44 Years of Service
Username Post: Disc brake offset list!!        (Topic#165598)
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
07-25-07 09:28 AM - Post#1216493
This is a list of wheel offsets for the 55-57 cars. All measurements where taken from the wheel mounting surface to the center of the lower ball joint using a surface plate and height gauge. Many companies claim different measurements for the exact same rotor and spindle combination. If in doubt, ask which brake rotor they are using.
0.0 CPP drop spindle = No change in track width. Minimum wheel: 14” disc type.
+3/8” O.E. spindle with narrow hub and CPP 13” rotor = 3/8” wider per side. Minimum wheel: some 16” all 17”.
+3/8” O.E. spindle with CPP “Zero Offset” 10.8” rotor = 3/8” wider per side. Minimum wheel: 14” disc type.
+7/8” O.E. Stock spindle with standard hub and CPP13” rotor = 7/8” wider per side. Minimum wheel: some 16” all 17”.
+7/8” O.E. Stock spindle with standard 11” rotor (common Chevelle rotor) = 7/8” wider per side. Minimum wheel: 14” disc type.
+7/16” O.E. spindle with ECI “Zero Offset” 10.5” rotor = 7/16” wider per side. Minimum wheel: 14” disc type.
+3/16” Heidts drop spindle with 8215 rotor = 3/16” wider per side. Minimum wheel: 14” disc type.
+7/8” Heidts drop spindle with CPP 13” rotor = 7/8” wider per side. Minimum wheel: some 16” all 17”.
Thanks,
Aaron @ Classic Performance
www.classicperform.com
aaron@classicperform.com
800-522-5004
Edited by Tony on 10-12-07 09:52 AM. Reason for edit: Made a sticky post
cowfarmer350
Reg: 02-03-01
09-16-07 10:57 PM - Post#1255169
    In response to cpptech
Aaron.....can you make a list like this for 58-64 , stock height , seems most of them are over 1" per side.......thanks
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
09-17-07 08:20 AM - Post#1255377
    In response to cowfarmer350
The 58-64 shares these 3 measurements as the 55-57.
Thanks,
800-522-5004
cowfarmer350
Reg: 02-03-01
09-21-07 04:24 PM - Post#1258654
how much does this kit affect the wheel and would you have better braking compared to the 10.8" zero offset kit, i have 16" ralley wheels and trying to get the largest brake with least offset , i can't use the 13" kits
5564WBKP12 1955-64, 12" Front Big Brake Kit
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
09-24-07 06:03 AM - Post#1260107
The 12" kit is not being made. Only the 13". These do fit some 16" wheels. But fit a 17" for sure.
Thanks,
800-522-5004
19ELVIS55
Lurker
Loc: Phila ,PA
Reg: 12-21-08
12-21-08 11:37 AM - Post#1589701
Need help. My 55 Nomad has stock drums up front. I want disc ,but no offset at all if possible. I have 15x7 Cragers with a 3/3 offset. I'd like a 1 peice rotor and hub set up . What kit do I use or what are my options? Also most kits I have seen have no backing plates. Why? Also I dont want to use drop spindles.
How fast is FAST ENOUGH ? It's that fine line between out of controll and dangerous.
1955 Nomad (Named Elvis) under construction
Edited by 19ELVIS55 on 12-21-08 11:39 AM. Reason for edit: No reason given.
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
12-22-08 07:39 AM - Post#1590342
    In response to 19ELVIS55
5564wbk-s0 is the minimum offset kit. Only 3/8" per side. Narrowest kit on the market.
Thanks,
800-522-5004
58IMPALACON
58IMPALACON
Loc: Harpenden, Herts,Great Br...
Reg: 11-06-01
01-11-09 09:02 AM - Post#1604342
For 1958-64
"0.0 CPP drop spindle = No change in track width. Minimum wheel: 14” disc type."
WARNING: This is blatantly untrue
Following a lengthy forum discussion a year ago it was established by fact and backed by senior chevytalk members that the track for 1958 models would be increased by 2 1/2" using the CPP drop spindle.
CPP have made the mistake of assumming that 1958-64 front spindles were the same when in fact the 58 model year spindle is entirely different and produces a track 2 1/2" narrower than the 1959-64 model years.
It is very important that 1958 owners are made aware of this as the options for wheel fitment are severely limited whilst using the CPP drop spindle - even more so when used in conjunction with air suspension.
I hope this helps all 58 owners considering this modification.
Regards Paul
58 Impala Convertible. Rebuilt 327 and turbo 350. Air suspension. Dropped spindles.
Disc brakes. Continental kit - painted in Cay Coral. Runs like a top.
RSB
RSB
Loc: San Jose, CA, USA
Reg: 06-21-00
03-15-09 01:12 PM - Post#1652292
    In response to 58IMPALACON
What is the wheel offset when using the new 5557SWBK-D12 kit? Is it the same zero offset spindle or something new?
Thanks,
Ron
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
03-16-09 06:33 AM - Post#1652914
    In response to RSB
3/8" per side.
Thanks,
800-522-5004
557B210
557B210
Loc: Jacksonville
Reg: 06-15-08
11-04-09 06:12 AM - Post#1799368
Aaron....I was going to post this info at TriFive...However, since you are a sposor there as well, would you like to do it?
david aka POPS
55/57 2DR B210
Execution time: 0.139 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:55 PM
