 Page 2 of 3 <123
Username Post: The Dead Horse: V8 Swapping        (Topic#149142)
ralph47
ralph47
Loc: new franklin, ohio
Reg: 10-28-08
02-03-09 07:33 AM - Post#1621648
    In response to gorilla1
hey guys..for those that have done the SBC in a 54, how much of the firewall fins did you cut..or leave? i have seen some completely gone..others with the upper part still there...pictures are good too...thanks..ralph
54 Chevy Handyman Wagon
48 Chevy Pick Up
39 Chevy Coupe
62 Olds F85 Cutlass Convertible
http://s370.photobucket.com/albums/oo148/ralph47_ p...
Bob_Hayden 74
02-04-09 06:05 AM - Post#1622314
    In response to ralph47
You can look at my pics and see how much I cut off of mine. I am in the process of pulling the engine to smooth the firewall. Wish I had removed all of them when I built the car to begin with. LOL
ralph47
ralph47
Reg: 10-28-08
02-04-09 06:41 AM - Post#1622327
    In response to Bob_Hayden
Bob..thanks again...always a help..as i look at your pictures..a couple of more questions pop up..OT of course..sorry all..first..i see 2 different ways you ran a/c and htr hoses..outside fender well and inside..whey the changes? 2nd, who did your interior and door pads? whose a/c did you use..trying to find interior pics of it..lastly...i am trying to find the stainless/chrome trim on your door pads..was that replacement? thanks again..sorry for the OT posts...
Ralph
48 Chevy Pick Up
39 Chevy Coupe
Bob_Hayden 74
02-04-09 09:50 PM - Post#1622946
ralph47, Email me those questions and I will be glad to answer them for you. Not sure what you are asking.
ralph47
ralph47
Reg: 10-28-08
02-05-09 07:43 AM - Post#1623076
will do Bob
48 Chevy Pick Up
39 Chevy Coupe
bonestheripper
bonestheripper
Reg: 07-13-09
09-28-09 03:57 PM - Post#1779828
Hey fellas,
Have a couple questions and hopefully you guys can help.
i have a 1950 chevy deluxe that i'm swapping to V8. I'm using a 350 SBC with a 700R4 trans behind it.
Question 1: i am able to get either a 68-74 Nova 10 bolt rear or a 64-67 Chevy II 10 bolt rear. Would either of these be useful for my application? i'm expecting to modify the perches if use one of these.
Question 2: for motor mounts, does it make a dramatic difference on whether weld-in mounts or bolt-in mounts are used?
thanks guys. sorry if you've answered these before.
Flamethrower Kit
In action
In action again
TPost
Loc: N. Stonington CT.
Reg: 07-26-05
09-28-09 05:13 PM - Post#1779882
    In response to bonestheripper
1. The stock rear end is 60" hub to hub. Measure the ones you have and go from there.
2. Either bolt in or weld in will work. I went with the bolt in ones from Chassis Engineering.
Todd
http://s84.photobucket.com/albums/k17/TPost50Chevy/
bonestheripper
bonestheripper
Reg: 07-13-09
09-28-09 09:57 PM - Post#1780033
    In response to TPost
the 68-74 rear is approximately 60 1/4" drum face to drum face. the 64-67 rear is approximately 57 3/4" drum face to drum face. is it safe to assume that the spring perches for the 64-67 rear will line up to the spring perches on the 50 chevy?
Flamethrower Kit
In action
In action again
bonestheripper
bonestheripper
Reg: 07-13-09
09-29-09 04:00 PM - Post#1780360
correction: 68-72 Nova/Camaro 10 bolt rear. 60 1/4" drum face to drum face.
Flamethrower Kit
In action
In action again
dgasfleetline
Reg: 02-23-10
02-23-10 09:43 AM - Post#1867933
Oops, I originally posted this in the parts and tips section... my bad!
Hey 'Cheese,
It's RileyRacing from that other board...
I wanted to tell ya Tardel has mounts that bolt to the front of the block and use biscuits- like an early Ford. That's another somewhat easy option similar to the Hurst style mount, but smaller.
Thanks!
JK
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
03-13-10 02:28 PM - Post#1879430
From experience; save yourself the headache, and breaking drill bits, and just weld them in. It does'nt take but a couple of short, strategically placed beads, to weld them in. My Sears Craftsman Buzz Box arc welder, I've had for 35 years, did the job just fine.Butch/56sedandelivery.
Edited by 56sedandelivery on 03-13-10 02:29 PM. Reason for edit: No reason given.
bart savage
bart savage
Loc: Nor Cal
Reg: 03-18-06
05-26-10 02:05 PM - Post#1921041
ok....did the swap....now i need a speedo cable from the stock gauge to the th350....
what can i use???
19IMnuts53
19IMnuts53
Loc: Regina Beach, Sask.
Reg: 09-21-08
05-26-10 03:39 PM - Post#1921080
    In response to bart savage
Bart
you should be able to use the stock cable. I did on my 53 business coupe and on my 49 sedan delivery.
no such word as "Can't" you either don't want to or are to lazy.
Bob_Hayden 74
05-27-10 05:52 AM - Post#1921328
    In response to 19IMnuts53
I did on my 54 also.
bonestheripper
bonestheripper
Reg: 07-13-09
05-27-10 02:24 PM - Post#1921509
does the same apply for a 700R4?
