Username Post: changing from a disc/drum proportioning valve to a disk/disk on a 87 camar        (Topic#365510)
jbander
Reg: 07-19-19
06-13-21 07:27 PM - Post#2821579
I'm wondering , there is 5 inlets that you plumb into your brake system on the disk/disk(PV4) combination proportioning valve that I'm trying to install and they look like they are all different then the brake line that I have in there now which has a disk/drum proportioning valve (PV2). , is there a disk/disk proportioning valve that will fit the existing brake lines that are in the 87 camaro now?
paulo57509
Loc: CA
Reg: 07-18-00
06-14-21 01:29 PM - Post#2821597
    In response to jbander
What exactly are you trying to do? It's not clear. It sounds like you're swapping over to a disc/disc from a disc/drum system and swapping the disc/disc combination (proportioning) valve is the problem?
Which port(s) don't match?
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
jbander
Reg: 07-19-19
06-14-21 07:45 PM - Post#2821609
    In response to paulo57509
Sorry its a 87 Camaro with disk/drum that I;m swapping for disk/disk. My problem is that the universal GM disk disk proportioning valve doesn't have the same size compression fittings, which makes it a big hassle . so I'm going to try to use the disk/drum proportioning valve that is in it now but install a stiffer pressure spring. Just need the spring number.
Execution time: 0.007 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:19 AM
