Dee Dee Dinah
Loc: Lodi, California
Reg: 03-10-00
01-22-06 09:14 AM - Post#859321
A set of quick release tools for late model gm fuel lines and a/c line disconnects. ACETYLENE TORCH ADJUSTABLE LENGTH PUSH ROD ADJUSTABLE POINTER , Adjustable stand, for dial indicator Assorted pliers/vise grips Air compressor Air ratchet Allen wrenches ASK QUESTIONS ASSORTED FILES ASSORTED SOCKETS,OPEN AND BOX WRENCHES 1/2",3/8".1/4" DRIVE Ball joint press tools Ball joint separator forks Battery charger(full size shop type) Bench grinder w/ wire wheel Big huge screwdriver which doubles as a pry bar BORE GAUGE Brake spring pliers and retaining spring tool CAM BEARING INSTALLER CAM DEGREE WHEEL CAM HANDLE CARBIDE BURRS CC Buret Kit/PLUS STAND Checking springs chisels (assorted sizes/types) clamp for compressing calipers CLUTCH PILOT Coil spring compressors Compression tester COMMON SENSE CRANK SOCKETS Creeper Crows feet CYLINDER HONE DENT PULLER DEPTH GAUGE Dial indicator, Die grinder Differential Set-up Kit Distributor wrench DRIFT PUNCHES (assorted sizes/types) Drain pans all sizes Dremel tool set to cut rivets etc. DRILL PRESS Drop light (florescent preferred) Dwell meter for the older cars EASY OUTS ELECTRIC SOLDER GUN Electrical tape Engine hoist ENGINE LEVELER ENGINE STAND Feeler Gages FIRE EXTINGUISHER Flexible dwell key for point distributors FREEZE PLUG INSTALLER FUEL PRESSURE GAUGE Full set of assorted hammers all the way up to 5 lb hand held full set of tap and dies metric and standard Full set of torqze tip screw drivers and sockets male and female all sizes Full size vice Gasket scraper Gear Pullers GM disk brake caliper Allen key 3/8 and 5/16 Grease gun Harmonic balancer puller HARMONIC BALLANCER INSTALLER HONING STONE Jack stands and a 2 1/2 -3 ton full size service floor jack JEWELERS FILES LAPTOP COMPUTER Leakdown tester LIFTER BORE HONE LIFTER GROOVE TOOL LUIS TOOL Magnet MAGNETIC PICK UP TOOL MAGNIFYING GLASS MANUAL LUBE PUMP MICROMETERS MIG WELDER Mini Valve Spring Tester MIRROR Multimeter Normal screwdrivers all sizes NUT SPLITTER OIL CAN Oil filter and regular spin on filter wrenches. Oil filter wrench Oil Pump Primers ONE NEW SOLID LIFTER PB BLASTER OIL Pipe cutter PISTON RING COMPRESSOR Piston stop, Pitman arm puller Plasma cutter PLASTIC HAMMER Pneumatic chisel Pneumatic impact guns 3/8 and 1/2 drive Pressure bleeder for brakes PRY BAR PUSHROD CHECKER Putty knife Ramps Rear caliper piston turning tool REFERENCE MANUALS RIFLE CLEANING ROD AND BRUSHES FOR OIL PASSAGES Ring expander pliers RING GAP FILER Rochester idle mixture adjusting tool ROD BOLT GUIDES ROD BOLT STRETCH GAUGE SCAN SOFTWARE Sledge or mall hammer SMALL FLASH LIGHT Snap ring pliers internal and external SPRING COMPRESSOR Standard set of drift pin punches,alignment punches,[censored] and centering punches. Steering column lock plate compressor Steering wheel puller Stethoscope STUD INSTALLER TAPE MEASURE Test light Three or four of every size socket and wrenches Timing light Tire Pressure Gauges TORQUE WRENCH Transmission jack Tubing cutter Tubing flare tool Tubing bender Utility knife VACUUM GAUGE Wire crimper Wheel chocks (keep cars from rolling)
GOOD KNOWLEDGEABLE FRIENDS Other things to keep handy - TheBandit -------------------------------------------------------------------------------- Additional items that may come in handy - -------------------------------------------------------------------------------- Gasket scraper Plasma cutter Drill press Allen wrenches 12pt sockets Deep sockets Impact sockets Compressor Retracting extension cord Safety glasses Bench grinder w/ wire wheel Die grinder Wire crimper Valve spring compressor Breaker bar Distributor wrench Taps & dies Oil filter wrench Line wrenches Crows feet Shorty wrenches Tire iron Cutting torch FIRE EXTINGUISHER Throw-away vinyl gloves Plastic zip-lock bags Permanent marker Duct tape Electrical tape Torque wrench Oil pump primer Speed wrench Carburetor stand Tire pressure gauge Compression gauge Sandblaster Paint gun Utility knife Transmission jack Mallet Stethoscope
