Site Ambassador
07-27-20 06:36 PM - Post#2799701
In response to ejw71
If you don’t want a computer controlled transmission, I would suggest you at least step up to a 700-R4 or 200-4R. You’ll get the benefit of overdrive and only need to hook up a switch to lock the converter in overdrive. There are several different ways to accomplish that. The only other thing you will need is to move the trans crossmember, hook up a throttle valve cable and shorten the driveshaft. The 700-R4 takes the same yoke as the TH350. Not sure about the 200. I have a 700-R4 in my ‘78 El Camino and I love it. I have 3.50:1 gears and a 29 inch tall rear tire and at 70 mph my rpm’s are just under 2,000.
1957 Cameo Carrier |
