Username Post: GOOD WRENCH AND GRUMPYVETTE'S HANDY TOOL LIST        (Topic#122215)
Dee Dee Dinah
Dee Dee Dinah
Loc: Lodi, California
Reg: 03-10-00
01-22-06 08:14 AM - Post#859321
A set of quick release tools for late model gm fuel lines and a/c line disconnects.
ACETYLENE TORCH
ADJUSTABLE LENGTH PUSH ROD
ADJUSTABLE POINTER ,
Adjustable stand, for dial indicator
Assorted pliers/vise grips
Air compressor
Air ratchet
Allen wrenches
ASK QUESTIONS
ASSORTED FILES
ASSORTED SOCKETS,OPEN AND BOX WRENCHES 1/2",3/8".1/4" DRIVE
Ball joint press tools
Ball joint separator forks
Battery charger(full size shop type)
Bench grinder w/ wire wheel
Big huge screwdriver which doubles as a pry bar
BORE GAUGE
Brake spring pliers and retaining spring tool
CAM BEARING INSTALLER
CAM DEGREE WHEEL
CAM HANDLE
CARBIDE BURRS
CC Buret Kit/PLUS STAND
Checking springs
chisels (assorted sizes/types)
clamp for compressing calipers
CLUTCH PILOT
Coil spring compressors
Compression tester
COMMON SENSE
CRANK SOCKETS
Creeper
Crows feet
CYLINDER HONE
DENT PULLER
DEPTH GAUGE
Dial indicator,
Die grinder
Differential Set-up Kit
Distributor wrench
DRIFT PUNCHES (assorted sizes/types)
Drain pans all sizes
Dremel tool set to cut rivets etc.
DRILL PRESS
Drop light (florescent preferred)
Dwell meter for the older cars
EASY OUTS
ELECTRIC SOLDER GUN
Electrical tape
Engine hoist
ENGINE LEVELER
ENGINE STAND
Feeler Gages
FIRE EXTINGUISHER
Flexible dwell key for point distributors
FREEZE PLUG INSTALLER
FUEL PRESSURE GAUGE
Full set of assorted hammers all the way up to 5 lb hand held full set of tap and dies metric and standard
Full set of torqze tip screw drivers and sockets male and female all sizes
Full size vice
Gasket scraper
Gear Pullers
GM disk brake caliper Allen key 3/8 and 5/16
Grease gun
Harmonic balancer puller
HARMONIC BALLANCER INSTALLER
HONING STONE
Jack stands and a 2 1/2 -3 ton full size service floor jack
JEWELERS FILES
LAPTOP COMPUTER
Leakdown tester
LIFTER BORE HONE
LIFTER GROOVE TOOL
LUIS TOOL
Magnet
MAGNETIC PICK UP TOOL
MAGNIFYING GLASS
MANUAL LUBE PUMP
MICROMETERS
MIG WELDER
Mini Valve Spring Tester
MIRROR
Multimeter
Normal screwdrivers all sizes
NUT SPLITTER
OIL CAN
Oil filter and regular spin on filter wrenches.
Oil filter wrench
Oil Pump Primers
ONE NEW SOLID LIFTER
PB BLASTER OIL
Pipe cutter
PISTON RING COMPRESSOR
Piston stop,
Pitman arm puller
Plasma cutter
PLASTIC HAMMER
Pneumatic chisel
Pneumatic impact guns 3/8 and 1/2 drive
Pressure bleeder for brakes
PRY BAR
PUSHROD CHECKER
Putty knife
Ramps
Rear caliper piston turning tool
REFERENCE MANUALS
RIFLE CLEANING ROD AND BRUSHES FOR OIL PASSAGES
Ring expander pliers
RING GAP FILER
Rochester idle mixture adjusting tool
ROD BOLT GUIDES
ROD BOLT STRETCH GAUGE
SCAN SOFTWARE
Sledge or mall hammer
SMALL FLASH LIGHT
Snap ring pliers internal and external
SPRING COMPRESSOR
Standard set of drift pin punches,alignment punches,[censored] and centering punches.
Steering column lock plate compressor
Steering wheel puller
Stethoscope
STUD INSTALLER
TAPE MEASURE
Test light
Three or four of every size socket and wrenches
Timing light
Tire Pressure Gauges
TORQUE WRENCH
Transmission jack
Tubing cutter
Tubing flare tool
Tubing bender
Utility knife
VACUUM GAUGE
Wire crimper
Wheel chocks (keep cars from rolling)
GOOD KNOWLEDGEABLE FRIENDS
Other things to keep handy - TheBandit
Additional items that may come in handy -
Gasket scraper
Plasma cutter
Drill press
Allen wrenches
12pt sockets
Deep sockets
Impact sockets
Compressor
Retracting extension cord
Safety glasses
Die grinder
Wire crimper
Valve spring compressor
Breaker bar
Distributor wrench
Taps & dies
Oil filter wrench
Line wrenches
Crows feet
Shorty wrenches
Tire iron
Cutting torch
FIRE EXTINGUISHER
Throw-away vinyl gloves
Plastic zip-lock bags
Permanent marker
Duct tape
Electrical tape
Torque wrench
Oil pump primer
Speed wrench
Carburetor stand
Tire pressure gauge
Compression gauge
Sandblaster
Paint gun
Utility knife
Transmission jack
Mallet
Stethoscope
Execution time: 0.45 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:17 AM
