Username Post: 89 suburban electrical issue need help desperatly( reposted so i can subscr        (Topic#339950)
trentin_k
Reg: 10-19-16
10-19-16 03:20 AM - Post#2657293
it has no electrical power at all but the headlights still work. its an 89 suburban with powered locks windows yada yada and none of it works except the headlights could really use some help i have to get to work tomarrow at 1500 pasific time. and i already checked fuses and all were still good but i couldnt check the power fuses because they are not clear and im not sure if that cheap teaster that you can get for testing fuses will work on those. any help will be greatly apprishiated.
trentin_k
Reg: 10-19-16
10-19-16 03:47 AM - Post#2657298
    In response to trentin_k
any help at all guys and gals even wild guesses might set me on the right path
10-19-16 05:01 AM - Post#2657306
Not sure on that truck but check the fusible links at the starter harness.
Chevytech
Chevytech
Reg: 04-25-04
10-19-16 06:48 AM - Post#2657316
That 89 burb is a square body so it has a fusible link between the brake booster and the center of the firewall that should be checked. It is near the battery junction block by the booster.
Execution time: 0.015 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:33 PM
