Username Post: Corn gas!        (Topic#353616)
100 CHEVY
Deceased Member RIP
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
10-26-18 07:26 PM - Post#2749641
Since the govt.has decided to allow the amount of ethanol in fuel to go up,who knows how to remove it or neutralize it?
I don't want to destroy all my gasoline engines.Or,constantly rebuild carbs,replace rubber parts,etc.
Plus,regular gas seems to always be way higher than the price of ethanol gas.And,getting harder to find!
Mike.
Senior Moderator
10-27-18 04:51 AM - Post#2749661
    In response to 100 CHEVY
Set up a plant in the back yard, buy in bulk, separate the ethanol and drink it?
Beats me; we've had ethanol fuel down here forever now. I don't think there's any "pure" gas anywhere near us.
Just noticed the primer bulb on my weed whacker has developed a hole dead center where you push it...
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
10-27-18 05:35 AM - Post#2749663
Pretty hard to avoid ethanol any more where I live. Learned the hard way that I no longer can let any gas engine set for more than a few months with gas in them. Especially during the hotter Summer months. I drain every thing with a small gas engine when I'm done with it now, especially 2 cycle engines.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C,
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
10-27-18 06:55 AM - Post#2749671
    In response to someotherguy
That is the way the primer bulbs are built.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
10-27-18 02:33 PM - Post#2749714
    In response to 2blu52
most reasonable lower compression car/truck engines , built in the last 30 years, can run the crappy low octane 10% ethanol laced pump swill thats sold at your local gas station.
if you have an older muscle car that had an 11:1 or higher compression engine or your running an engine like a chain saw or lawn mower that may be sitting for months between uses that ethanol laced crap is very detrimental, as it sits without any movement it tends over extended time, frames, to separated out, ethanol is hygroscopic
hy·gro·scop·ic
/?h??r??skäpik/Submit
adjective
(of a substance) tending to absorb moisture from the air.
relating to humidity or its measurement.
since water is heavier than gas, it settles to the bottom of the tank and in direct contact with the metal surface it can and frequently does cause corrosion issues
products like "STABILE MARINE FUEL ADDITIVE
https://www.walmart.com/ip/STA-BIL-xc2-xae-22 240-3...
https://www.walmart.com/ip/STA-BIL-22275-360- Perfo...
https://www.walmart.com/ip/Marvel-MM13R-Myste ry-Oi...
adding 6 oz of each of these 3 products to your fresh fuel , assuming the common, (16-20 gallon tank capacity) before you put your muscle car in storage is a huge help in preventing problems from developing over a winters storage
heres a web site that lists stations that carry reasonably priced real gas with zero ethanol
https://www.pure-gas.org/
Edited by grumpyvette on 10-28-18 05:37 PM. Reason for edit: No reason given.
Senior Moderator
10-27-18 10:05 PM - Post#2749741
That is the way the primer bulbus are built.
I wondered about that but I've owned this thing for a couple years and don't ever recall the primer bulb getting gas on my finger before. The one on my mower doesn't have a hole...
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
10-28-18 07:26 AM - Post#2749761
if you do not use the trimmer much buy can gas at
the hardware store. it has no alcohol. it is not cheap. jim
10-28-18 09:32 AM - Post#2749768
    In response to jdk
Non ethanol premium is available in upstate NY.
TAT_2
Member #26 "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
10-28-18 04:37 PM - Post#2749792
Cross Keys Airport - PHILLIPS 66
1531 N Tuckahoe Rd, Williamstown NJ
856-629-3033
Ethanol-free octane ratings: 100
GPS coordinates: N 39.70650 W 75.02680 (entered by N/A)
Updated by rob carsey, July 07, 2017 1:47 CDT
This is 100LL (typical avgas available at all airports). It DOES contain lead and will foul most engines not designed for lead.
JUST A HOP SKIP & A JUMP FROM ME.
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6SPD/RAG TOP
NEXT ?
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
10-29-18 01:29 PM - Post#2749906
https://youtu.be/kSnE4MYwRzs
Been thinking about this for my "storage gas cans".
Street bikes needs their float bowls drained for winter storage because those carbs are a chore to clean. Happy I got an ultra sonic bath now, though.
http://www.youtube.com/watch?v=SXn2QVipK2o&a mp;fea...
100 CHEVY
Deceased Member RIP
100 CHEVY
Reg: 12-09-04
10-29-18 03:09 PM - Post#2749923
    In response to Impala65SS
I watched that video before I made this post!It was all I could find and I have some reservations about his methods.
How does he know he's getting it all out,or if it's even working?
Is there something like a ph tester I could get?
Mike.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
10-30-18 06:21 AM - Post#2749971
if you don,t want alcohol content in your fuel... simply buy it from a source that sells pure 100% petroleum gas
larrybrowningmauldin
Loc: New Braunfels,TX
Reg: 08-16-05
04-30-19 12:19 PM - Post#2765391
    In response to grumpyvette
Look at the web site pure-gas.org
I found several Murphy (Walmart) stations here in south central Texas which are noted as having ethanol-free gasoline.
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
07-09-19 10:07 AM - Post#2770283
    In response to larrybrowningmauldin
Back in the old days, we used to use glycol (anti-freeze) to absorb the ethanol in gasoline.
It was a test we would perform in the dealership to see how much ethanol was in a customer's fuel. we would put a certain measure of glycol in a graduated cylinder, pour in the fuel, stir and measure the glycol level again. The difference between the first and second measurement was the amount of ethanol/alcohol in the fuel mixture.
I don't know if you could then siphon off the remaining "clean" fuel and burn it in an engine - I've never tried it, but I thought I'd throw that in there for good measure.
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L,
1966 C20 Custom Camper "Rattle can primer red" 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
07-12-19 07:04 AM - Post#2770521
    In response to hilandr451
Execution time: 0.103 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:25 AM
