Username Post: New guy with engine mystery        (Topic#366648)
Joe Dirte
Reg: 10-09-21
10-09-21 01:01 PM - Post#2828877
1998 k1500. 350. Have a weird shake at about 1700 rpm. Only codes I'd get were low readings on o2s. Fuel pump was only pushin bout 50psi. Just swapped that out today but of course I can't find my scanner to check the sensors readings. This has been an ongoing issue since I got the truck running. No misfires, no leaks, no other codes than low readings on o2s.
Edited by Joe Dirte on 10-09-21 01:02 PM. Reason for edit: No reason given.
10-10-21 04:19 PM - Post#2828933
    In response to Joe Dirte
If this a Vortec that fuel pressure is too low. Should be about 62 psi. Check the specs for your engine, that could skew your o2 readings.
Edited by Shepherd on 10-10-21 04:20 PM. Reason for edit: No reason given.
10-12-21 07:48 PM - Post#2829057
uh, is that in park? welcome to ct.
Execution time: 0.098 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:40 AM
