Username Post: 1988 k1500 305 stutter in acceleration        (Topic#320595)
pudge00
Reg: 01-28-15
01-28-15 08:20 PM - Post#2518657
My truck has been doing this for a while it runs good until you pass up 1/4 throttle then stutters and backfires ive replaced the coolant temp sensor throttle body iac valve tps sensor distributor
Plugs wires knock sensor oxygen sensors ecm and egr valve im starting to think it may be electrical like a bad ground? Im just wanting to get some opinions before i sink more money in it and while im at it the transmission pulls as it should but tries to hang between 2nd and drive could this be a torque converter? Thanks ahead
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-28-15 08:41 PM - Post#2518660
    In response to pudge00
You been running a zinc additive? Flat tappet cams need zinc and the EPA took it out of oil. They don't care if it kills your cam. It's possible it could need plugs, wires, cap, and rotor. I'd make sure you didn't wipe a cam lobe before you shotgun more money at it.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
01-29-15 01:13 AM - Post#2518711
how is your fuel pressure and filter?
Execution time: 0.019 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:45 AM
