 Page 2 of 2 <12
Username Post: Common Mistakes and tips        (Topic#177647)
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-29-12 02:38 PM - Post#2293450
    In response to Todd W. White
after the first 300 miles I generally run just a good quality standard petroleum base or synthetic premium oil and a quart of marvel mystery oil which is just a high detergent oil itself that Ive found works well, added to the other oil, theres a great deal of info on the oil quality in the links, a good quality oil already has all the additives needed if its changed frequently, but adding the ZDDPlus probably won,t hurt anything but your wallet.
Todd W. White
Todd W. White
Loc: Sapulpa, Oklahoma
Reg: 02-08-08
11-30-12 12:11 PM - Post#2293749
    In response to grumpyvette
Thanks again GV.
Our local speed shop, which has been around for 50 years, sells "Brad Penn" break-in oil for about $6 a quart. After looking at their website (link below), I see that theirs has ZDDP in it - should I add some to the break-in oil in addition to what's already in it?
Link:
http://www.penngrade1.com/products/High-Perform anc...
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-30-12 02:52 PM - Post#2293810
that oil is fine as is
Edited by grumpyvette on 02-29-16 06:40 AM. Reason for edit: No reason given.
Todd W. White
Todd W. White
Reg: 02-08-08
12-01-12 12:25 PM - Post#2294075
THANKS!
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
01-18-16 07:28 AM - Post#2602943
    In response to PhatOne
With the recent (OK, 10-15 years) popularity of GM Vortec heads, I want to add this:
The GM Vortec heads (casting number 062) I bought new in 2015 have the exhaust ports raised approx .100"-.120" on the head relative to the manifold/header bolt holes. That means on most all cast iron manifolds (and on some headers) the gasket and/or sealing surfaces will cover up the top of the ports. And that's exactly where exhaust gas flow is the most intense!
Bottom line: Be sure to use a template or a gasket to ensure your header/manifold flanges and/or gaskets don't cover up the tops of the raised Vortec exhaust ports.
Here's an OE type gasket on stock GM Vortec head casting no. 062. You can where the ports are located relative to the bolt holes -- higher than on pre-1996 conventional head.
I used this Fel Pro gasket instead:
And I had to raise the openings on a pair of cast iron manifolds. Obviously, you'd be limited on how much material you could remove from headers. The good news is there's lots of gasket surface area on the heads.
heidi
Reg: 06-14-16
06-19-16 04:10 PM - Post#2634884
Not having a clean work area,you don't need dirt and debri in a rebuilt engine.Before I start,the area gets cleaned good free of dirt and debri.I learned this from a long time engine builder.Not cleaning bolt holes out good with a rethreading tap and die set.Follow the torque specs and don't jerk on the torque wrench after hearing the clicking noise with a clicker type torque wrench.A false torque reading is the result of jerking on the torque wrench after hearing the clicking noise.Double check your work too.
 Page 2 of 2 <12
Execution time: 0.168 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:41 AM
