jbander
Reg: 07-19-19
09-17-21 04:27 PM - Post#2827280
Normal driving it is fine shift at about 35 mph but put down the accelerator to the floor and it won't shift into 4th , I've run it up to 6500, all the rest of the gears are fine/. 1987 Camaro 355 built.
Edited by jbander on 09-18-21 10:25 AM. Reason for edit: No reason given.
09-18-21 05:10 AM - Post#2827297
In response to jbander
Under full throttle you may not get a 3-4 shift til 75, depends on the governor calibration.
jbander
Reg: 07-19-19
09-18-21 10:24 AM - Post#2827311
I've run it up above red line to 6500, no shift
09-18-21 05:15 PM - Post#2827327
Ok, throttle linkage adjustment is checked first, then get to the governor, check for its normal operation, got to get it out to do this. No mods to the valve body?
paulo57509
Loc: CA
Reg: 07-18-00
09-23-21 08:27 AM - Post#2827774
https://transgo.com/product-details/700-3 -4-shift-...
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari |
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
09-26-21 01:56 PM - Post#2828018
I'm just gonna ask, but are you sure that you have a 4-speed automatic? Just asking...
jbander
Reg: 07-19-19
09-26-21 08:55 PM - Post#2828067
In response to Tony1963
Yes it is a 700R4 , here is the problem that I found out weeks ago- a 700r4 was designed not to shift into 4th at full power. I should have responded with this information. Don't ask me why , I will find out but I haven't yet.Thanks folks.
Tony1963
Reg: 07-09-18
09-27-21 05:33 PM - Post#2828142
I can understand that. With the pedal on the floor, the throttle cable is keeping from the overdrive shift. Makes sense.
jbander
Reg: 07-19-19
11-08-21 09:10 PM - Post#2830488
Actually a 700R4 was designed not to shift into OD ever at wot.
Edited by jbander on 11-08-21 09:10 PM. Reason for edit: No reason given.
