket in how the engine runs.
Casting Numbers
Capr87Elco70
Loc: New York
Reg: 06-24-02
01-11-08 04:20 PM - Post#1340572
    In response to artak
That's good, it's easy enough to replace them. It sure is making a mess on the garage floor, I never knew they could leak so much even with the engine off. I haven't started this car in a few months now and the puddle grows!
-Shawn-
old_koon
Loc: La Quinta, CA
Reg: 06-02-07
01-11-08 06:46 PM - Post#1340692
The head gasket seals compression and coolant, not oil. Oil is supplied to the upper engine thru the pushrods. Another possibility would be the intake manifold end seals or maybe the oil pressure sender/switch The best thing to do is clean all old residue and then find exactly where your leak is.
Good Luck, Don
Execution time: 0.057 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:48 AM