Flamethrower Kit
In action
In action again
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
05-27-10 05:13 PM - Post#1921580
Yes, I used the stock cable on my 700R4. Mike
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-28-10 02:06 AM - Post#1921756
    In response to Mike JW
if the stock one is a little short .order one from a same yr. pick up there sold 4 to 6 inch longer than car..chevy of 40's or filling station
53belair
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
05-28-10 04:52 AM - Post#1921782
No, and the 64=67 rear is way too short for the 50 chevy, and therefore the spring perches just don't matter. The later nova rear is almost exactly the same width as the original. The perches from a second gen camaro do, however, line up with the springs on the 50. The axle width will work, and it will only need minor modifications (redrilling for the alignment pin)
1953 Belair Sport Coupe,350/350/Fatman/Dako ta Digital/American Shifter/Southern Air/Ciadella Interiors
1967 Chevelle 396 Muncie
2010 Camaro II-SS
2011 Camaro Pace Car
2012 Tahoe
darkrider2
darkrider2
Loc: CA
Reg: 01-04-10
08-29-10 03:56 PM - Post#1968507
    In response to 53belair
This is a link I found pretty useful. It's for a SBC and auto swap with great pictures.
http://www.rodandcustommagazine.com/techarticles/0...
Edited by darkrider2 on 08-29-10 03:56 PM. Reason for edit: No reason given.
Fiddy3-210
Loc: Apopka, FL
Reg: 12-30-10
12-30-10 09:45 AM - Post#2024436
    In response to darkrider2
A lot of GREAT info here! I'm getting ready to swap mine out as well. Got a moderately built 350, 4-sp Saginaw and a 10-Bolt GM out of a 68 Camaro.
1953 Chevy 210 4 dr
350 SBC - Built
750 cfm Holley Double Pumper
Sanderson CC50 Headers
4-Speed Saginaw Tranny
68 Camaro Rear End
Triple Core Aluminum Radiator w/Fan
gearhead695456
Reg: 04-17-11
04-17-11 07:48 PM - Post#2078135
    In response to Fiddy3-210
Hey guys, great information here. I'm almost done swapping a v8 into my 1951 deluxe but the manifold on the driver side is giving me heck. The 80's truck log style exhaust would seem to be good choice however, one issue not discussed on any of the forums Ive read is using a pre '79 engine (in my case 305) with the oil dipstick on the driver side and the interference with the log style rear dump exhaust manifold. There is no room for the dipstick to go around the manifold even with a custom flexible dipstick. Im now on my forth set of exhaust manifolds with no luck. Here is what Ive tried so far: 80s truck log style, corvette rams horn, 69 and up SBC. Someone mentioned the 1956 chevy 265 manifold but the front dump causes interference with my engine mount. Any ideas? Thanks
04-17-11 08:09 PM - Post#2078150
    In response to gearhead695456
There was just a topic on this subject. Hope it helps.
29-41, 42-48, 49-54 Moderator
ChevyBro
Reg: 07-19-11
07-19-11 05:52 AM - Post#2115639
Sounds like am impressive projects. Can we see some pictures?
Dillrod
Loc: SE Kansas
Reg: 11-20-11
11-20-11 11:48 AM - Post#2159988
    In response to ChevyBro
Ok I've been looking throughout this forum for info on a V8 swap
I have finally got my hands on a nice 51 Yes it needs work but first on the project is installing a 64' 283 with a 350turbo or possible 700r4 if I can find one at a good price and rebuild it.
from what I have gathered if I find a late 70"s camaro I should be able to use the rearend with little modification and the front clip so I will have p/s p/b and V8 motor mounts and possible a/c parts if I wanna go that far.
I got a good lead on a 79 camaro sitting in a field it's a complete car so I will then have all parts I need.
Thanks for the info I new to site and really like everything I've seen on here
11-20-11 03:05 PM - Post#2160063
    In response to Dillrod
Welcome to CT. Good luck with your project.
Lots of help here and we love pictures.
Also go to My ChevyTalk at the top of the forum and fill out your profile, so we know where you are from.
Dillrod
Loc: SE Kansas
Reg: 11-20-11
11-20-11 03:37 PM - Post#2160070
Sure will thanks
Dillrod
Loc: SE Kansas
Reg: 11-20-11
11-21-11 03:49 PM - Post#2160431
What about an early 80 Malibu ? I found one for free with a runnig driving V6 auto I will have to do some measurements unless some on here already knows
boones
Reg: 06-24-11
03-10-12 11:04 PM - Post#2201044
I have been doing alot of research on using factory style exhaust manifolds during the V8 swap (stock steering). I see some folks have been able to make them work and others have not. I think some of this comes down to what motor mounts are used, how far back the motor sets and how high.
I am using a set of Walton Fabrication motor and tranny mounts. great quality but not sure they allow the motor to sit back far enough or high enough. I talked with the owner and he said he has never used his mounts with a stock suspension. I am using exhaust manifolds from a mod 80s PU (which I have had several people on various boards tell me will work).
For me the steering pivot arm when turning to the left is hitting the down pipe.
2 questions. what motor mounts are people using and has anyone shorten the draglink (not sure if that is what it is called but red item in picture below). can this been shortened up (to limit the angle the pivot arms has to swing when turning full to one side.
Edited by boones on 03-10-12 11:06 PM. Reason for edit: No reason given.
Mike JW
Mike JW
Reg: 01-19-06
03-11-12 12:52 PM - Post#2201225
    In response to boones
How about if you cut a notch in the mount.
dongc1
dongc1
Loc: Gatesville,TX
Reg: 10-07-09
03-12-12 06:38 PM - Post#2201736
I think he said the pitman arm hits the exhaust pipe, not the motor mount.
I used 90 Camaro manifolds and cut the downcomer off. i rotated it a little and leaned it back a little, welded it back on and everything works. It works better if you have a new manifold, welds better. A experienced cast iron welder can weld it for you.
51 Styleline 2dr Sedan
 Page 2 of 3 <123
Execution time: 0.226 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:43 AM
