Username Post: copper plumbing - corrosion/pinholes only in cold water?        (Topic#354115)
LtFrankDrebin
LtFrankDrebin
Loc: Coopersburg, PA
Reg: 01-25-01
11-28-18 04:27 PM - Post#2752708
This house that we just bought a year and a half ago that was built in 1978 had the cold water circuit fail due to leaks. At first I thought that it was odd that repairs had only been done in the basement on the horizontal cold water pipes. Well, a leak sprung in the vertical pipe heading to the 2nd floor, and then a few weeks after that, a leak sprung in the horizontal pipe in the 2nd floor. I just finished replacing all of the 2nd floor cold water system with CPVC. Question is - should I replace the copper hot water system as well? Knock on wood - there has been no repairs done to the hot water system at all so far. Why is that?
'56 210 Townsman wagon 6cyl/3spd OD | '58 Impala Sierra Gold 348
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-29-18 08:37 AM - Post#2752774
    In response to LtFrankDrebin
it sure sounds like you have an issue with electrolysis (electrical current flow in the pipes causing damage to the pipes,) as the current causes corrosion
https://www.youtube.com/watch?v=nD5lMITzx_Y
https://www.youtube.com/watch?v=tjz_QoorocM
your electrical system must have a great
separate,electrical ground rod ground, if your using the pluming pipes as a ground source your bound to have issues related to electrolysis
Edited by grumpyvette on 11-30-18 06:43 AM. Reason for edit: No reason given.
11-29-18 08:39 PM - Post#2752844
    In response to grumpyvette
Sounds like it to me too. I have copper in my almost 62 year old house and have never had any problems.
1957 Cameo Carrier
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
12-01-18 09:38 AM - Post#2752988
FROM THIS OLD HOUSE
Richard Trethewey replies: Generally, leaks in copper pipe can be traced back to a problem with the way the pipes were installed or to the water itself. For instance, flux—the acidic paste used in soldering—react with copper if the pipes stand idle for a long period after installation. This kind of trouble typically crops up near fittings and in cold-water pipes because hot water is better at washing flux away. Also, if a pipe wasn't reamed after being cut, the burr on the inside will cause turbulence—tiny swirls of water so vigorous that they actually wear away the metal. Too much velocity, either from undersized pipes or excessive water pressure, can have the same effect.
Then there's the water itself. Anything abrasive, such as bits of rust or any other contaminant, will scour the inside of the pipe and exacerbate the effects of turbulence and velocity. So-called "aggressive," or acidic, water with a pH of 6.8 or less will eat through copper. Water loaded with dissolved minerals can generate copper-dissolving electrical charges.
BTW,I CHANGED ALL MY COPPER OVER TO HI TEMP PVC,EVEN THE COLD ABOUT 20 YEARS AGO.USED 3/4 IN
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
12-01-18 04:36 PM - Post#2753020
    In response to TAT_2
i had a pin hole leak in my basement. there was green around the hole. it was in the middle area
of the half inch pipe. jim
Execution time: 0.018 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:34 PM
